The problem of using TX1 module can not be boot
Hello, everyone, I encountered some problems when I was using TX1 module, Carrier Board was designed by myself, the current phenomenon is as follows: After adding power, the power sequence and the TX1 module datasheet requirements are consistent, have been satisfied, and have already removed the peripheral PCIe equipment, but the module can not be boot, debugging serial port also no output, in addition to the time sequence, also need to pay attention to which key signals, will cause such a result, thank you.
Hi, can this module boot up with carrier board of dev kit? Did you check the strapping pin settings as said in OEM DG?
The problem has been solved. It’s the connector assembly and welding problem. Thank you.
