启动失败,需要重新刷系统
Jetson System firmware version 36.4.0-gcid-37537400 date 2024-09-13T04:02:39+00:
00
ESC to enter Setup.
F11 to enter Boot Manager Menu.
Enter to continue boot.
L4TLauncher: Attempting Direct Boot
EFI stub: Booting Linux Kernel…
EFI stub: Using DTB from configuration table
EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path
EFI stub: Exiting boot services…
鈊ebugfs initialized
銲/TC: Reserved shared memory is disabled
I/TC: Dynamic shared memory is enabled
I/TC: Normal World virtualization support is disabled
I/TC: Asynchronous notifications are disabled
醄 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]
[ 0.000000] Linux version 5.15.148-tegra (buildbrain@mobile-u64-5441-d8000) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2022.08) 11.3.0, GNU ld (GNU Binutils) 2.38) #1 SMP PREEMPT Thu Sep 12 21:01:54 PDT 2024 ()
[ 0.000000] Machine model: NVIDIA Jetson AGX Orin Developer Kit
[ 0.000000] efi: EFI v2.70 by EDK II
[ 0.000000] efi: RTPROP=0x1027f4f198 TPMFinalLog=0x1018b10000 SMBIOS=0xffff0000 SMBIOS 3.0=0x1027940000 MEMATTR=0x1021926018 ESRT=0x1021927f98 TPMEventLog=0x1018b28018 RNG=0x1015080018 MEMRESERVE=0x1018b2ac18
[ 0.000000] random: crng init done
[ 0.000000] secureboot: Secure boot disabled
[ 0.000000] esrt: Reserving ESRT space from 0x0000001021927f98 to 0x0000001021927fd0.
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000ff4000000, size 512 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] NUMA: No NUMA configuration found
[ 0.000000] NUMA: Faking a node at [mem 0x0000000080000000-0x0000001033ffffff]
[ 0.000000] NUMA: NODE_DATA [mem 0x1022d15800-0x1022d17fff]
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x0000001033ffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x00000000fffdffff]
[ 0.000000] node 0: [mem 0x00000000fffe0000-0x00000000ffffffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x000000101897ffff]
[ 0.000000] node 0: [mem 0x0000001018980000-0x0000001018b1ffff]
[ 0.000000] node 0: [mem 0x0000001018b20000-0x0000001018b2afff]
[ 0.000000] node 0: [mem 0x0000001018b2b000-0x0000001018b2bfff]
[ 0.000000] node 0: [mem 0x0000001018b2c000-0x000000102600ffff]
[ 0.000000] node 0: [mem 0x0000001026010000-0x0000001027f4ffff]
[ 0.000000] node 0: [mem 0x0000001027f50000-0x000000102c5fffff]
[ 0.000000] node 0: [mem 0x000000102c600000-0x000000102c7fffff]
[ 0.000000] node 0: [mem 0x000000102c800000-0x000000102cd6ffff]
[ 0.000000] node 0: [mem 0x000000102d700000-0x000000102d7fffff]
[ 0.000000] node 0: [mem 0x0000001032000000-0x0000001033ffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000001033ffffff]
[ 0.000000] On node 0, zone Normal: 2448 pages in unavailable ranges
[ 0.000000] On node 0, zone Normal: 18432 pages in unavailable ranges
[ 0.000000] On node 0, zone Normal: 16384 pages in unavailable ranges
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 29 pages/cpu s80408 r8192 d30184 u118784
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: Address authentication (architected algorithm)
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: Virtualization Host Extensions
[ 0.000000] CPU features: detected: Hardware dirty bit management
[ 0.000000] CPU features: detected: Spectre-v4
[ 0.000000] CPU features: detected: Spectre-BHB
[ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] alternatives: patching kernel code
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages7] mmcblk0boot1: mmc0:0001 DG4064 4.00 MiB
[ 3.677745] mmcblk0rpmb: mmc0:0001 DG4064 4.00 MiB, chardev (511:0)
[ 6.667079] tegra194-pcie 14100000.pcie: Adding to iommu group 4
[ 6.669886] tegra194-pcie 14100000.pcie: host bridge /bus@0/pcie@14100000 ranges:
[ 6.669906] tegra194-pcie 14100000.pcie: MEM 0x2080000000..0x20a7ffffff → 0x2080000000
[ 6.669912] tegra194-pcie 14100000.pcie: MEM 0x20a8000000..0x20afffffff → 0x0040000000
[ 6.669915] tegra194-pcie 14100000.pcie: IO 0x0030100000..0x00301fffff → 0x0030100000
[ 6.670392] tegra194-pcie 14100000.pcie: iATU unroll: enabled
[ 6.670395] tegra194-pcie 14100000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[ 6.747629] irq: IRQ237: trimming hierarchy from :bus@0:pmc@c360000
[ 6.776059] tegra194-pcie 14100000.pcie: Link up
[ 6.777692] tegra194-pcie 14100000.pcie: Link up
[ 6.777766] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00
[ 6.777770] pci_bus 0001:00: root bus resource [io 0x0000-0xfffff] (bus address [0x30100000-0x301fffff])
[ 6.777773] pci_bus 0001:00: root bus resource [mem 0x20a8000000-0x20afffffff] (bus address [0x40000000-0x47ffffff])
[ 6.777775] pci_bus 0001:00: root bus resource [bus 00-ff]
[ 6.777776] pci_bus 0001:00: root bus resource [mem 0x2080000000-0x20a7ffffff pref]
[ 6.777826] pci 0001:00:00.0: [10de:229e] type 01 class 0x060400
[ 6.777991] pci 0001:00:00.0: PME# supported from D0 D3hot
[ 6.781631] pci 0001:01:00.0: [10ec:c822] type 00 class 0x028000
[ 6.781802] pci 0001:01:00.0: reg 0x10: [io 0x0000-0x00ff]
[ 6.782001] pci 0001:01:00.0: reg 0x18: [mem 0x20a8000000-0x20a800ffff 64bit]
[ 6.783048] pci 0001:01:00.0: supports D1 D2
[ 6.783049] pci 0001:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 6.794991] pci 0001:00:00.0: BAR 14: assigned [mem 0x20a8000000-0x20a80fffff]
[ 6.794996] pci 0001:00:00.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 6.794999] pci 0001:01:00.0: BAR 2: assigned [mem 0x20a8000000-0x20a800ffff 64bit]
[ 6.795100] pci 0001:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 6.795130] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[ 6.795134] pci 0001:00:00.0: bridge window [io 0x1000-0x1fff]
[ 6.795137] pci 0001:00:00.0: bridge window [mem 0x20a8000000-0x20a80fffff]
[ 6.795240] pcieport 0001:00:00.0: Adding to iommu group 4
[ 6.795337] pcieport 0001:00:00.0: PME: Signaling with IRQ 200
[ 6.796013] pcieport 0001:00:00.0: AER: enabled with IRQ 200
[ 6.796934] tegra194-pcie 14160000.pcie: Adding to iommu group 5
[ 6.799894] tegra194-pcie 14160000.pcie: host bridge /bus@0/pcie@14160000 ranges:
[ 6.799920] tegra194-pcie 14160000.pcie: MEM 0x2140000000..0x2427ffffff → 0x2140000000
[ 6.799927] tegra194-pcie 14160000.pcie: MEM 0x2428000000..0x242fffffff → 0x0040000000
[ 6.799929] tegra194-pcie 14160000.pcie: IO 0x0036100000..0x00361fffff → 0x0036100000
[ 6.800443] tegra194-pcie 14160000.pcie: iATU unroll: enabled
[ 6.800447] tegra194-pcie 14160000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[ 6.908048] tegra194-pcie 14160000.pcie: Link up
[ 6.917963] tegra194-pcie 14160000.pcie: Link up
[ 6.918022] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[ 6.918027] pci_bus 0004:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x36100000-0x361fffff])
[ 6.918030] pci_bus 0004:00: root bus resource [mem 0x2428000000-0x242fffffff] (bus address [0x40000000-0x47ffffff])
[ 6.918033] pci_bus 0004:00: root bus resource [bus 00-ff]
[ 6.918035] pci_bus 0004:00: root bus resource [mem 0x2140000000-0x2427ffffff pref]
[ 6.918080] pci 0004:00:00.0: [10de:229c] type 01 class 0x060400
[ 6.918223] pci 0004:00:00.0: PME# supported from D0 D3hot
[ 6.921581] pci 0004:01:00.0: [15b7:5045] type 00 class 0x010802
[ 6.921759] pci 0004:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[ 6.934852] pci 0004:00:00.0: BAR 14: assigned [mem 0x2428000000-0x24280fffff]
[ 6.934858] pci 0004:01:00.0: BAR 0: assigned [mem 0x2428000000-0x2428003fff 64bit]
[ 6.934936] pciund
[ 7.600575] systemd[1]: /etc/systemd/system/nvs-service.service:41: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[ 7.603072] systemd[1]: /etc/systemd/system/nvargus-daemon.service:42: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[ 7.635342] systemd[1]: Queued start job for default target Graphical Interface.
[ 7.637223] systemd[1]: Created slice Slice /system/modprobe.
[ 7.663595] systemd[1]: Created slice Slice /system/serial-getty.
[ 7.672418] systemd[1]: Created slice Slice /system/systemd-fsck.
[ 7.673613] systemd[1]: Created slice User and Session Slice.
[ 7.674533] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 7.675622] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 7.699901] systemd[1]: Reached target Slice Units.
[ 7.717493] systemd[1]: Reached target Mounting snaps.
[ 7.718303] systemd[1]: Reached target Swaps.
[ 7.719103] systemd[1]: Reached target Local Verity Protected Volumes.
[ 7.726095] systemd[1]: Listening on RPCbind Server Activation Socket.
[ 7.747346] systemd[1]: Listening on Syslog Socket.
[ 7.754074] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 7.754970] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 7.755969] systemd[1]: Listening on Journal Audit Socket.
[ 7.779623] systemd[1]: Listening on Journal Socket (/dev/log).
[ 7.787833] systemd[1]: Listening on Journal Socket.
[ 7.795063] systemd[1]: Listening on udev Control Socket.
[ 7.795985] systemd[1]: Listening on udev Kernel Socket.
[ 7.810853] systemd[1]: Mounting Huge Pages File System…
[ 7.812789] systemd[1]: Mounting POSIX Message Queue File System…
[ 7.828169] systemd[1]: Mounting Kernel Debug File System…
[ 7.830060] systemd[1]: Mounting Kernel Trace File System…
[ 7.838483] systemd[1]: Starting Journal Service…
[ 7.854020] systemd[1]: Starting Set the console keyboard layout…
[ 7.855959] systemd[1]: Starting Create List of Static Device Nodes…
[ 7.873444] systemd[1]: Starting Load Kernel Module configfs…
[ 7.875304] systemd[1]: Starting Load Kernel Module drm…
[ 7.889957] systemd[1]: Starting Load Kernel Module efi_pstore…
[ 7.891754] systemd[1]: Starting Load Kernel Module fuse…
[ 7.900250] fuse: init (API version 7.34)
[ 7.907388] systemd[1]: Starting NVIDIA specific first-boot udev script…
[ 7.920812] systemd[1]: Started Nameserver information manager.
[ 7.921667] systemd[1]: Reached target Preparation for Network.
[ 7.922459] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 7.924316] systemd[1]: Starting Load Kernel Modules…
[ 7.930353] nvsciipc: loading out-of-tree module taints kernel.
[ 7.931580] nvsciipc: loaded module
[ 7.937977] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 7.938408] nvmap_co_device_init: vpr :dma coherent mem declare 0x0000001049800000,914358272
[ 7.938413] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[ 7.938425] nvmap_page_pool_init: Total RAM pages: 16087199
[ 7.938426] nvmap_page_pool_init: nvmap page pool size: 2010899 pages (3759 MB)
[ 7.938473] nvmap_background_zero_thread: PP zeroing thread starting.
[ 7.938488] nvmap_heap_create: created heap vpr base 0x0000001049800000 size (892928KiB)
[ 7.938514] nvmap_heap_create: fsi :dma coherent mem declare 0x000000102f000000,16777216
[ 7.938516] nvmap_heap_create: created heap fsi base 0x000000102f000000 size (16384KiB)
[ 7.953569] tegra-host1x 13e00000.host1x: Adding to iommu group 7
[ 7.954573] ho 7.954913] host1x-context host1x-ctx.3: Adding to iommu group 11
[ 7.955017] host1x-context host1x-ctx.4: Adding to iommuble
錞CU debug prints will be routed to traces.
醄 8.571165] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: ivc channel driver missing
[ 8.571168] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: ivc channel driver missing
[ 8.571169] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: ivc channel driver missing
[ 8.571170] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivc channel driver missing
[ 8.571171] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivc channel driver missing
[ 8.571173] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: ivc channel driver missing
[ 8.571178] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[ 8.571182] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[ 8.571188] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[ 8.571190] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[ 8.571192] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[ 8.571194] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[ 8.571204] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[ 8.571206] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[ 8.571209] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[ 8.776169] (NULL device *): fops function table already registered
[ 8.837679] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 8.838086] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 8.838295] cfg80211: Loaded X.509 cert ‘wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600’
鑃tarting RmBootstrap
Registered event_type:[0] for dce_core_ipc_type:[1]
Registered event_type:[1] for dce_core_ipc_type:[3]
dce_ipc State Initialized
RmBootstrap completed successfully
醄 11.413732] using random self ethernet address
[ 11.413738] using random host ethernet address
[ 11.545758] using random self ethernet address
[ 11.545764] using random host ethernet address
[ 15.732998] systemd-udevd[79]: Failed to move watches directory /run/udev/watch. Old watches will not be restored: Invalid cross-device link
[ 15.750172] systemd-udevd[79]: /etc/udev/rules.d/99-realsense-libusb.rules:81 Invalid value “/bin/sh -c ‘(major=uname -r | cut -d "." -f1 && minor=uname -r | cut -d "." -f2 && (([ $major -eq 4 ] && [ $minor -ge 15 ]) || [ $major -ge 5 ])) && (enamefile=/sys/%p/name && [ cat $enamefile = “accel_3d” ]) && enfile=/sys/%p/buffer/enable && echo “COUNTER=0; while [ $COUNTER -lt 20 ] && grep -q 0 $enfile; do sleep 0.01; COUNTER=$((COUNTER+1)); done && echo 0 > $enfile” | at now’” for RUN (char 188: invalid substitution type), ignoring, but please fix it.
Ubuntu 22.04.4 LTS nvidia-desktop ttyTCU0
nvidia-desktop login:
[ 16.916707] systemd-udevd[126]: console: Failed to process device, ignoring: File exists
Please remove all connected peripherals and restart your system before attempting to log in.
这台设备拆下来,除了SSD以外没有带外设情况下也是这个状态,重启依然如此,下图是我们挂在硬盘的方式
Sorry for the late response.
This device was removed, and apart from the SSD, no other peripherals were connected. After restarting, the problem persisted. The image below shows how we connected the hard drive.
Could you try logging in over SSH? It looks like the system finished booting successfully.
