hi, 目前我们自研板载使用SOM为T5000, software为JetPack7.1
在camera部分使用max96712通过CPHY连接到Thor的CSI,请问SDK bsp软件上是否支持CPHY?是否需要打补丁?
按照以往在Orin上的经验,JetPack5需要打补丁,JetPack6则不需要。
thanks
Yes, thor support CPHY but higher speed like > 2.5Gsps need NV support for signal tuning.
请问这个是如何获取支持呢? 是软件调优还是硬件调优?在JetPack下7.1上支持吗?
hi,请问下,我们现在使用的max96712,这部分有相应的CPHY Driver驱动demo源码吗?
I don’t have idea for max96712 need to config the PHY mode. But for the sensor you can just modify the phy_mode in device tree to config the Thor side.
Hi 1967760537,
I checked JetPack 7.x (Thor) BSP sources regarding C-PHY and MAX96712.
- C-PHY is supported in the stack (DT → NVCSI → VI).
phy_mode = "CPHY"is correctly parsed and propagated. - However, support is not fully complete end-to-end (some paths still assume D-PHY, and tuning/calibration is D-PHY-focused).
phy_modealone is not enough for a full working pipeline.
About MAX96712:
- There is only a minimal NVIDIA-specific driver (not a full media pipeline driver).
- No reference design found using MAX96712 + C-PHY (only D-PHY examples).
- GMSL framework in BSP is mainly for MAX9295/9296, not MAX96712.
As summary C-PHY works at framework level, but MAX96712 + C-PHY likely requires custom integration and possibly NVIDIA support, especially for high-speed tuning (>2.5Gsps).
I hope this helps!
Jose Morera
Embedded Software Engineer at RidgeRun
Contact us: support@ridgerun.com
Developers wiki: https://developer.ridgerun.com
Website: www.ridgerun.com
您好,请问cphy调通了吗?我们也遇到了类似的问题,也是96712接了cphy,目前看拉流拉不起来,15帧左右就卡了,重新拉还能拉,但还是10多帧,不知道为什么
