Hello!
I am trying to use the gpio pins to control something,but the voltage of all GPIO pins are about 1.4~1.5V, but not 3,3V.
How to set the voltage of all GPIO pins to 3,3V or 5V?
thanks.
hello neon-1004,
according to Jetson Xavier NX Developer Kit User Guide,
may I know which port you’re used, is it J12, 40-pin expansion header?
thanks
yes.it is the J12, 40-pin expansion header.According to <Jetson_Xavier_NX_Developer_Kit_User_Guide>,interface signal pins,all signals use 3.3V levels. so what is the problem the voltage of the GPIO pins are about 1.4~1.5V.
hello neon-1004,
here’s 40-pin header documentation, please check Jetson Download Center | NVIDIA Developer.
this application note also work with the signals on the 40-pin expansion header on Xavier NX.
thanks
hello neon-1004,
may I know what’s the approaches you’re used to measure the voltage,
FYI, GPIO is a logic output, and not intended for significant supply of current.
Hello JerryChang,I use multimeter to measur the GPOI voltage.I set the GPIO HIGH level voltage,sleep 2 seconds and then set it LOW level and sleep 2 seconds.The GPIO pin is not connected width any device except the multimeter.and we can see the voltage of the GPIO is jumping from 0v to 1.4~1.5v.
Please check the 40-pin header docs in DLC: https://developer.nvidia.com/jetson-nano-developer-kit-40-pin-expansion-header-gpio-usage-considerations-applications-note
There are load request when measure the voltage, please use a oscilloscope to measure output.
ok.thank you for your answers!
