Please check and try the following patch, it may help.
drivers/i2c/busses/i2c-tegra.c | 34 +++++++++++++++++++++++++++++++++-
include/linux/i2c-tegra.h | 1 +
2 files changed, 34 insertions(+), 1 deletion(-)
diff --git a/drivers/i2c/busses/i2c-tegra.c b/drivers/i2c/busses/i2c-tegra.c
index dfa55c2..e9db3db 100644
--- a/drivers/i2c/busses/i2c-tegra.c
+++ b/drivers/i2c/busses/i2c-tegra.c
@@ -133,6 +133,9 @@
#define I2C_SLV_CONFIG_LOAD (1 << 1)
#define I2C_TIMEOUT_CONFIG_LOAD (1 << 2)
+#define I2C_CLKEN_OVERRIDE 0x090
+#define I2C_MST_CORE_CLKEN_OVR (1 << 0)
#define SL_ADDR1(addr) (addr & 0xff)
#define SL_ADDR2(addr) ((addr >> 8) & 0xff)
@@ -162,6 +165,7 @@ struct tegra_i2c_chipdata {
u16 clk_divisor_hs_mode;
int clk_multiplier_hs_mode;
bool has_config_load_reg;
+ bool has_clk_override_reg;
@@ -232,6 +236,7 @@ struct tegra_i2c_dev {
bool bit_banging_xfer_after_shutdown;
bool is_shutdown;
struct notifier_block pm_nb;
+ bool is_multimaster_mode;
static void dvc_writel(struct tegra_i2c_dev *i2c_dev, u32 val, unsigned long reg)
@@ -702,6 +707,9 @@ static int tegra_i2c_init(struct tegra_i2c_dev *i2c_dev)
if (tegra_i2c_flush_fifos(i2c_dev))
err = -ETIMEDOUT;
+ if (i2c_dev->is_multimaster_mode && i2c_dev->chipdata->has_clk_override_reg)
+ i2c_writel(i2c_dev, I2C_MST_CORE_CLKEN_OVR, I2C_CLKEN_OVERRIDE);
if (i2c_dev->chipdata->has_config_load_reg) {
i2c_writel(i2c_dev, I2C_MSTR_CONFIG_LOAD, I2C_CONFIG_LOAD);
while (i2c_readl(i2c_dev, I2C_CONFIG_LOAD) != 0) {
@@ -1364,6 +1372,12 @@ static struct tegra_i2c_platform_data *parse_i2c_tegra_dt(
pdata->sda_gpio = of_get_named_gpio(np, "sda-gpio", 0);
pdata->is_dvc = of_device_is_compatible(np, "nvidia,tegra20-i2c-dvc");
+ pdata->is_multimaster_mode = of_property_read_bool(np,
+ "nvidia,multimaster-mode");
+ if (pdata->is_multimaster_mode)
+ pdata->is_clkon_always = true;
/* Default configuration for device tree initiated driver */
pdata->slave_addr = 0xFC;
return pdata;
@@ -1380,6 +1394,7 @@ static struct tegra_i2c_chipdata tegra20_i2c_chipdata = {
.clk_divisor_hs_mode = 3,
.clk_multiplier_hs_mode = 12,
.has_config_load_reg = false,
+ .has_clk_override_reg = false,
static struct tegra_i2c_chipdata tegra30_i2c_chipdata = {
@@ -1393,6 +1408,7 @@ static struct tegra_i2c_chipdata tegra30_i2c_chipdata = {
static struct tegra_i2c_chipdata tegra114_i2c_chipdata = {
@@ -1407,6 +1423,7 @@ static struct tegra_i2c_chipdata tegra114_i2c_chipdata = {
.clk_divisor_hs_mode = 1,
.clk_multiplier_hs_mode = 3,
static struct tegra_i2c_chipdata tegra148_i2c_chipdata = {
@@ -1421,9 +1438,23 @@ static struct tegra_i2c_chipdata tegra148_i2c_chipdata = {
.clk_divisor_hs_mode = 2,
.clk_multiplier_hs_mode = 13,
.has_config_load_reg = true,
+ .has_clk_override_reg = true,
-#define tegra124_i2c_chipdata tegra148_i2c_chipdata
+static struct tegra_i2c_chipdata tegra124_i2c_chipdata = {
+ .timeout_irq_occurs_before_bus_inactive = false,
+ .has_xfer_complete_interrupt = true,
+ .has_continue_xfer_support = true,
+ .has_hw_arb_support = true,
+ .has_fast_clock = false,
+ .has_clk_divisor_std_fast_mode = true,
+ .clk_divisor_std_fast_mode = 0x19,
+ .clk_divisor_fast_plus_mode = 0x10,
+ .clk_divisor_hs_mode = 2,
+ .clk_multiplier_hs_mode = 13,
+ .has_config_load_reg = true,
/* Match table for of_platform binding */
static const struct of_device_id tegra_i2c_of_match[] = {
@@ -1584,6 +1615,7 @@ skip_pinctrl:
i2c_dev->cont_id = pdev->id;
i2c_dev->dev = &pdev->dev;
i2c_dev->is_clkon_always = pdata->is_clkon_always;
+ i2c_dev->is_multimaster_mode = pdata->is_multimaster_mode;
i2c_dev->bus_clk_rate = pdata->bus_clk_rate ? pdata->bus_clk_rate: 100000;
i2c_dev->is_high_speed_enable = pdata->is_high_speed_enable;
i2c_dev->clk_divisor_non_hs_mode =
diff --git a/include/linux/i2c-tegra.h b/include/linux/i2c-tegra.h
index ea40c64..9d1e869 100644
--- a/include/linux/i2c-tegra.h
+++ b/include/linux/i2c-tegra.h
@@ -33,6 +33,7 @@ struct tegra_i2c_platform_data {
u16 hs_master_code;
bool needs_cl_dvfs_clock;
struct tegra_i2c_slave_platform_data {
drivers/i2c/busses/i2c-tegra.c | 147 +++++++++++++++++++++++------------------
1 file changed, 83 insertions(+), 64 deletions(-)
index e9db3db..dda35db 100644
@@ -744,6 +744,32 @@ static int tegra_i2c_copy_next_to_current(struct tegra_i2c_dev *i2c_dev)
return 0;
+static int tegra_i2c_disable_packet_mode(struct tegra_i2c_dev *i2c_dev)
+ u32 cnfg;
+ unsigned long timeout;
+ cnfg = i2c_readl(i2c_dev, I2C_CNFG);
+ if (cnfg & I2C_CNFG_PACKET_MODE_EN)
+ i2c_writel(i2c_dev, cnfg & (~I2C_CNFG_PACKET_MODE_EN),
+ I2C_CNFG);
+ if (i2c_dev->chipdata->has_config_load_reg) {
+ i2c_writel(i2c_dev, I2C_MSTR_CONFIG_LOAD,
+ I2C_CONFIG_LOAD);
+ timeout = jiffies + msecs_to_jiffies(1000);
+ while (i2c_readl(i2c_dev, I2C_CONFIG_LOAD) != 0) {
+ if (time_after(jiffies, timeout)) {
+ dev_err(i2c_dev->dev,
+ "timeout config_load");
+ return -ETIMEDOUT;
+ udelay(2);
+ return 0;
static irqreturn_t tegra_i2c_isr(int irq, void *dev_id)
u32 status;
@@ -754,6 +780,7 @@ static irqreturn_t tegra_i2c_isr(int irq, void *dev_id)
struct tegra_i2c_dev *i2c_dev = dev_id;
u32 mask;
+ spin_lock_irqsave(&i2c_dev->fifo_lock, flags);
status = i2c_readl(i2c_dev, I2C_INT_STATUS);
if (status == 0) {
@@ -769,6 +796,7 @@ static irqreturn_t tegra_i2c_isr(int irq, void *dev_id)
if (unlikely(status & status_err)) {
+ tegra_i2c_disable_packet_mode(i2c_dev);
dev_dbg(i2c_dev->dev, "I2c error status 0x%08x\n", status);
if (status & I2C_INT_NO_ACK) {
i2c_dev->msg_err |= I2C_ERR_NO_ACK;
@@ -823,15 +851,8 @@ static irqreturn_t tegra_i2c_isr(int irq, void *dev_id)
if (!i2c_dev->msg_read && (status & I2C_INT_TX_FIFO_DATA_REQ)) {
- if (i2c_dev->msg_buf_remaining) {
- spin_lock_irqsave(&i2c_dev->fifo_lock, flags);
+ if (i2c_dev->msg_buf_remaining)
tegra_i2c_fill_tx_fifo(i2c_dev);
- spin_unlock_irqrestore(&i2c_dev->fifo_lock, flags);
else
tegra_i2c_mask_irq(i2c_dev, I2C_INT_TX_FIFO_DATA_REQ);
@@ -850,8 +871,7 @@ static irqreturn_t tegra_i2c_isr(int irq, void *dev_id)
complete(&i2c_dev->msg_complete);
- return IRQ_HANDLED;
+ goto done;
err:
dev_dbg(i2c_dev->dev, "reg: 0x%08x 0x%08x 0x%08x 0x%08x\n",
i2c_readl(i2c_dev, I2C_CNFG), i2c_readl(i2c_dev, I2C_STATUS),
@@ -901,6 +921,8 @@ err:
+done:
+ spin_unlock_irqrestore(&i2c_dev->fifo_lock, flags);
return IRQ_HANDLED;
@@ -949,6 +971,46 @@ static int tegra_i2c_send_next_read_msg_pkt_header(struct tegra_i2c_dev *i2c_dev
return 0;
+static int tegra_i2c_issue_bus_clear(struct tegra_i2c_dev *i2c_dev)
+ if (i2c_dev->chipdata->has_hw_arb_support) {
+ INIT_COMPLETION(i2c_dev->msg_complete);
+ i2c_writel(i2c_dev, I2C_BC_ENABLE
+ | I2C_BC_SCLK_THRESHOLD
+ | I2C_BC_STOP_COND
+ | I2C_BC_TERMINATE
+ , I2C_BUS_CLEAR_CNFG);
+ I2C_CONFIG_LOAD);
+ dev_warn(i2c_dev->dev,
+ msleep(1);
+ tegra_i2c_unmask_irq(i2c_dev, I2C_INT_BUS_CLEAR_DONE);
+ wait_for_completion_timeout(&i2c_dev->msg_complete,
+ TEGRA_I2C_TIMEOUT);
+ if (!(i2c_readl(i2c_dev, I2C_BUS_CLEAR_STATUS) & I2C_BC_STATUS))
+ dev_warn(i2c_dev->dev, "Un-recovered Arbitration lost\n");
+ } else {
+ i2c_algo_busclear_gpio(i2c_dev->dev,
+ i2c_dev->scl_gpio, GPIOF_OPEN_DRAIN,
+ i2c_dev->sda_gpio, GPIOF_OPEN_DRAIN,
+ MAX_BUSCLEAR_CLOCK, 100000);
+ return 0;
static int tegra_i2c_xfer_msg(struct tegra_i2c_dev *i2c_dev,
struct i2c_msg *msg, enum msg_end_type end_state,
struct i2c_msg *next_msg, enum msg_end_type next_msg_end_state)
@@ -991,6 +1053,9 @@ static int tegra_i2c_xfer_msg(struct tegra_i2c_dev *i2c_dev,
i2c_writel(i2c_dev, 0, I2C_INT_MASK);
+ int_mask = I2C_INT_NO_ACK | I2C_INT_ARBITRATION_LOST
+ | I2C_INT_TX_FIFO_OVERFLOW;
+ tegra_i2c_unmask_irq(i2c_dev, int_mask);
val = 7 << I2C_FIFO_CONTROL_TX_TRIG_SHIFT |
0 << I2C_FIFO_CONTROL_RX_TRIG_SHIFT;
@@ -1064,10 +1129,10 @@ static int tegra_i2c_xfer_msg(struct tegra_i2c_dev *i2c_dev,
i2c_dev->chipdata->has_xfer_complete_interrupt))
int_mask |= I2C_INT_ALL_PACKETS_XFER_COMPLETE;
dev_dbg(i2c_dev->dev, "unmasked irq: %02x\n",
i2c_readl(i2c_dev, I2C_INT_MASK));
@@ -1107,25 +1172,8 @@ static int tegra_i2c_xfer_msg(struct tegra_i2c_dev *i2c_dev,
if (i2c_dev->is_dvc)
dvc_i2c_mask_irq(i2c_dev, DVC_CTRL_REG3_I2C_DONE_INTR_EN);
- cnfg = i2c_readl(i2c_dev, I2C_CNFG);
- if (cnfg & I2C_CNFG_PACKET_MODE_EN)
- i2c_writel(i2c_dev, cnfg & (~I2C_CNFG_PACKET_MODE_EN),
- I2C_CNFG);
- else
- dev_err(i2c_dev->dev, "i2c_cnfg PACKET_MODE_EN not set\n");
- if (i2c_dev->chipdata->has_config_load_reg) {
- i2c_writel(i2c_dev, I2C_MSTR_CONFIG_LOAD,
- I2C_CONFIG_LOAD);
- while (i2c_readl(i2c_dev, I2C_CONFIG_LOAD) != 0) {
- if (time_after(jiffies, timeout)) {
- dev_warn(i2c_dev->dev,
- "timeout config_load");
- return -ETIMEDOUT;
- udelay(2);
+ if (likely(i2c_dev->msg_err == I2C_ERR_NONE))
if (ret == 0) {
@@ -1189,39 +1237,10 @@ static int tegra_i2c_xfer_msg(struct tegra_i2c_dev *i2c_dev,
/* Arbitration Lost occurs, Start recovery */
if (i2c_dev->msg_err == I2C_ERR_ARBITRATION_LOST) {
- if (i2c_dev->chipdata->has_hw_arb_support) {
- INIT_COMPLETION(i2c_dev->msg_complete);
- i2c_writel(i2c_dev, I2C_BC_ENABLE
- | I2C_BC_SCLK_THRESHOLD
- | I2C_BC_STOP_COND
- | I2C_BC_TERMINATE
- , I2C_BUS_CLEAR_CNFG);
- I2C_CONFIG_LOAD);
- msleep(1);
- tegra_i2c_unmask_irq(i2c_dev, I2C_INT_BUS_CLEAR_DONE);
- wait_for_completion_timeout(&i2c_dev->msg_complete,
- TEGRA_I2C_TIMEOUT);
- if (!(i2c_readl(i2c_dev, I2C_BUS_CLEAR_STATUS) & I2C_BC_STATUS))
- dev_warn(i2c_dev->dev, "Un-recovered Arbitration lost\n");
- } else {
- i2c_algo_busclear_gpio(i2c_dev->dev,
- i2c_dev->scl_gpio, GPIOF_OPEN_DRAIN,
- i2c_dev->sda_gpio,GPIOF_OPEN_DRAIN,
- MAX_BUSCLEAR_CLOCK, 100000);
+ if (!i2c_dev->is_multimaster_mode) {
+ ret = tegra_i2c_issue_bus_clear(i2c_dev);
+ if (ret)
+ return ret;
return -EAGAIN;
br
ChenJian
