The position of rigid_body will change repeatedly between two different positions when the environment is reset
In the “compute _observations” function of “Franka Cabinet”, the following code can read the position of rigid_body normally
 self.franka_lfinger_pos = self.rigid_body_states[:, self.lfinger_handle][:, 0:3]
 self.franka_rfinger_pos = self.rigid_body_states[:, self.rfinger_handle][:, 0:3]
I tried to imitate FrankaCabinet, but found that with theses codes the position of rigid_body will change repeatedly between two different positions when the environment is reset(“reset_idx”).
I did not use “gym.get_rigid_transform” and “gymapi.Transform()” to declare variables. Will this have an impact?
Here is the entire code about the variable like “self.franka_lfinger_pos”:
def __init__(self, cfg, sim_device, graphics_device_id, headless):
          self.racket_pos=torch.zeros_like(self.rigid_body_states[:, self.racket_handle][:, 0:3])
          self.ball_pos=torch.zeros_like(self.rigid_body_states[:, self.racket_handle][:, 0:3])
def compute_observations(self):
    self.racket_pos = self.rigid_body_states[:, self.racket_handle][:, 0:3]
    self.ball_pos = self.rigid_body_states[:, self.ball_handle][:, 0:3]
    self.obs_buf = torch.cat((dof_pos_scaled, self.Robot_dof_vel * self.dof_vel_scale, self.racket_pos, self.ball_pos), dim=-1)
 def compute_reward(self, actions):
   self.rew_buf[:], self.reset_buf[:] = compute_PingPong_reward(
   self.reset_buf, self.progress_buf, self.actions, self.racket_pos,self.ball_pos,
   self.num_envs, self.dist_reward_scale,self.action_penalty_scale, self.max_episode_length
The values I set are as follows, but I think it should be correct.
def reset_idx(self, env_ids):
ball_pos = self.ball_pos_lower_limits+torch.rand((len(env_ids),1, 3), device=self.device)*(self.ball_pos_higher_limits-self.ball_pos_lower_limits)
        self.ball_rigid_pos[env_ids] = ball_pos.squeeze(1)
    ball_state=torch.cat((ball_pos,self.default_ball_states[env_ids,...,3:]),dim=-1)
    self.ball_root_states[env_ids] = ball_state
    self.gym.set_actor_root_state_tensor(self.sim,
                                                gymtorch.unwrap_tensor(self.root_state_tensor)),
    self.gym.set_dof_position_target_tensor(self.sim,gymtorch.unwrap_tensor(self.Robot_dof_targets))
    self.gym.set_dof_state_tensor(self.sim,gymtorch.unwrap_tensor(self.dof_state))
    self.progress_buf[env_ids] = 0
    self.reset_buf[env_ids] = 0
As long as I delete these codes in “compute_observations(self)”, the environment can be reset normally.
    ​self.racket_pos = self.rigid_body_states[:, self.racket_handle][:, 0:3]
Besides, if I use local variable , I can also reset the environment correctly.
However, with these method I can’t record the position of the balls and rackets.
I can’t say for sure because I don’t have an IssacGym environment right now, but do you need the code below? Does the sample look like that?
2021年12月15日(水) 22:23 780927810 via NVIDIA Developer Forums <nvidia@discoursemail.com>:
No, in isaac gym env, these functions I wrote are used by the vec_env class. I can’t explain its specific logic, but I sincerely suggest you refer to the issac gym env code library. It is so great and Inspires me a lot of coding skills
It’s hard to say from the snippets you posted. What values are you setting the position buffers to when you reset?
In the first part of the “compute_observations” function,
Missing “self.gym.refresh_rigid_body_state_tensor (self.sim)”.
It is absolutely necessary for headless mode.
With non-headless mode, it works for some reason without it.
Even if the non-headless mode is good, the headless mode may not work, so it is necessary to check if the two match.
In the function “reset_idx”, to reset the position of the ball and robot, I used the following functions :
However, I solved the problem with the following functions.
  self.gym.set_actor_root_state_tensor_indexed
  self.gym.set_dof_position_target_tensor_indexed
  self.gym.set_dof_state_tensor indexed
