Hi All,
I use 2 imx390 to light up the camera using port 3, why can’t I get a picture? All other ports are ok, please help me check, thank you.
test command:
v4l2-ctl -d /dev/gmsl5 --set-ctrl sensor_mode=0 --set-fmt-video=width=1920,height=1080,pixelformat=YUYV --stream-mmap=3 --stream-skip=3 --stream-count=1 --stream-poll --stream-to=-|ffmpeg -loglevel quiet -f rawvideo -s 1920x1080 -pix_fmt yuyv422 -i - /tmp/gmsl5_output.jpeg
soft version:
root@tegra:/sys/kernel/debug/dynamic_debug# cat /etc/nv_tegra_release
# R35 (release), REVISION: 4.1, GCID: 33958178, BOARD: t186ref, EABI: aarch64, DATE: Tue Aug 1 19:57:35 UTC 2023
