The 5V and GND short circuits of the ORIN module (without carrier board )are suspected to be caused by A3 (PRSNT0) and 12V short circuits. It is possible that there is a problem with which power chip
Not sure what you mean there is a problem, please provide more details. Thanks
After being powered on, ORIN doesn’t work。The resistance between 5V and ground on the module(Only the ORIN without carrier board) is 3 ohm.
5V means ORIN’s SYS_VIN_MV power supply
Seems some devices on module are damaged and cause such short b/w 5V and GND. You may need RMA for it. Jetson FAQ | NVIDIA Developer
