I am looking for a supported, noninterrupting way to attribute CUDA activity in WSL2/Docker to exact guest processes while retaining visibility of competing CUDA contexts on the same physical GPU.
Retained environment: RTX 3060, Windows NVIDIA driver 591.86, and a prebuilt Nsight Systems 2025.6.1 Linux Target. These are retained versions, not a freshly checked installation. Raw nvidia-smi --query-compute-apps=pid,process_name,used_gpu_memory --format=csv,noheader,nounits returned empty rows during active workloads. A separate model-free fixture produced positive Nsight CUDA graph records despite empty NVML process rows. This demonstrates scoped trace visibility, but does not demonstrate a complete process census or zero loss.
The current Nsight guide describes system-wide CUDA injection as limited to eligible same-user processes launched after collection begins. The public GPU-PV description associates guest DXGPROCESS objects with the Windows vmmem process. Neither fact appears to supply a complete public observer join on its own.
Which supported interface and exact provider/event/API fields can provide the following on this platform?
- A join between guest Linux PID, process lifecycle/start identity, VM identity, host DXGPROCESS/GPU context, and the physical GPU. What PID namespace or thread semantics apply?
- Rundown and coverage of preexisting and newly created, uninstrumented compute contexts across Windows and WSL users, distinguishable from ordinary display activity.
- Explicit dropped-event/buffer-loss and coverage diagnostics, including documented timestamp and observation-interval semantics.
- The availability, privilege requirements, and an existing CLI example or export schema for RTX 3060 / driver 591.86 / WSL GPU-PV.
Can this be obtained without replacing the display driver, changing scheduler settings, or restarting Windows/WSL? If no supported interface provides these guarantees, an explicit statement of that limitation would also help us choose the next design step.
References:
