Hello everyone,
It appears that when the system should become ready to login and running, some errors start to appear on the console:
Mellanox MLNX-OS Switch Management
cmpny-GW login: Apr 17 16:11:22 cmpny-GW mgmtd[4229]: [mgmtd.ERR]: Initial commit failed. Code: 1 Message: Can’t configure IP 10.22.100.253/24 to proxy-arp interface - conflicts with IP 10.22.100.90/24 of interface mgmt0
Apr 17 16:11:24 cmpny-GW chad[4742]: [chad.ERR]: chad_mgmt_init(), chad.c:1150, build 1: Error code 14004 (item not found) returned
Apr 17 16:11:24 cmpny-GW chad[4742]: [chad.ERR]: chad_mgmt_init(), chad.c:1187, build 1: Unable to connect to the management daemon
Apr 17 16:11:24 cmpny-GW chad[4742]: [chad.ERR]: bn_binding_get_uint8(), bnode_types.c:2898, build 1: NULL binding passed
Apr 17 16:11:29 cmpny-GW chad[4742]: [chad.ERR]: chad_init_internal(), chad.c:2722, build 1: Error code 14004 (item not found) returned
Apr 17 16:11:29 cmpny-GW chad[4742]: [chad.ERR]: main(), chad.c:2916, build 1: Error code 14004 (item not found) returned
Apr 17 16:11:29 cmpny-GW chad[4756]: [chad.ERR]: chad_mgmt_init(), chad.c:1150, build 1: Error code 14004 (item not found) returned
Apr 17 16:11:29 cmpny-GW chad[4756]: [chad.ERR]: chad_mgmt_init(), chad.c:1187, build 1: Unable to connect to the management daemon
Apr 17 16:11:29 cmpny-GW chad[4756]: [chad.ERR]: bn_binding_get_uint8(), bnode_types.c:2898, build 1: NULL binding passed
Apr 17 16:11:29 cmpny-GW chad[4756]: [chad.ERR]: chad_init_internal(), chad.c:2722, build 1: Error code 14004 (item not found) returned
Apr 17 16:11:29 cmpny-GW chad[4756]: [chad.ERR]: main(), chad.c:2916, build 1: Error code 14004 (item not found) returned
Apr 17 16:11:31 cmpny-GW chad[4767]: [chad.ERR]: chad_mgmt_init(), chad.c:1150, build 1: Error code 14004 (item not found) returned
Apr 17 16:11:31 cmpny-GW chad[4767]: [chad.ERR]: chad_mgmt_init(), chad.c:1187, build 1: Unable to connect to the management daemon
Apr 17 16:11:31 cmpny-GW chad[4767]: [chad.ERR]: bn_binding_get_uint8(), bnode_types.c:2898, build 1: NULL binding passed
Apr 17 16:11:31 cmpny-GW chad[4767]: [chad.ERR]: chad_init_internal(), chad.c:2722, build 1: Error code 14004 (item not found) returned
Apr 17 16:11:31 cmpny-GW chad[4767]: [chad.ERR]: main(), chad.c:2916, build 1: Error code 14004 (item not found) returned
Apr 17 16:11:34 cmpny-GW chad[4775]: [chad.ERR]: chad_mgmt_init(), chad.c:1150, build 1: Error code 14004 (item not found) returned
Apr 17 16:11:34 cmpny-GW chad[4775]: [chad.ERR]: chad_mgmt_init(), chad.c:1187, build 1: Unable to connect to the management daemon
Apr 17 16:11:34 cmpny-GW chad[4775]: [chad.ERR]: bn_binding_get_uint8(), bnode_types.c:2898, build 1: NULL binding passed
Apr 17 16:11:34 cmpny-GW chad[4775]: [chad.ERR]: chad_init_internal(), chad.c:2722, build 1: Error code 14004 (item not found) returned
Apr 17 16:11:34 cmpny-GW chad[4775]: [chad.ERR]: main(), chad.c:2916, build 1: Error code 14004 (item not found) returned
Apr 17 16:11:43 cmpny-GW chad[4784]: [chad.ERR]: chad_mgmt_init(), chad.c:1150, build 1: Error code 14004 (item not found) returned
Apr 17 16:11:43 cmpny-GW chad[4784]: [chad.ERR]: chad_mgmt_init(), chad.c:1187, build 1: Unable to connect to the management daemon
Apr 17 16:11:43 cmpny-GW chad[4784]: [chad.ERR]: bn_binding_get_uint8(), bnode_types.c:2898, build 1: NULL binding passed
Apr 17 16:11:43 cmpny-GW chad[4784]: [chad.ERR]: chad_init_internal(), chad.c:2722, build 1: Error code 14004 (item not found) returned
Apr 17 16:11:43 cmpny-GW chad[4784]: [chad.ERR]: main(), chad.c:2916, build 1: Error code 14004 (item not found) returned
Apr 17 16:12:10 cmpny-GW chad[4795]: [chad.ERR]: chad_mgmt_init(), chad.c:1150, build 1: Error code 14004 (item not found) returned
Apr 17 16:12:10 cmpny-GW chad[4795]: [chad.ERR]: chad_mgmt_init(), chad.c:1187, build 1: Unable to connect to the management daemon
Apr 17 16:12:10 cmpny-GW chad[4795]: [chad.ERR]: bn_binding_get_uint8(), bnode_types.c:2898, build 1: NULL binding passed
Apr 17 16:12:10 cmpny-GW chad[4795]: [chad.ERR]: chad_init_internal(), chad.c:2722, build 1: Error code 14004 (item not found) returned
Apr 17 16:12:10 cmpny-GW chad[4795]: [chad.ERR]: main(), chad.c:2916, build 1: Error code 14004 (item not found) returned
Apr 17 16:13:31 cmpny-GW chad[4811]: [chad.ERR]: chad_mgmt_init(), chad.c:1150, build 1: Error code 14004 (item not found) returned
Apr 17 16:13:31 cmpny-GW chad[4811]: [chad.ERR]: chad_mgmt_init(), chad.c:1187, build 1: Unable to connect to the management daemon
Apr 17 16:13:31 cmpny-GW chad[4811]: [chad.ERR]: bn_binding_get_uint8(), bnode_types.c:2898, build 1: NULL binding passed
Apr 17 16:13:31 cmpny-GW chad[4811]: [chad.ERR]: chad_init_internal(), chad.c:2722, build 1: Error code 14004 (item not found) returned
Apr 17 16:13:31 cmpny-GW chad[4811]: [chad.ERR]: main(), chad.c:2916, build 1: Error code 14004 (item not found) returned
Apr 17 16:16:30 cmpny-GW snmpd[4746]: TID 1208121120: [snmpd.ERR]: sn_mib_get_caching_interval(), sn_mib_mellanox.c:334, build 1: Unexpected NULL
Apr 17 16:16:30 cmpny-GW snmpd[4746]: TID 1208121120: [snmpd.ERR]: sn_mib_entity_init(), sn_mib_entity.c:79, build 1: Error code 14001 (unexpected NULL) returned
Apr 17 16:17:30 cmpny-GW snmpd[4746]: TID 1208121120: [snmpd.ERR]: sn_mib_interfaces_init(), sn_mib_interfaces.c:106, build 1: Error code 14001 (unexpected NULL) returned
Apr 17 16:17:30 cmpny-GW snmpd[4746]: TID 1208121120: [snmpd.ERR]: sn_mib_mellanox_init(), sn_mib_mellanox.c:418, build 1: Unexpected NULL
Apr 17 16:17:30 cmpny-GW snmpd[4746]: TID 1208121120: [snmpd.ERR]: sn_modules_init(), …/…/tms/sn_modules.c:165, build 1: Error code 14001 (unexpected NULL) returned
Apr 17 16:17:35 cmpny-GW chad[4843]: [chad.ERR]: chad_mgmt_init(), chad.c:1150, build 1: Error code 14004 (item not found) returned
Apr 17 16:17:35 cmpny-GW chad[4843]: [chad.ERR]: chad_mgmt_init(), chad.c:1187, build 1: Unable to connect to the management daemon
Apr 17 16:17:35 cmpny-GW chad[4843]: [chad.ERR]: bn_binding_get_uint8(), bnode_types.c:2898, build 1: NULL binding passed
Apr 17 16:17:35 cmpny-GW chad[4843]: [chad.ERR]: chad_check_restarts: Too many CHAD restarts; fail_count=7, max_num_of_retries=7 CHAD is the Killing system in 2 seconds.
Restarting system.
I can eventually show the complete POST log…
How would one fix this?
Regards
