Tearing in VR since 570.x
Since Linux driver 570 (no matter if .86 or .124) I got tearing in VR with the Valve Index on my nVidia 2080 via Display Port. I’m on Ubuntu 24.04 LTS. It’s independent of if GSP is enabled or not or NVreg_RegistryDwords=RMIntrLockingMode=1 is present or not.
I tried both setting it as a grub boot parameter “nvidia.NVreg_EnableGpuFirmware=1 nvidia.NVreg_RegistryDwords=RMIntrLockingMode=1” and sudo update-grub or via module setting in /usr/lib/modprobe.d/nvidia.conf and afterwards using sudo update-initramfs -u -k all (but not grub and modprobe at the same time).
Shaking my head in VR reveals a horizontal line where the upper and lower images have different latency. Comparabel to the latancy introduced here: Latency in VR (with GSync) since 440.44
Where this seperation line occurs seems random, once I was in the upper quarter another time in the lower quarter.
It’s independent of if I use SteamVR or Monado, if async reprojection is enabled or not.
Downgrading to driver 565 resolves this issue, just the rendering latency issue (linked above) remains, just no tearing.
I do not have this issue on my PC with 3070 using HTC Vive via HDMI on driver 570.x (disabled GSP though, as the stutter/lags in VR issue is not solved with setting NVreg_RegistryDwords=RMIntrLockingMode=1)
Looks like the tearing could be OpenVR only. It occurs in Beat Saber 1.29 but not in Pistol Whip, while Beat Saber 1.29 (using legacy beta branch) is not yet OpenXR, Pistol Whip is OpenXR. Needs more testing to narrow it down.
edit: it also happens in Pistol Whip.
Yet as written in the other thread (Latency in VR (with GSync) since 440.44 - #8 by Corben78), the headtrack delay seems gone in Monado with the U_PACING_COMP_PRESENT_TO_DISPLAY_OFFSET_MS=10setting.
This is still affecting me, all the way up to 580.82.09 (on Gentoo), although it seems to be tied to async reprojection for me.
  • Independent of refresh rate
  • Occurs all the time, in and out of games
  • Only occurs when two conditions are met:
    • “enableLinuxVulkanAsync” : true in steamvr.vrsettings
    • steamvr is actually able to enable async reprojection
      • Either by running steam with STEAM_RUNTIME=1, or by using setcap CAP_SYS_NICE=ep on vrcompositor-launcher and launching it outside of steam.
  • I haven’t experimented with module parameters yet
Otherwise it’s exactly like Corben78 describes: The lower 1/3? of the view has a curved horizontal tear line where everything below seems to lag behind everything above when I move my head around.
565 (Specifically 565.77 for me) works without issue, but I won’t be able to stay on that version forever. Every driver since then has experienced this horizontal tear issue when async is enabled.
Still happening to me as of 580.119.02 on Gentoo
If Steam can enable async reprojection I get a horizontal tear and everything below it has different latency from everything above it. This causes the bottom portion of the screen to “lag behind” as I move my head around.
Here is a bug report log where I booted the computer and logged in, launched Steam with “STEAM_RUNTIME=1 steam”, and then launched SteamVR. I confirmed that Asyncronous Reprojection was enabled in the logs:
Sun Dec 21 2025 12:35:09.661729 [Info] - Attempting to enable async support…
Sun Dec 21 2025 12:35:09.661744 [Info] - Enabling async support!
nvidia-bug-report.log.gz (1.3 MB)
Here’s another, same behavior on 590.48.01
Maybe worth noting, the location of the tear line changes. As I continue to move my head around the line moves lower and then briefly disappears, and when it does it looks like async has been fully disabled. Then it comes back, higher in my viewport again and the behavior repeats.
nvidia-bug-report.log.gz (684.4 KB)
Sounds somewhat similar to
and its connected github issue:
