• Hardware Platform (Jetson / GPU) Jetson • DeepStream Version 6.2 • JetPack Version (valid for Jetson only) 5.1.1 • TensorRT Version 8.5.2.2 • Issue Type( questions, new requirements, bugs) Questions
Hi, I’m using the test.py example to test an app based on deepstream_nvdsanalytics. I have the following questions. I would like to build on test2, i.e. end-to-end testing of my application.
-Should I modify the pipeline_fakesink_tracker class to accept multiple video streams?
-Also, should I add reading the config_nvdsanalycs.py configuration file?
-Maybe there is something already developed?
In the end I have generated a test that checks the application thanks to the console output, taking advantage of the fact that in each nvdsanalytics event I print on screen the frame and the object.
So, I have solved it this way and for now, it is valid for me.
