Trusty image missing after updating on Last Jetpack
After updating on last Jetpack, my jetson TX1 development board stup booting.
What i may to do with it? For updating use my PC with Ubuntu 16.04 Eng version.
Maybe I may boot it from SD card?
I try to update it 10 times, but result is the same.
TX2 updating sucsesfuly all times from this Jetpack4.3 (of course i change platform on first 2-3 step in Jetpack updating program).
[0000.140] [TegraBoot] (version 00.00.2014.50-mobile-6987b70e)
[0000.146] Processing in cold boot mode Bootloader 2
[0000.150] A02 Bootrom Patch rev = 63
[0000.154] Power-up reason: on button
[0000.157] No Battery Present
[0000.160] RamCode = 0
[0000.162] Platform has Ddr4 type ram
[0000.165] max77620 disabling SD1 Remote Sense
[0000.170] Setting Ddr voltage to 1125mv
[0000.174] Serial Number of Pmic Max77663: 0x2405f6
[0000.181] Entering ramdump check
[0000.184] Get RamDumpCarveOut = 0x0
[0000.187] RamDumpCarveOut=0x0,  RamDumperFlag=0xe59ff3f8
[0000.193] Last reboot was clean, booting normally!
[0000.197] Sdram initialization is successful
[0000.201] SecureOs Carveout Base=0xff800000 Size=0x00800000
[0000.207] GSC1 Carveout Base=0xff700000 Size=0x00100000
[0000.212] GSC2 Carveout Base=0xff600000 Size=0x00100000
[0000.217] GSC3 Carveout Base=0xff500000 Size=0x00100000
[0000.222] GSC4 Carveout Base=0xff400000 Size=0x00100000
[0000.227] GSC5 Carveout Base=0xff300000 Size=0x00100000
[0000.232] BpmpFw Carveout Base=0xff2c0000 Size=0x00040000
[0000.238] Lp0 Carveout Base=0xff2bf000 Size=0x00001000
[0000.253] RamDump Carveout Base=0xff23f000 Size=0x00080000
[0000.258] Platform-DebugCarveout: 0
[0000.262] Nck Carveout Base=0xff03f000 Size=0x00200000
[0000.267] Non secure mode, and RB not enabled.
[0000.307] Using GPT Primary to query partitions
[0000.312] Loading Tboot-CPU binary
[0000.361] Verifying TBC in OdmNonSecureSBK mode
[0000.370] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.377] Bootloader downloaded successfully.
[0000.381] Downloaded Tboot-CPU binary to 0xa0000258
[0000.387] MAX77620_GPIO1 Configured.
[0000.390] MAX77620_GPIO5 Configured.
[0000.393] CPU power rail is up
[0000.396] CPU clock enabled
[0000.400] Performing RAM repair
[0000.403] Updating A64 Warmreset Address to 0xa00002e9
[0000.408] Loading NvTbootBootloaderDTB
[0000.503] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0000.633] Bootloader DTB Load Address: 0x83000000
[0000.638] Loading NvTbootKernelDTB
[0000.732] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0000.862] Kernel DTB Load Address: 0x83100000
[0000.867] Loading cboot binary
[0000.961] Verifying EBT in OdmNonSecureSBK mode
[0000.997] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0001.004] Bootloader downloaded successfully.
[0001.008] GPT: Partition NOT found !
[0001.012] Find Partition via GPT Failed
[0001.015] Find Partition via PT Failed
[0001.019] function NvTbootGetBinaryOffsets: 0x1 error
[0001.024] Error in NvTbootLoadBinary: 0x1 !
[0001.028] Next binary entry address: 0x92c00258
[0001.032] BoardId: 2180
[0001.037] dram memory type is 3
[0001.041] WB0 init successful
[0001.067] Bpmp FW successfully loaded
[0001.070] Set NvDecSticky Bits
[0001.074] GSC1 address : ff700000
[0001.077] GSC2 address ff63fffc value c0edbbcc
[0001.082] GSC2 address : ff600000
[0001.086] GSC3 address : ff500000
[0001.089] GSC4 address : ff400000
[0001.093] GSC5 address : ff300000
[0001.096] GSC MC Settings done
[0001.100] TOS plaintext Image length 32848
[0001.104]  Monitor size 32848
[0001.106]  OS size 0
[0001.110] *** Secure OS image signature not verified ***
[0001.115] Loading and Validation of Secure OS Successful
[0001.120] NvTbootPackSdramParams: start.
[0001.125] NvTbootPackSdramParams: done.
[0001.129] Tegraboot started after 119218 us
[0001.133] Basic modules init took 946335 us
[0001.137] Sec Bootdevice Read Time = 355 ms, Read Size = 15771 KB
[0001.143] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0001.148] Next stage binary read took 732 us
[0001.152] Carveout took -6645 us
[0001.155] CPU initialization took 96707 us
[0001.159] Total time taken by TegraBoot 1037129 us
[0001.164] Starting CPU & Halting co-processor
64NOTICE:  BL31: v1.2(release):e1e4477
NOTICE:  BL31: Built : 20:39:55, Mar  1 2018
NOTICE:  Trusty image missing.
ERROR:   Error initializing runtime service trusty_fast
[0001.305] RamCode = 0
[0001.326] LPDDR4 Training: Read DT: Number of tables = 10
[0001.331] EMC Training (SRC-freq: 204000; DST-freq: 408000)
[0001.337] EMC Training Successful
[0001.340] EMC Training (SRC-freq: 204000; DST-freq: 665600)
[0001.346] EMC Training Successful
[0001.349] EMC Training (SRC-freq: 204000; DST-freq: 800000)
[0001.361] EMC Training Successful
[0001.364] EMC Training (SRC-freq: 204000; DST-freq: 1065600)
[0001.387] EMC Training Successful
[0001.390] EMC Training (SRC-freq: 204000; DST-freq: 1331200)
[0001.411] EMC Training Successful
[0001.414] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0001.434] EMC Training Successful
[0001.437] Switching to 800000 KHz Success
[0001.447] RamCode = 0
[0001.451] DT Write: emc-table@40800 succeeded
[0001.457] DT Write: emc-table@68000 succeeded
[0001.463] DT Write: emc-table@102000 succeeded
[0001.469] DT Write: emc-table@204000 succeeded
[0001.475] DT Write: emc-table@408000 succeeded
[0001.481] DT Write: emc-table@665600 succeeded
[0001.487] DT Write: emc-table@800000 succeeded
[0001.493] DT Write: emc-table@1065600 succeeded
[0001.499] DT Write: emc-table@1331200 succeeded
[0001.506] DT Write: emc-table@1600000 succeeded
[0001.510] LPDDR4 Training: Write DT: Number of tables = 10
It isn’t even reaching U-Boot. Is this the development kit carrier board?
You might try to flash on command line and log that flash (which you can post here…if you hover your mouse over the quote icon in an existing post, then a paper clip icon should show up for attaching files). To flash on command line, with the Jetson in recovery mode and the micro-B USB cable connected, the follow flashes and logs (the extra is for logging without enormous progress bar content):
sudo ./flash.sh jetson-tx1 mmcblk0p1 2>&1 | gawk '{gsub("[0-9][0-9]+[/][0-9[0-9]+ bytes sent..",".");print}' | tee log.txt
Also, from your flash software directory, how much space does the host PC have?
df -H -T /where/ever/you/flash/from/Linux_for_Tegra/
Sorry, I don’t understand in what moment I need to add this comand in terminal.
The previous post with the “flash.sh” command is used to manually flash from command line. Keep in mind that some of the content would be installed and set up correctly already if you installed the SDK Manager/JetPack and had attempted to flash once (SDKM/JetPack is a front end for the other flash software).
After the host PC has the “Linux_for_Tegra/” directory, and after the Jetson is connected to the host PC via the micro-B USB with the Jetson being in recovery mode, this is when you run the “sudo ./flash.sh …” command.
Note that I added a method to create a log of the flash.sh command results. That log would be useful.
Also note that if your PC sees the Jetson with command “lsusb -d 0955:7721”, then the Jetson is available for flash and is in recovery mode. If “lsusb -d 0955:7721” does not show anything, then either the Jetson is not in recovery mode or there is a USB error.
I may add Log file from SDK manager. Because I can not download old version of Jetpack. In new version of Jetpack I may upgrade only Xavier.
indent preformatted text by 4 spaces
15:48:27 INFO : null
15:48:32 INFO : Drivers for Jetson TX1/Nano : start to download https://developer.download.nvidia.com/devzone/devcenter/mobile/jetpack_l4t/JETPACK_423_b6/P3448-0000/Jetson-210_Linux_R32.2.3_aarch64.tbz2 to /home/markusboil/Downloads/nvidia/sdkm_downloads/Jetson-210_Linux_R32.2.3_aarch64.tbz2
15:48:32 INFO : File System and OS : start to download https://developer.download.nvidia.com/devzone/devcenter/mobile/jetpack_l4t/JETPACK_423_b6/P3448-0000/Tegra_Linux_Sample-Root-Filesystem_R32.2.3_aarch64.tbz2 to /home/markusboil/Downloads/nvidia/sdkm_downloads/Tegra_Linux_Sample-Root-Filesystem_R32.2.3_aarch64.tbz2
15:49:14 INFO : Drivers for Jetson TX1/Nano : verifying checksum of /home/markusboil/Downloads/nvidia/sdkm_downloads/Jetson-210_Linux_R32.2.3_aarch64.tbz2
15:49:15 INFO : Drivers for Jetson TX1/Nano : download /home/markusboil/Downloads/nvidia/sdkm_downloads/Jetson-210_Linux_R32.2.3_aarch64.tbz2 successfully, checksum is correct
15:49:15 INFO : Drivers for Jetson TX1/Nano : Download ‘Drivers for Jetson TX1/Nano’ success
15:49:15 INFO : Drivers for Jetson TX1/Nano : Start to install ‘Drivers for Jetson TX1/Nano’
15:49:16 DEBUG : Drivers for Jetson TX1/Nano : running command < cd ‘/home/markusboil/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_P2180’ ; ‘/opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter’ -a=‘install’ -c=‘eyJpZCI6Ik5WX0w0VF9EUklWRVJTX05BTk9fVFgxX0NPTVAiLCJuYW1lIjoiRHJpdmVycyBmb3IgSmV0c29uIFRYMS9OYW5vIiwiZGVzY3JpcHRpb24iOiJOVklESUEgVGVncmEgTGludXggRHJpdmVyIFBhY2thZ2UiLCJjb21wVHlwZSI6InRhcmdldF9pbWFnZSIsImlzVmlzaWJsZSI6dHJ1ZSwibGljZW5zZUlkIjoiTlZfSkVUUEFDS19PU19FVUxBIiwiaXNEZXRlY3RhYmxlSW5zdGFsbCI6ZmFsc2UsImlzSW5zdGFsbFBhdGhDdXN0b21pemFibGUiOnRydWUsInZlcnNpb24iOiIzMi4yLjMiLCJvcGVyYXRpbmdTeXN0ZW1zIjpbInVidW50dTE2MDQiLCJ1YnVudHUxODA0Il0sImluc3RhbGxTaXplTUIiOjM1NiwiZG93bmxvYWRGaWxlcyI6W3sidXJsIjoiUDM0NDgtMDAwMC9KZXRzb24tMjEwX0xpbnV4X1IzMi4yLjNfYWFyY2g2NC50YnoyIiwiZmlsZU5hbWUiOiJKZXRzb24tMjEwX0xpbnV4X1IzMi4yLjNfYWFyY2g2NC50YnoyIiwic2l6ZSI6MTk3MDkwODY0LCJjaGVja3N1bSI6ImE0YTYyODQ3ZjYwYWVkYmJjMzMxYTFjNThhZjFhYjFlIiwiY2hlY2tzdW1UeXBlIjoibWQ1IiwiaW5zdGFsbFBhcmFtZXRlcnMiOnsiaW5zdGFsbFR5cGUiOiJjbWQiLCJhZGRpdGlvbmFsUGFyYW1ldGVycyI6eyJpbnN0YWxsRGlyIjoie3tUQVJHRVRfUk9PVH19L3t7QlVORExFX1RJVExFfX1fe3tCT0FSRF9JRH19IiwicHJlaW5zdGFsbENvbW1hbmRzIjpbeyJ1c2VyQ29tbWFuZCI6InN1ZG8gcm0gLXJmIHt7VEFSR0VUX1JPT1R9fS97e0JVTkRMRV9USVRMRX19X3t7Qk9BUkRfSUR9fS9MaW51eF9mb3JfVGVncmEvIn1dLCJpbnN0YWxsQ29tbWFuZHMiOlt7ImV4ZWNCYXNoIjpbInN1ZG8gYXB0LWdldCB1cGRhdGUgfHwgdHJ1ZSIsInNhZmVfYXB0X2luc3RhbGwgXCJzdWRvIGFwdC1nZXQgaW5zdGFsbCAteSBwaWd6IGxiemlwMlwiIDUiLCJ0YXIgeHBmIHt7RklMRV9QQVRIfX0iXX1dfX0sImNhY2hlZFVybCI6Imh0dHBzOi8vZGV2ZWxvcGVyLmRvd25sb2FkLm52aWRpYS5jb20vZGV2em9uZS9kZXZjZW50ZXIvbW9iaWxlL2pldHBhY2tfbDR0L0pFVFBBQ0tfNDIzX2I2L1AzNDQ4LTAwMDAvSmV0c29uLTIxMF9MaW51eF9SMzIuMi4zX2FhcmNoNjQudGJ6MiIsImN1cnJlbnREb3dubG9hZGVkVXJsIjoiaHR0cHM6Ly9kZXZlbG9wZXIuZG93bmxvYWQubnZpZGlhLmNvbS9kZXZ6b25lL2RldmNlbnRlci9tb2JpbGUvamV0cGFja19sNHQvSkVUUEFDS180MjNfYjYvUDM0NDgtMDAwMC9KZXRzb24tMjEwX0xpbnV4X1IzMi4yLjNfYWFyY2g2NC50YnoyIn1dLCJ0YXJnZXRJZHMiOlsiUDM0NDgtMDAwMCIsIlAzNDQ4LTAwMjAiLCJQMjE4MCJdLCJkZXBlbmRlbmNpZXMiOltdLCJleHRlcm5hbF9kZXBlbmRlbmNpZXMiOltdLCJ0YXJnZXRJRCI6IlAyMTgwIiwiX2lkIjoiTlZfTDRUX0RSSVZFUlNfTkFOT19UWDFfQ09NUEBQMjE4MCIsInBhcmVudElEIjoiTlZfSkVUUEFDS19MNFRfSU1BR0VfU0VUVVBfVEFSR0VUX0dST1VQIiwiX3BhcmVudElEIjoiTlZfSkVUUEFDS19MNFRfSU1BR0VfU0VUVVBfVEFSR0VUX0dST1VQQFAyMTgwIiwiaW5zdGFsbFN0YXR1cyI6Im5vbmUiLCJhY3Rpb24iOjEsImRvd25sb2FkRXJyb3JzIjpbXSwiZmlyc3REb3dubG9hZEZpbGUiOiIvaG9tZS9tYXJrdXNib2lsL0Rvd25sb2Fkcy9udmlkaWEvc2RrbV9kb3dubG9hZHMvSmV0c29uLTIxMF9MaW51eF9SMzIuMi4zX2FhcmNoNjQudGJ6MiIsImJ1bmRsZVRpdGxlIjoiSmV0UGFja180LjIuM19MaW51eF9HQSIsImluc3RhbGxQYXRoIjoiL2hvbWUvbWFya3VzYm9pbC9udmlkaWEvbnZpZGlhX3Nkay9KZXRQYWNrXzQuMi4zX0xpbnV4X0dBX1AyMTgwIiwiaW5zdGFsbFJvb3QiOiIvaG9tZS9tYXJrdXNib2lsL252aWRpYS9udmlkaWFfc2RrIiwiYm9hcmRJRCI6IlAyMTgwIiwidGFyZ2V0QWNjZXNzSW5mbyI6eyJ1c2VyIjoiIiwicGFzc3dvcmQiOiIiLCJob3N0IjoiMTkyLjE2OC41NS4xIiwicG9ydCI6IjIyIn0sImlzRHJ5UnVuIjpmYWxzZX0=’ -i=‘NV_L4T_DRIVERS_NANO_TX1_COMP’ -v=‘32.2.3’ -l=‘/home/markusboil/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_P2180’ -L=‘/home/markusboil/.nvsdkm/logs/JetPack_4.2.3_Linux_GA’ -p=‘2755’ -t=‘P2180’ -e=‘/home/markusboil/Downloads/nvidia/sdkm_downloads/Jetson-210_Linux_R32.2.3_aarch64.tbz2’ >
15:49:16 INFO : Drivers for Jetson TX1/Nano : [ Disk Avail:129.27 GB ]
15:49:16 INFO : Drivers for Jetson TX1/Nano : Using GenericInstaller to Install NV_L4T_DRIVERS_NANO_TX1_COMP
15:49:16 INFO : Drivers for Jetson TX1/Nano : NV_L4T_DRIVERS_NANO_TX1_COMP include 1 package
15:49:16 INFO : Drivers for Jetson TX1/Nano : change working directory to /home/markusboil/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_P2180
15:49:16 INFO : Drivers for Jetson TX1/Nano : [ Package PreInstall Started ]
15:49:16 INFO : Drivers for Jetson TX1/Nano : current working directory is /home/markusboil/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_P2180
15:49:16 INFO : Drivers for Jetson TX1/Nano : exec_command: sudo rm -rf /home/markusboil/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_P2180/Linux_for_Tegra/
15:49:16 INFO : Drivers for Jetson TX1/Nano : [host] [sudo] password for markusboil:
15:49:16 INFO : Drivers for Jetson TX1/Nano : [ Package PreInstall Finished Successfully ]
15:49:16 INFO : Drivers for Jetson TX1/Nano : [ Package Install Started ]
15:49:16 INFO : Drivers for Jetson TX1/Nano : exec_command [host]:
15:49:16 INFO : Drivers for Jetson TX1/Nano : **********************
15:49:16 INFO : Drivers for Jetson TX1/Nano : #!/bin/bash
15:49:16 INFO : Drivers for Jetson TX1/Nano : set -e
15:49:16 INFO : Drivers for Jetson TX1/Nano : function safe_apt_install {
15:49:16 INFO : Drivers for Jetson TX1/Nano : echo “*begin $1, $2”
15:49:16 INFO : Drivers for Jetson TX1/Nano : tmp_log=/tmp/jetpack_dpkg_log.txt
15:49:16 INFO : Drivers for Jetson TX1/Nano : sudo rm -f $tmp_log
15:49:16 INFO : Drivers for Jetson TX1/Nano : set +e; $1 2>&1 | tee $tmp_log; CMD_STATUS=${PIPESTATUS[0]}; set -e
15:49:16 INFO : Drivers for Jetson TX1/Nano : while [ ${CMD_STATUS} -ne 0 ]; do
15:49:16 INFO : Drivers for Jetson TX1/Nano : if grep -q -e “is locked by another process” -e “E: Could not get lock /var/lib” $tmp_log; then
15:49:16 INFO : Drivers for Jetson TX1/Nano : echo “Waiting $2 seconds for apt to be available”; sleep ${2}
15:49:16 INFO : Drivers for Jetson TX1/Nano : else
15:49:16 INFO : Drivers for Jetson TX1/Nano : echo “Unhandled error when running $1”; exit 1
15:49:16 INFO : Drivers for Jetson TX1/Nano : fi
15:49:16 INFO : Drivers for Jetson TX1/Nano : done
15:49:16 INFO : Drivers for Jetson TX1/Nano : }
15:49:16 INFO : Drivers for Jetson TX1/Nano : sudo apt-get update || true
15:49:16 INFO : Drivers for Jetson TX1/Nano : safe_apt_install “sudo apt-get install -y pigz lbzip2” 5
15:49:16 INFO : Drivers for Jetson TX1/Nano : tar xpf /home/markusboil/Downloads/nvidia/sdkm_downloads/Jetson-210_Linux_R32.2.3_aarch64.tbz2
15:49:16 INFO : Drivers for Jetson TX1/Nano : exec_command: /tmp/tmp_NV_L4T_DRIVERS_NANO_TX1_COMP.sh
15:49:16 INFO : Drivers for Jetson TX1/Nano : Get:1 Index of /ubuntu bionic-security InRelease [88.7 kB]
15:49:17 INFO : Drivers for Jetson TX1/Nano : Hit:2 Index of /ubuntu bionic InRelease
15:49:17 INFO : Drivers for Jetson TX1/Nano : Get:3 Index of /ubuntu bionic-updates InRelease [88.7 kB]
15:49:17 INFO : Drivers for Jetson TX1/Nano : Get:4 Index of /ubuntu bionic-backports InRelease [74.6 kB]
15:49:18 INFO : Drivers for Jetson TX1/Nano : Get:5 Index of /ubuntu bionic-security/main amd64 DEP-11 Metadata [38.5 kB]
15:49:19 INFO : Drivers for Jetson TX1/Nano : Get:6 Index of /ubuntu bionic-security/main DEP-11 48x48 Icons [17.6 kB]
15:49:19 INFO : Drivers for Jetson TX1/Nano : Get:7 Index of /ubuntu bionic-updates/main amd64 DEP-11 Metadata [307 kB]
15:49:19 INFO : Drivers for Jetson TX1/Nano : Get:8 Index of /ubuntu bionic-security/main DEP-11 64x64 Icons [41.5 kB]
15:49:19 INFO : Drivers for Jetson TX1/Nano : Get:9 Index of /ubuntu bionic-security/universe amd64 DEP-11 Metadata [42.1 kB]
15:49:19 INFO : Drivers for Jetson TX1/Nano : Get:10 Index of /ubuntu bionic-security/universe DEP-11 48x48 Icons [16.4 kB]
15:49:19 INFO : Drivers for Jetson TX1/Nano : Get:11 Index of /ubuntu bionic-security/universe DEP-11 64x64 Icons [108 kB]
15:49:19 INFO : Drivers for Jetson TX1/Nano : Get:12 Index of /ubuntu bionic-security/multiverse amd64 DEP-11 Metadata [2,464 B]
15:49:19 INFO : Drivers for Jetson TX1/Nano : Get:13 Index of /ubuntu bionic-updates/main DEP-11 48x48 Icons [73.8 kB]
15:49:19 INFO : Drivers for Jetson TX1/Nano : Get:14 Index of /ubuntu bionic-updates/main DEP-11 64x64 Icons [140 kB]
15:49:19 INFO : Drivers for Jetson TX1/Nano : Get:15 Index of /ubuntu bionic-updates/universe amd64 DEP-11 Metadata [273 kB]
15:49:19 INFO : Drivers for Jetson TX1/Nano : Get:16 Index of /ubuntu bionic-updates/universe DEP-11 48x48 Icons [199 kB]
15:49:20 INFO : Drivers for Jetson TX1/Nano : Get:17 Index of /ubuntu bionic-updates/universe DEP-11 64x64 Icons [481 kB]
15:49:20 INFO : Drivers for Jetson TX1/Nano : Get:18 Index of /ubuntu bionic-updates/multiverse amd64 DEP-11 Metadata [2,464 B]
15:49:20 INFO : Drivers for Jetson TX1/Nano : Get:19 Index of /ubuntu bionic-backports/universe amd64 DEP-11 Metadata [7,976 B]
15:49:28 INFO : Drivers for Jetson TX1/Nano : Fetched 2,003 kB in 4s (524 kB/s)
15:49:48 INFO : Drivers for Jetson TX1/Nano : Reading package lists…
15:49:48 INFO : Drivers for Jetson TX1/Nano : *begin sudo apt-get install -y pigz lbzip2, 5
15:49:50 INFO : Drivers for Jetson TX1/Nano : Reading package lists…
15:49:51 INFO : Drivers for Jetson TX1/Nano : Building dependency tree…
15:49:51 INFO : Drivers for Jetson TX1/Nano : Reading state information…
15:49:52 INFO : Drivers for Jetson TX1/Nano : The following packages were automatically installed and are no longer required:
15:49:52 INFO : Drivers for Jetson TX1/Nano : efibootmgr gir1.2-geocodeglib-1.0 libfwup1 libllvm8 libwayland-egl1-mesa
15:49:52 INFO : Drivers for Jetson TX1/Nano : ubuntu-web-launchers
15:49:52 INFO : Drivers for Jetson TX1/Nano : Use ‘sudo apt autoremove’ to remove them.
15:49:52 INFO : Drivers for Jetson TX1/Nano : The following NEW packages will be installed:
15:49:52 INFO : Drivers for Jetson TX1/Nano : lbzip2 pigz
15:49:53 INFO : Drivers for Jetson TX1/Nano : 0 upgraded, 2 newly installed, 0 to remove and 6 not upgraded.
15:49:53 INFO : Drivers for Jetson TX1/Nano : Need to get 121 kB of archives.
15:49:53 INFO : Drivers for Jetson TX1/Nano : After this operation, 422 kB of additional disk space will be used.
15:49:53 INFO : Drivers for Jetson TX1/Nano : Get:1 Index of /ubuntu bionic/universe amd64 pigz amd64 2.4-1 [57.4 kB]
15:49:54 INFO : Drivers for Jetson TX1/Nano : Get:2 Index of /ubuntu bionic/universe amd64 lbzip2 amd64 2.5-2 [63.7 kB]
15:49:58 INFO : Drivers for Jetson TX1/Nano : Fetched 121 kB in 1s (97.6 kB/s)
15:49:58 INFO : Drivers for Jetson TX1/Nano : Selecting previously unselected package pigz.
15:50:01 INFO : Drivers for Jetson TX1/Nano : (Reading database … (Reading database … 5% (Reading database … 10% (Reading database … 15% (Reading database … 20% (Reading database … 25% (Reading database … 30% (Reading database … 35% (Reading database … 40% (Reading database … 45% (Reading database … 50% (Reading database … 55% (Reading database … 60% (Reading database … 65% (Reading database … 70% (Reading database … 75% (Reading database … 80% (Reading database … 85% (Reading database … 90% (Reading database … 95% (Reading database … 100% (Reading database … 175219 files and directories currently installed.)
15:50:01 INFO : Drivers for Jetson TX1/Nano : Preparing to unpack …/archives/pigz_2.4-1_amd64.deb …
15:50:01 INFO : Drivers for Jetson TX1/Nano : Unpacking pigz (2.4-1) …
15:50:01 INFO : Drivers for Jetson TX1/Nano : Selecting previously unselected package lbzip2.
15:50:01 INFO : Drivers for Jetson TX1/Nano : Preparing to unpack …/lbzip2_2.5-2_amd64.deb …
15:50:01 INFO : Drivers for Jetson TX1/Nano : Unpacking lbzip2 (2.5-2) …
15:50:02 INFO : Drivers for Jetson TX1/Nano : Setting up lbzip2 (2.5-2) …
15:50:02 INFO : Drivers for Jetson TX1/Nano : Setting up pigz (2.4-1) …
15:50:02 INFO : Drivers for Jetson TX1/Nano : Processing triggers for man-db (2.8.3-2ubuntu0.1) …
15:50:44 INFO : File System and OS : verifying checksum of /home/markusboil/Downloads/nvidia/sdkm_downloads/Tegra_Linux_Sample-Root-Filesystem_R32.2.3_aarch64.tbz2
15:51:09 INFO : Drivers for Jetson TX1/Nano : [ Package Install Finished Successfully ]
15:51:09 INFO : Drivers for Jetson TX1/Nano : [ 1.12 GB used. Disk Avail: 128.15 GB ]
15:51:09 INFO : Drivers for Jetson TX1/Nano : [ NV_L4T_DRIVERS_NANO_TX1_COMP Install took 1m54s ]
15:51:09 INFO : Drivers for Jetson TX1/Nano : command finished successfully
15:51:09 INFO : Drivers for Jetson TX1/Nano : install ‘Drivers for Jetson TX1/Nano’ success
15:51:22 INFO : File System and OS : download /home/markusboil/Downloads/nvidia/sdkm_downloads/Tegra_Linux_Sample-Root-Filesystem_R32.2.3_aarch64.tbz2 successfully, checksum is correct
15:51:22 INFO : File System and OS : Download ‘File System and OS’ success
15:51:23 INFO : File System and OS : Start to install ‘File System and OS’
15:51:23 DEBUG : File System and OS : running command < cd ‘/home/markusboil/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_P2180’ ; ‘/opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter’ -a=‘install’ -c=‘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’ -i=‘NV_L4T_FILE_SYSTEM_AND_OS_NANO_TX1_COMP’ -v=‘32.2.3’ -l=‘/home/markusboil/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_P2180’ -L=‘/home/markusboil/.nvsdkm/logs/JetPack_4.2.3_Linux_GA’ -p=‘2755’ -t=‘P2180’ -e=‘/home/markusboil/Downloads/nvidia/sdkm_downloads/Tegra_Linux_Sample-Root-Filesystem_R32.2.3_aarch64.tbz2’ >
15:51:24 INFO : File System and OS : [ Disk Avail:128.15 GB ]
15:51:24 INFO : File System and OS : Using GenericInstaller to Install NV_L4T_FILE_SYSTEM_AND_OS_NANO_TX1_COMP
15:51:24 INFO : File System and OS : NV_L4T_FILE_SYSTEM_AND_OS_NANO_TX1_COMP include 1 package
15:51:24 INFO : File System and OS : change working directory to /home/markusboil/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_P2180/Linux_for_Tegra/rootfs/
15:51:24 INFO : File System and OS : [ Package Install Started ]
15:51:24 INFO : File System and OS : current working directory is /home/markusboil/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_P2180/Linux_for_Tegra/rootfs
15:51:24 INFO : File System and OS : exec_command [host]:
15:51:24 INFO : File System and OS : **********************
15:51:24 INFO : File System and OS : #!/bin/bash
15:51:24 INFO : File System and OS : set -e
15:51:24 INFO : File System and OS : sudo tar xpf /home/markusboil/Downloads/nvidia/sdkm_downloads/Tegra_Linux_Sample-Root-Filesystem_R32.2.3_aarch64.tbz2
15:51:24 INFO : File System and OS : cd …
15:51:24 INFO : File System and OS : sudo ./apply_binaries.sh
15:51:24 INFO : File System and OS : sudo mkdir -p rootfs/opt/nvidia/deb_repos
15:51:24 INFO : File System and OS : exec_command: /tmp/tmp_NV_L4T_FILE_SYSTEM_AND_OS_NANO_TX1_COMP.sh
15:58:03 INFO : File System and OS : Using rootfs directory of: /home/markusboil/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_P2180/Linux_for_Tegra/rootfs
15:58:03 INFO : File System and OS : Extracting the NVIDIA user space components to /home/markusboil/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_P2180/Linux_for_Tegra/rootfs
15:58:09 INFO : File System and OS : Creating t210 gm20b symbolic links…
15:58:09 INFO : File System and OS : Extracting the BSP test tools to /home/markusboil/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_P2180/Linux_for_Tegra/rootfs
15:58:09 INFO : File System and OS : Extracting the NVIDIA gst test applications to /home/markusboil/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_P2180/Linux_for_Tegra/rootfs
15:58:10 INFO : File System and OS : Extracting Weston to /home/markusboil/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_P2180/Linux_for_Tegra/rootfs
15:58:10 INFO : File System and OS : Extracting the configuration files for the supplied root filesystem to /home/markusboil/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_P2180/Linux_for_Tegra/rootfs
15:58:11 INFO : File System and OS : Extracting graphics_demos to /home/markusboil/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_P2180/Linux_for_Tegra/rootfs
15:58:16 INFO : File System and OS : Extracting the firmwares and kernel modules to /home/markusboil/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_P2180/Linux_for_Tegra/rootfs
15:58:18 INFO : File System and OS : Extracting the kernel headers to /home/markusboil/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_P2180/Linux_for_Tegra/rootfs/usr/src
15:58:27 INFO : File System and OS : Adding symlink /home/markusboil/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_P2180/Linux_for_Tegra/rootfs/lib/modules/4.9.140-tegra/build → /usr/src/linux-headers-4.9.140-tegra-ubuntu18.04_aarch64/kernel-4.9
15:58:27 INFO : File System and OS : Installing Image into /boot in target rootfs
15:58:35 INFO : File System and OS : Installing the board .dtb files into /boot in target rootfs
15:58:35 INFO : File System and OS : Creating a symbolic link nvgstplayer pointing to nvgstplayer-1.0
15:58:35 INFO : File System and OS : Creating a symbolic link nvgstcapture pointing to nvgstcapture-1.0
15:58:35 INFO : File System and OS : Adding symlink libcuda.so → libcuda.so.1.1 in target rootfs
15:58:35 INFO : File System and OS : Adding symlink libnvbuf_utils.so → libnvbuf_utils.so.1.0.0 in target rootfs
15:58:35 INFO : File System and OS : Adding symlink libnvid_mapper.so → libnvid_mapper.so.1.0.0 in target rootfs
15:58:35 INFO : File System and OS : Adding symlink libnvbufsurface.so → libnvbufsurface.so.1.0.0 in target rootfs
15:58:35 INFO : File System and OS : Adding symlink libnvbufsurftransform.so → libnvbufsurftransform.so.1.0.0 in target rootfs
15:58:35 INFO : File System and OS : Adding symlink libcuda.so → tegra/libcuda.so in target rootfs
15:58:35 INFO : File System and OS : Adding symlink /home/markusboil/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_P2180/Linux_for_Tegra/rootfs/usr/lib/aarch64-linux-gnu/libdrm_nvdc.so → /home/markusboil/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_P2180/Linux_for_Tegra/rootfs/usr/lib/aarch64-linux-gnu/tegra/libdrm.so.2
15:58:35 INFO : File System and OS : Adding symlink nvidia_icd.json → /etc/vulkan/icd.d/nvidia_icd.json in target rootfs
15:58:35 INFO : File System and OS : Adding symlink nvidia.json → /usr/share/glvnd/egl_vendor.d/10_nvidia.json in target rootfs
15:58:35 INFO : File System and OS : Creating symlinks for weston, wayland-demos, libinput and wayland-ivi-extention modules
15:58:35 INFO : File System and OS : Adding symlinks for NVIDIA systemd services
15:58:35 INFO : File System and OS : Rename ubuntu.desktop → ux-ubuntu.desktop
15:58:35 INFO : File System and OS : Copying USB device mode filesystem image to /home/markusboil/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_P2180/Linux_for_Tegra/rootfs
15:58:35 INFO : File System and OS : Disabling NetworkManager-wait-online.service
15:58:35 INFO : File System and OS : Disable the ondemand service by changing the runlevels to ‘K’
15:58:36 INFO : File System and OS : Installing extlinux.conf into /boot/extlinux in target rootfs
15:58:36 INFO : File System and OS : Success!
15:58:36 INFO : File System and OS : [ Package Install Finished Successfully ]
15:58:36 INFO : File System and OS : [ 3.96 GB used. Disk Avail: 124.19 GB ]
15:58:36 INFO : File System and OS : [ NV_L4T_FILE_SYSTEM_AND_OS_NANO_TX1_COMP Install took 7m12s ]
15:58:36 INFO : File System and OS : command finished successfully
15:58:36 INFO : File System and OS : install ‘File System and OS’ success
15:58:37 INFO : Automatic trying to flash the target device with Manual Flash option…
15:58:37 DEBUG : running command < [ lsusb | grep -c "0955:" -ne 1 ] >
15:58:37 INFO : command finished successfully
15:58:37 DEBUG : running command < [ lsusb | grep -c "0955:" -gt 1 ] >
15:58:37 DEBUG : command terminated with error
15:58:37 ERROR : Could not detect Nvidia Jetson device connected to USB. Verify that: 1. is connected to this host machine with a USB cable. 2. Jetson’s Ubuntu OS is up and running. 3. Ubuntu ‘System configuration wizard’ is completed on the device. This can be validated by running the ‘lsusb’ command on your host, and look for “0955:7721” (NVIDIA Corp). Or use the ‘Manual Setup’ instead.
15:58:37 INFO : Automatic trying to flash the target device with Manual Flash option failed!
15:58:37 INFO : Automatic trying to flash the target device with Automatic Flash option…
15:58:38 DEBUG : command terminated with error
15:58:38 ERROR : Could not detect Nvidia Jetson device connected to USB. Verify that: 1. is connected to this host machine with a USB cable. 2. Jetson’s Ubuntu OS is up and running. 3. Ubuntu ‘System configuration wizard’ is completed on the device. This can be validated by running the ‘lsusb’ command on your host, and look for “0955:7721” (NVIDIA Corp). Or use the ‘Manual Setup’ instead.
15:58:38 INFO : Automatic trying to flash the target device with Automatic Flash option failed!
15:58:38 INFO : Poping up the guide dialog for user…
16:14:22 DEBUG : running command < [ lsusb | grep -c "0955:" -ne 1 ] >
16:14:22 DEBUG : command terminated with error
16:14:22 INFO : Only one nvidia device detected, as expected.
16:14:22 DEBUG : running command < lsusb | grep 0955:7020 >
16:14:22 INFO : Jetson device is in recovery mode.
16:14:22 DEBUG : running command < lsusb | grep 0955:7721 >
16:14:22 INFO : Bus 002 Device 005: ID 0955:7721 NVidia Corp.
16:14:22 INFO : command finished successfully
16:14:22 INFO : Verified, 0955:7721 detected in recovery mode.
16:14:23 INFO : Device Mode Host Setup in Flash : Start to install ‘Device Mode Host Setup in Flash’
16:14:23 DEBUG : Device Mode Host Setup in Flash : running command < cd ‘/home/markusboil/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_P2180’ ; ‘/opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter’ -a=‘install’ -c=‘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’ -i=‘NV_L4T_DEVICE_MODE_SETUP_COMP_IN_FLASH’ -v=‘1.0’ -l=‘/home/markusboil/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_P2180’ -L=‘/home/markusboil/.nvsdkm/logs/JetPack_4.2.3_Linux_GA’ -p=‘2755’ -t=‘P2180’ -e=‘undefined’ >
16:14:23 INFO : Device Mode Host Setup in Flash : [ Disk Avail:124.18 GB ]
16:14:23 INFO : Device Mode Host Setup in Flash : Using GenericInstaller to Install NV_L4T_DEVICE_MODE_SETUP_COMP_IN_FLASH
16:14:23 INFO : Device Mode Host Setup in Flash : change working directory to /home/markusboil/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_P2180
16:14:23 INFO : Device Mode Host Setup in Flash : [ Component Install Started ]
16:14:23 INFO : Device Mode Host Setup in Flash : current working directory is /home/markusboil/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_P2180
16:14:23 INFO : Device Mode Host Setup in Flash : exec_command [host]:
16:14:23 INFO : Device Mode Host Setup in Flash : **********************
16:14:23 INFO : Device Mode Host Setup in Flash : #!/bin/bash
16:14:23 INFO : Device Mode Host Setup in Flash : set -e
16:14:23 INFO : Device Mode Host Setup in Flash : set +e
16:14:23 INFO : Device Mode Host Setup in Flash : eth_port_name=$(ip route show default | awk ‘/default via/ {print $5; exit}’)
16:14:23 INFO : Device Mode Host Setup in Flash : if [[ $eth_port_name == ‘’ ]]; then
16:14:23 INFO : Device Mode Host Setup in Flash : echo ‘Can not found route default $eth_port_name, device mode setup failed!’
16:14:23 INFO : Device Mode Host Setup in Flash : exit 0
16:14:23 INFO : Device Mode Host Setup in Flash : fi
16:14:23 INFO : Device Mode Host Setup in Flash : echo ‘Found route default’ $eth_port_name’, setting up device mode’
16:14:23 INFO : Device Mode Host Setup in Flash : setup_t=‘192.168.55.0/24’
16:14:23 INFO : Device Mode Host Setup in Flash : sudo iptables -t nat -A POSTROUTING -s $setup_t -o $eth_port_name -j MASQUERADE
16:14:23 INFO : Device Mode Host Setup in Flash : sudo iptables -A FORWARD -s $setup_t -o $eth_port_name -j ACCEPT
16:14:23 INFO : Device Mode Host Setup in Flash : sudo iptables -A FORWARD -d $setup_t -m state --state ESTABLISHED,RELATED -i $eth_port_name -j ACCEPT
16:14:23 INFO : Device Mode Host Setup in Flash : sudo sysctl -w net.ipv4.ip_forward=1
16:14:23 INFO : Device Mode Host Setup in Flash : check_google_dns=$(dig @8.8.8.8 nvidia.com || true)
16:14:23 INFO : Device Mode Host Setup in Flash : if [[ $check_google_dns == ‘Got answer’ ]]; then
16:14:23 INFO : Device Mode Host Setup in Flash : echo ‘Device mode on host successfuly set with DNS 8.8.8.8!’
16:14:23 INFO : Device Mode Host Setup in Flash : else
16:14:23 INFO : Device Mode Host Setup in Flash : echo ‘Default google DNS is not working, trying to find a valid server in local host settings!’
16:14:23 INFO : Device Mode Host Setup in Flash : dns_list=$(nmcli -t device show $eth_port_name | grep ‘DNS’ | grep -o '[^:]
16:14:23 INFO : Device Mode Host Setup in Flash : for dns in $dns_list; do
16:14:23 INFO : Device Mode Host Setup in Flash : check_dns=$(dig @$dns nvidia.com || true)
16:14:23 INFO : Device Mode Host Setup in Flash : if [[ $check_dns == ‘Got answer’ ]]; then
16:14:23 INFO : Device Mode Host Setup in Flash : sudo iptables -t nat -A PREROUTING -p tcp -d 8.8.8.8 --dport 53 -j DNAT --to-destination $dns
16:14:23 INFO : Device Mode Host Setup in Flash : sudo iptables -t nat -A PREROUTING -p udp -d 8.8.8.8 --dport 53 -j DNAT --to-destination $dns
16:14:23 INFO : Device Mode Host Setup in Flash : echo ‘Device mode on host successfuly set with DNS’ $dns’!’
16:14:23 INFO : Device Mode Host Setup in Flash : done
16:14:23 INFO : Device Mode Host Setup in Flash : echo ‘Can not found a valid DNS server, device mode setup failed!’
16:14:23 INFO : Device Mode Host Setup in Flash : echo ‘If needed to use device mode, please change the target default dns to a valid server by following the steps in release note.’
16:14:23 INFO : Device Mode Host Setup in Flash : exec_command: /tmp/tmp_NV_L4T_DEVICE_MODE_SETUP_COMP_IN_FLASH.sh
16:14:23 INFO : Device Mode Host Setup in Flash : Found route default wlp2s0, setting up device mode
16:14:23 INFO : Device Mode Host Setup in Flash : [host] [sudo] password for markusboil:
16:14:25 INFO : Device Mode Host Setup in Flash : net.ipv4.ip_forward = 1
16:14:25 INFO : Device Mode Host Setup in Flash : Device mode on host successfuly set with DNS 8.8.8.8!
16:14:25 INFO : Device Mode Host Setup in Flash : [ Component Install Finished Successfully ]
16:14:25 INFO : Device Mode Host Setup in Flash : [ 16.00 KB used. Disk Avail: 124.18 GB ]
16:14:25 INFO : Device Mode Host Setup in Flash : [ NV_L4T_DEVICE_MODE_SETUP_COMP_IN_FLASH Install took 3s ]
16:14:25 INFO : Device Mode Host Setup in Flash : command finished successfully
16:14:25 INFO : Device Mode Host Setup in Flash : install ‘Device Mode Host Setup in Flash’ success
16:14:26 INFO : Flash Jetson TX1 : Start to install ‘Flash Jetson TX1’
16:14:26 DEBUG : Flash Jetson TX1 : running command < cd ‘/home/markusboil/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_P2180’ ; ‘/opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter’ -a=‘install’ -c=‘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’ -i=‘NV_L4T_FLASH_TX1_WITH_OS_IMAGE_COMP’ -v=‘32.2.3’ -l=‘/home/markusboil/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_P2180’ -L=‘/home/markusboil/.nvsdkm/logs/JetPack_4.2.3_Linux_GA’ -p=‘2755’ -t=‘P2180’ -e=‘undefined’ >
16:14:26 INFO : Flash Jetson TX1 : [ Disk Avail:124.18 GB ]
16:14:26 INFO : Flash Jetson TX1 : Using GenericInstaller to Install NV_L4T_FLASH_TX1_WITH_OS_IMAGE_COMP
16:14:26 INFO : Flash Jetson TX1 : change working directory to /home/markusboil/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_P2180/Linux_for_Tegra
16:14:26 INFO : Flash Jetson TX1 : [ Component PreInstall Started ]
16:14:26 INFO : Flash Jetson TX1 : current working directory is /home/markusboil/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_P2180/Linux_for_Tegra
16:14:26 INFO : Flash Jetson TX1 : exec_command: sudo apt-get install -y python
16:14:30 INFO : Flash Jetson TX1 : Reading package lists…
16:14:30 INFO : Flash Jetson TX1 : Building dependency tree…
16:14:30 INFO : Flash Jetson TX1 : Reading state information…
16:14:31 INFO : Flash Jetson TX1 : The following packages were automatically installed and are no longer required:
16:14:31 INFO : Flash Jetson TX1 : efibootmgr gir1.2-geocodeglib-1.0 libfwup1 libllvm8 libwayland-egl1-mesa
16:14:31 INFO : Flash Jetson TX1 : ubuntu-web-launchers
16:14:31 INFO : Flash Jetson TX1 : Use ‘sudo apt autoremove’ to remove them.
16:14:31 INFO : Flash Jetson TX1 : The following additional packages will be installed:
16:14:31 INFO : Flash Jetson TX1 : libpython-stdlib python-minimal python2.7 python2.7-minimal
16:14:31 INFO : Flash Jetson TX1 : Suggested packages:
16:14:31 INFO : Flash Jetson TX1 : python-doc python-tk python2.7-doc binfmt-support
16:14:32 INFO : Flash Jetson TX1 : The following NEW packages will be installed:
16:14:32 INFO : Flash Jetson TX1 : libpython-stdlib python python-minimal python2.7 python2.7-minimal
16:14:33 INFO : Flash Jetson TX1 : 0 upgraded, 5 newly installed, 0 to remove and 6 not upgraded.
16:14:33 INFO : Flash Jetson TX1 : Need to get 176 kB/1,718 kB of archives.
16:14:33 INFO : Flash Jetson TX1 : After this operation, 4,990 kB of additional disk space will be used.
16:14:33 INFO : Flash Jetson TX1 : Get:1 Index of /ubuntu bionic/main amd64 python-minimal amd64 2.7.15~rc1-1 [28.1 kB]
16:14:33 INFO : Flash Jetson TX1 : Get:2 Index of /ubuntu bionic/main amd64 libpython-stdlib amd64 2.7.15~rc1-1 [7,620 B]
16:14:33 INFO : Flash Jetson TX1 : Get:3 Index of /ubuntu bionic/main amd64 python amd64 2.7.15~rc1-1 [140 kB]
16:14:36 INFO : Flash Jetson TX1 : Fetched 176 kB in 1s (178 kB/s)
16:14:37 INFO : Flash Jetson TX1 : Selecting previously unselected package python2.7-minimal.
16:14:40 INFO : Flash Jetson TX1 : (Reading database … (Reading database … 5% (Reading database … 10% (Reading database … 15% (Reading database … 20% (Reading database … 25% (Reading database … 30% (Reading database … 35% (Reading database … 40% (Reading database … 45% (Reading database … 50% (Reading database … 55% (Reading database … 60% (Reading database … 65% (Reading database … 70% (Reading database … 75% (Reading database … 80% (Reading database … 85% (Reading database … 90% (Reading database … 95% (Reading database … 100% (Reading database … 175237 files and directories currently installed.)
16:14:40 INFO : Flash Jetson TX1 : Preparing to unpack …/python2.7-minimal_2.7.17-1~18.04_amd64.deb …
16:14:40 INFO : Flash Jetson TX1 : Unpacking python2.7-minimal (2.7.17-1~18.04) …
16:14:41 INFO : Flash Jetson TX1 : Selecting previously unselected package python-minimal.
16:14:41 INFO : Flash Jetson TX1 : Preparing to unpack …/python-minimal_2.7.15~rc1-1_amd64.deb …
16:14:41 INFO : Flash Jetson TX1 : Unpacking python-minimal (2.7.15~rc1-1) …
16:14:42 INFO : Flash Jetson TX1 : Selecting previously unselected package python2.7.
16:14:42 INFO : Flash Jetson TX1 : Preparing to unpack …/python2.7_2.7.17-1~18.04_amd64.deb …
16:14:42 INFO : Flash Jetson TX1 : Unpacking python2.7 (2.7.17-1~18.04) …
16:14:43 INFO : Flash Jetson TX1 : Selecting previously unselected package libpython-stdlib:amd64.
16:14:43 INFO : Flash Jetson TX1 : Preparing to unpack …/libpython-stdlib_2.7.15~rc1-1_amd64.deb …
16:14:43 INFO : Flash Jetson TX1 : Unpacking libpython-stdlib:amd64 (2.7.15~rc1-1) …
16:14:44 INFO : Flash Jetson TX1 : Setting up python2.7-minimal (2.7.17-1~18.04) …
16:14:45 INFO : Flash Jetson TX1 : Linking and byte-compiling packages for runtime python2.7…
16:14:48 INFO : Flash Jetson TX1 : Setting up python-minimal (2.7.15~rc1-1) …
16:14:48 INFO : Flash Jetson TX1 : Selecting previously unselected package python.
16:14:48 INFO : Flash Jetson TX1 : (Reading database … (Reading database … 5% (Reading database … 10% (Reading database … 15% (Reading database … 20% (Reading database … 25% (Reading database … 30% (Reading database … 35% (Reading database … 40% (Reading database … 45% (Reading database … 50% (Reading database … 55% (Reading database … 60% (Reading database … 65% (Reading database … 70% (Reading database … 75% (Reading database … 80% (Reading database … 85% (Reading database … 90% (Reading database … 95% (Reading database … 100% (Reading database … 175294 files and directories currently installed.)
16:14:48 INFO : Flash Jetson TX1 : Preparing to unpack …/python_2.7.15~rc1-1_amd64.deb …
16:14:48 INFO : Flash Jetson TX1 : Unpacking python (2.7.15~rc1-1) …
16:14:50 INFO : Flash Jetson TX1 : Setting up python2.7 (2.7.17-1~18.04) …
16:14:53 INFO : Flash Jetson TX1 : Setting up libpython-stdlib:amd64 (2.7.15~rc1-1) …
16:14:53 INFO : Flash Jetson TX1 : Setting up python (2.7.15~rc1-1) …
16:14:53 INFO : Flash Jetson TX1 : Processing triggers for desktop-file-utils (0.23-1ubuntu3.18.04.2) …
16:14:53 INFO : Flash Jetson TX1 : Processing triggers for man-db (2.8.3-2ubuntu0.1) …
16:14:57 INFO : Flash Jetson TX1 : Processing triggers for gnome-menus (3.13.3-11ubuntu1.1) …
16:14:57 INFO : Flash Jetson TX1 : Processing triggers for mime-support (3.60ubuntu1) …
16:15:06 INFO : Flash Jetson TX1 : [ Component PreInstall Finished Successfully ]
16:15:06 INFO : Flash Jetson TX1 : [ Component Install Started ]
16:15:06 INFO : Flash Jetson TX1 : current working directory is /home/markusboil/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_P2180/Linux_for_Tegra
16:15:06 INFO : Flash Jetson TX1 : exec_command: sudo ./flash.sh jetson-tx1 mmcblk0p1
16:15:06 INFO : Flash Jetson TX1 : ###############################################################################
16:15:06 INFO : Flash Jetson TX1 : # L4T BSP Information:
16:15:06 INFO : Flash Jetson TX1 : # R32 , REVISION: 2.3
16:15:06 INFO : Flash Jetson TX1 : # Target Board Information:
16:15:06 INFO : Flash Jetson TX1 : # Name: jetson-tx1, Board Family: t210ref, SoC: Tegra 210,
16:15:06 INFO : Flash Jetson TX1 : # OpMode: production, Boot Authentication: ,
16:15:06 INFO : Flash Jetson TX1 : ./tegraflash.py --chip 0x21 --applet “/home/markusboil/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_P2180/Linux_for_Tegra/bootloader/nvtboot_recovery.bin” --skipuid --cmd “dump eeprom boardinfo cvm.bin”
16:15:06 INFO : Flash Jetson TX1 : Welcome to Tegra Flash
16:15:06 INFO : Flash Jetson TX1 : version 1.0.0
16:15:06 INFO : Flash Jetson TX1 : Type ? or help for help and q or quit to exit
16:15:06 INFO : Flash Jetson TX1 : Use ! to execute system commands
16:15:06 INFO : Flash Jetson TX1 : [ 0.0037 ] Generating RCM messages
16:15:06 INFO : Flash Jetson TX1 : [ 0.0056 ] tegrarcm --listrcm rcm_list.xml --chip 0x21 0 --download rcm /home/markusboil/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_P2180/Linux_for_Tegra/bootloader/nvtboot_recovery.bin 0 0
16:15:07 INFO : Flash Jetson TX1 : [ 0.0070 ] RCM 0 is saved as rcm_0.rcm
16:15:07 INFO : Flash Jetson TX1 : [ 0.0359 ] RCM 1 is saved as rcm_1.rcm
16:15:07 INFO : Flash Jetson TX1 : [ 0.0359 ] List of rcm files are saved in rcm_list.xml
16:15:07 INFO : Flash Jetson TX1 : [ 0.0359 ] Signing RCM messages
16:15:07 INFO : Flash Jetson TX1 : [ 0.0605 ] tegrasign --key None --list rcm_list.xml --pubkeyhash pub_key.key
16:15:07 INFO : Flash Jetson TX1 : [ 0.0628 ] Assuming zero filled SBK key
16:15:07 INFO : Flash Jetson TX1 : [ 0.1116 ]
16:15:07 INFO : Flash Jetson TX1 : [ 0.1116 ] Copying signature to RCM mesages
16:15:07 INFO : Flash Jetson TX1 : [ 0.1139 ] tegrarcm --chip 0x21 0 --updatesig rcm_list_signed.xml
16:15:07 INFO : Flash Jetson TX1 : [ 0.1169 ]
If you go here on the host PC:
cd ‘/home/markusboil/nvidia/nvidia_sdk/JetPack_4.2.3_Linux_GA_P2180/Linux_for_Tegra/rootfs/etc/'
…what do you see from “head -n 1 nv_tegra_release”?
Also, earlier you had mentioned:
Is this all purely JetPack4.3 without use of earlier JetPack releases?
Is this entirely for TX1? I am uncertain of the meaning of this:
…are you saying the JetPack4.3 is what you want to use for Xavier, but not for TX1? JetPack4.3 should work for both a TX1 and Xavier, but I want to make sure we are talking about a single model of Jetson and not mixing debug information.
In your most recent log it appears flash never completed. If this is the case (and this does happen), then flash would have never added the full operating system and I would expect any attempt to boot would probably just halt somewhere and never continue.
In terms of situations where flash halts and does not continue this is usually associated with a host PC running on a VM (VMs have issues with holding USB). Is your host a VM or actual install of Ubuntu?
Sorry from my last letter I update system on my laptop on Ubuntu 16.04
I Use Dell laptop with i3 Processor 4Gb Ram and 320GB of disc space.
Download jetpack 3.3 and update TX2 dev.board successfully.
Try to update TX1 dev.board, and nothing is not changed.
Blockquote[0000.120] [TegraBoot] (version 00.00.2014.50-mobile-6987b70e)
[0000.126] Processing in cold boot mode Bootloader 2
[0000.130] A02 Bootrom Patch rev = 63
[0000.134] Power-up reason: reset button
[0000.137] No Battery Present
[0000.140] RamCode = 0
[0000.142] Platform has Ddr4 type ram
[0000.145] max77620 disabling SD1 Remote Sense
[0000.150] Setting Ddr voltage to 1125mv
[0000.154] Serial Number of Pmic Max77663: 0x2405f6
[0000.161] Entering ramdump check
[0000.164] Get RamDumpCarveOut = 0x0
[0000.168] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0000.173] Last reboot was clean, booting normally!
[0000.177] Sdram initialization is successful
[0000.181] SecureOs Carveout Base=0xff800000 Size=0x00800000
[0000.187] GSC1 Carveout Base=0xff700000 Size=0x00100000
[0000.192] GSC2 Carveout Base=0xff600000 Size=0x00100000
[0000.197] GSC3 Carveout Base=0xff500000 Size=0x00100000
[0000.202] GSC4 Carveout Base=0xff400000 Size=0x00100000
[0000.207] GSC5 Carveout Base=0xff300000 Size=0x00100000
[0000.212] BpmpFw Carveout Base=0xff2c0000 Size=0x00040000
[0000.218] Lp0 Carveout Base=0xff2bf000 Size=0x00001000
[0000.233] RamDump Carveout Base=0xff23f000 Size=0x00080000
[0000.239] Platform-DebugCarveout: 0
[0000.242] Nck Carveout Base=0xff03f000 Size=0x00200000
[0000.247] Non secure mode, and RB not enabled.
[0000.277] Using GPT Primary to query partitions
[0000.282] Loading Tboot-CPU binary
[0000.331] Verifying TBC in OdmNonSecureSBK mode
[0000.340] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.347] Bootloader downloaded successfully.
[0000.351] Downloaded Tboot-CPU binary to 0xa0000258
[0000.357] MAX77620_GPIO1 Configured.
[0000.360] MAX77620_GPIO5 Configured.
[0000.363] CPU power rail is up
[0000.366] CPU clock enabled
[0000.370] Performing RAM repair
[0000.373] Updating A64 Warmreset Address to 0xa00002e9
[0000.378] Loading NvTbootBootloaderDTB
[0000.473] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0000.603] Bootloader DTB Load Address: 0x83000000
[0000.608] Loading NvTbootKernelDTB
[0000.702] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0000.832] Kernel DTB Load Address: 0x83100000
[0000.837] Loading cboot binary
[0000.931] Verifying EBT in OdmNonSecureSBK mode
[0000.967] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0000.974] Bootloader downloaded successfully.
[0000.978] GPT: Partition NOT found !
[0000.982] Find Partition via GPT Failed
[0000.985] Find Partition via PT Failed
[0000.989] function NvTbootGetBinaryOffsets: 0x1 error
[0000.994] Error in NvTbootLoadBinary: 0x1 !
[0000.998] Next binary entry address: 0x92c00258
[0001.002] BoardId: 2180
[0001.007] dram memory type is 3
[0001.011] WB0 init successful
[0001.037] Bpmp FW successfully loaded
[0001.040] Set NvDecSticky Bits
[0001.044] GSC1 address : ff700000
[0001.047] GSC2 address ff63fffc value c0edbbcc
[0001.052] GSC2 address : ff600000
[0001.056] GSC3 address : ff500000
[0001.059] GSC4 address : ff400000
[0001.063] GSC5 address : ff300000
[0001.066] GSC MC Settings done
[0001.070] TOS plaintext Image length 32848
[0001.074] Monitor size 32848
[0001.076] OS size 0
[0001.080] *** Secure OS image signature not verified ***
[0001.085] Loading and Validation of Secure OS Successful
[0001.090] NvTbootPackSdramParams: start.
[0001.095] NvTbootPackSdramParams: done.
[0001.099] Tegraboot started after 98582 us
[0001.103] Basic modules init took 936216 us
[0001.107] Sec Bootdevice Read Time = 355 ms, Read Size = 15771 KB
[0001.113] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0001.118] Next stage binary read took 732 us
[0001.122] Carveout took -6646 us
[0001.125] CPU initialization took 96705 us
[0001.129] Total time taken by TegraBoot 1027007 us
[0001.134] Starting CPU & Halting co-processor
[0001.275] RamCode = 0
[0001.296] LPDDR4 Training: Read DT: Number of tables = 10
[0001.301] EMC Training (SRC-freq: 204000; DST-freq: 408000)
[0001.307] EMC Training Successful
[0001.310] EMC Training (SRC-freq: 204000; DST-freq: 665600)
[0001.316] EMC Training Successful
[0001.319] EMC Training (SRC-freq: 204000; DST-freq: 800000)
[0001.331] EMC Training Successful
[0001.334] EMC Training (SRC-freq: 204000; DST-freq: 1065600)
[0001.356] EMC Training Successful
[0001.359] EMC Training (SRC-freq: 204000; DST-freq: 1331200)
[0001.381] EMC Training Successful
[0001.384] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0001.404] EMC Training Successful
[0001.407] Switching to 800000 KHz Success
[0001.417] RamCode = 0
[0001.421] DT Write: emc-table@40800 succeeded
[0001.427] DT Write: emc-table@68000 succeeded
[0001.433] DT Write: emc-table@102000 succeeded
[0001.439] DT Write: emc-table@204000 succeeded
[0001.445] DT Write: emc-table@408000 succeeded
[0001.451] DT Write: emc-table@665600 succeeded
[0001.457] DT Write: emc-table@800000 succeeded
[0001.463] DT Write: emc-table@1065600 succeeded
[0001.469] DT Write: emc-table@1331200 succeeded
[0001.475] DT Write: emc-table@1600000 succeeded
[0001.480] LPDDR4 Training: Write DT: Number of tables = 10
after this I find in files flash.sh and open terminal from this folder. Run your command this is result:
log.log (386.6 KB)
Maybe I may upload system from SD card? If yes, please send to me how to do it. or from HDD…
The log shows flash was successful, and worked as expected. If you were working on a special case, e.g., secure boot, then there would have been other setup required. More detail on why you feel it is failed, or what you were expecting which did not occur, would be helpful. For example, if there was no GUI after boot or some feature was missing (or what you thought should have changed but did not change).
I don’t see GUI on my monitor(I also don’t see NVIDIA logo on sturtup. and command line), TX1 connected in my Router but I don’t see it like connected on router but see how it try to send something(by LED on connector). I may connect it on my TX2 dev.Board but affraid that i Have revision A of TX1 and this version not working on TX2 dev board…(how i know)
By UART interface how you see I also don’t see full startup of system.
TX2startup.log (89.7 KB)
This is sturtup log by UART on TX2.
On tx1 sturtup ending on 1.48second
If You like I may to do video file of STURTUP this two dev. Boards.
It looks like boot was successful and did not have anything interesting going on. Is this monitor natively HDMI? Or did you use a VGA adapter? VGA is not supported, and something like this is common place if VGA is used.
