Support for volumetric cloud
Does Create supports this?
I generated a cloud with this plugin in Blender but when I export to Omniverse it just shows a cube.
Also is there a quick way to create clouds in Omniverse?
it says:
Future work
  • Add automatic volume export file (VDB).
That is the one you can import to Omniverse
Thanks,
I found a cloud vdb file and it seems to work, but when I imported it into the scene it’s terribly slow. I’m using a A4000. Have attached the file, you can try it out. Not sure if it’s my machine or OV it’s not stable yet.
cloudVDB1.usdc (1.3 KB)
sorry I have no time to study this now, so much work at hand.
I hope Nvidia people can check out this speed issue…
Hey, i found a little time…
I followed this tutorial:
But I could not see anything :P
See, I made a video for you. First I have the Embergen free asset visible ( following the above great tutorial by Tyler ):
Then I change to your file…and nothing.
So there is something still wrong in that vbd…
I cannot help you futher, but somehow you need to compare the embergen vbd and yours…
Thanks a lot, this method works! I could never have figured this out on my own.
Hurray!!!
