Toolkit 3.1 Contents, Nsight, cutil32, cuda.rules, vs08
Hi All,
Is the toolkit 3.1 supposed to come with cuda.rules file, a cutil32.lib (and cutil32.dll) files?
If not, where can I get a cuda.rules file for visual studio 2008 and the cutil32.lib files. Where those replaced by something else in the 3.1 toolkit? (i’ve found some stuff, but I am looking for a file provided by NVIDIA).
Also, is that parallel Nsight program supposed to make it easy for me to create CUDA/C++ apps using visual studio? Would I have to worry about using setting proper paths, etc. (Cause i’ve tried and failed.)
Thanks a bunch. :D
Plese see your NVIDIA GPU Computing SDK folder. You can find it: Start - Programs - NVIDIA Corporation - NVIDIA GPU Computing SDK - Browse NVIDIA GPU Computing SDK.
cuda.rules: …\C\common
cutil32.lib, cutil32.dll: …\C\common\lib
If are no files there, please reinstall GPU Computing SDK. I have the files in 3.1 distributive.
The toolkit installed in C:\CUDA and there are bin, lib, etc folders there but not this. Would I also need to install the SDK to work with CUDA? I didn’t think I needed to.
The cutil files were developped for the SDK.
Similarly the cuda.rules file is used with the sdk examples.
None of these are required to compile/run cuda executables, but they make things easier. The cuda.rules that comes with the sdk file will most likely take care of all path problems.
