flash cmd: sudo ./l4t_initrd_flash.sh jetson-agx-thor-devkit internal
err msg:
[flash_bsp_jetson-t264_die0]: [executeShellCommand(156)] : command = timeout 5 /home/jason/nfs-share/nvidia_jetson_thor_R38.2.1_J7.0/Linux_for_Tegra/unified_flash/out/bsp_images/tools/flashtools/flash/adb -s 2U1TS830G000004G00E0 wait-for-device
cwd = /home/jason/nfs-share/nvidia_jetson_thor_R38.2.1_J7.0/Linux_for_Tegra/unified_flash/out/bsp_images/flash_workspace/flash-images
[flash_bsp_jetson-t264_die0]: [executeShellCommand(171)] : shell command – timeout 5 /home/jason/nfs-share/nvidia_jetson_thor_R38.2.1_J7.0/Linux_for_Tegra/unified_flash/out/bsp_images/tools/flashtools/flash/adb -s 2U1TS830G000004G00E0 wait-for-device failed
[flash_bsp_jetson-t264_die0]: [executeShellCommand(173)] : Output:
[flash_bsp_jetson-t264_die0]: [executeShellCommand(175)] : Return code: 124
[flash_bsp_jetson-t264_die0]: [executeShellCommand(177)] : stdout: b’’
[flash_bsp_jetson-t264_die0]: [executeShellCommand(179)] : stderr: None
[flash_bsp_jetson-t264_die0]: [AdbFindDevice(203)] : the ADB device is not yet found online : 2U1TS830G000004G00E0
[flash_bsp_jetson-t264_die0]: [AdbFindDevice(204)] : current totaltime in finding device online : 95
[flash_bsp_jetson-t264_die0]: [AdbFindDevice(208)] : failed to find the device :2U1TS830G000004G00E0 online at the end of :100 seconds
[flash_bsp_jetson-t264_die0]: [CheckUSBServiceInit(275)] : Could not find the 2U1TS830G000004G00E0 device online
[flash_bsp_jetson-t264_die0]: [RestartAdbServer(220)] : Killing the ADB server…
[flash_bsp_jetson-t264_die0]: [executeShellCommand(156)] : command = /home/jason/nfs-share/nvidia_jetson_thor_R38.2.1_J7.0/Linux_for_Tegra/unified_flash/out/bsp_images/tools/flashtools/flash/adb kill-server
[flash_bsp_jetson-t264_die0]: [executeShellCommand(163)] :
[flash_bsp_jetson-t264_die0]: [RestartAdbServer(222)] :
[flash_bsp_jetson-t264_die0]: [RestartAdbServer(224)] : Re-starting the ADB server after killing…
[flash_bsp_jetson-t264_die0]: [startADBServer(168)] : Starting ADB server
[flash_bsp_jetson-t264_die0]: [executeShellCommand(156)] : command = /home/jason/nfs-share/nvidia_jetson_thor_R38.2.1_J7.0/Linux_for_Tegra/unified_flash/out/bsp_images/tools/flashtools/flash/adb start-server
[flash_bsp_jetson-t264_die0]: [executeShellCommand(171)] : shell command – /home/jason/nfs-share/nvidia_jetson_thor_R38.2.1_J7.0/Linux_for_Tegra/unified_flash/out/bsp_images/tools/flashtools/flash/adb start-server failed
[flash_bsp_jetson-t264_die0]: [executeShellCommand(173)] : Output: error: protocol fault (couldn’t read status): Connection reset by peer
[flash_bsp_jetson-t264_die0]: [executeShellCommand(175)] : Return code: 255
[flash_bsp_jetson-t264_die0]: [executeShellCommand(177)] : stdout: b"error: protocol fault (couldn’t read status): Connection reset by peer\n"
[flash_bsp_jetson-t264_die0]: [startADBServer(172)] : failed to start-server
[flash_bsp_jetson-t264_die0]: [RestartAdbServer(227)] : Could not start ADB server, after killing ADB server
The flashing cable is the official matching data cable, and the carrier board is also official. Successful flashing has been achieved before.
