I’m working on a Jetson Nano project that requires a specific version of JetPack (4.6.1) and L4T (32.7.1). I’m using a Jetson Nano production module (eMMC, no SD card), and the component that requires these specific versions of JetPack and L4T is the Allied Vision CSI-2 Camera Driver (version 4.0.0).
I’m using the NVIDIA SDK Manager to flash the Jetson Nano, which is automatically detected by the SDK Manager. The SDK Manager flashing process seems to complete without any issue, and the Jetson Nano boots up as it should.
However, I’m getting an issue with the installation of the camera drivers, and ultimately the issue seems to stem from an unexpected bootloader file on the Jetson Nano. After flashing, it seems like some version of JetPack 4.6.2 has been unintentionally installed, and a number of the Debian NVIDIA packages on the Jetson Nano are version 32.7.2 instead of 32.7.1. I checked to see if the correct versions of JetPack and L4T had been installed with the reflash using the commands below:
JetPack Version: sudo apt-cache show nvidia-jetpack
Package: nvidia-jetpack
Version: 4.6.2-b5
Architecture: arm64
Maintainer: NVIDIA Corporation
Installed-Size: 194
Depends: nvidia-cuda (= 4.6.2-b5), nvidia-opencv (= 4.6.2-b5), nvidia-cudnn8 (= 4.6.2-b5), nvidia-tensorrt (= 4.6.2-b5), nvidia-visionworks (= 4.6.2-b5), nvidia-container (= 4.6.2-b5), nvidia-vpi (= 4.6.2-b5), nvidia-l4t-jetson-multimedia-api (>> 32.7-0), nvidia-l4t-jetson-multimedia-api (<< 32.8-0)
Homepage: http://developer.nvidia.com/jetson
Priority: standard
Section: metapackages
Filename: pool/main/n/nvidia-jetpack/nvidia-jetpack_4.6.2-b5_arm64.deb
SHA256: 925f4abff97e6024d86cff3b9e132e7c7554d05fb83590487381b7e925d5b2bb
SHA1: e3ef727e87df5c331aece34508c110d57d744fe9
MD5sum: 7cb2e387af41bc8143ac7b6525af7794
Description: NVIDIA Jetpack Meta Package
Description-md5: ad1462289bdbc54909ae109d1d32c0a8
Version: 4.6.1-b110
Architecture: arm64
Installed-Size: 194
Depends: nvidia-cuda (= 4.6.1-b110), nvidia-opencv (= 4.6.1-b110), nvidia-cudnn8 (= 4.6.1-b110), nvidia-tensorrt (= 4.6.1-b110), nvidia-visionworks (= 4.6.1-b110), nvidia-container (= 4.6.1-b110), nvidia-vpi (= 4.6.1-b110), nvidia-l4t-jetson-multimedia-api (>> 32.7-0), nvidia-l4t-jetson-multimedia-api (<< 32.8-0)
Priority: standard
Filename: pool/main/n/nvidia-jetpack/nvidia-jetpack_4.6.1-b110_arm64.deb
SHA256: acfd9e75af780eab165361d61de4b4fe4974890864fe191060b402ac4c2f54d5
SHA1: a016568ac53705acc145a9f7e60505707bea259f
MD5sum: 79be976b184a8c885bd9169ea5b7fb7b
L4T Version: cat /etc/nv_tegra_release
# R32 (release), REVISION: 7.1, GCID: 29818004, BOARD: t210ref, EABI: aarch64, DATE: Sat Feb 19 17:05:08 UTC 2022
Debian Package Versions: sudo apt list nvidia*
Listing... Done
nvidia-cg-doc/bionic 3.1.0013-3 all
nvidia-container/stable 4.6.2-b5 arm64
nvidia-container-csv-cuda/stable,now 10.2.460-1 arm64 [installed]
nvidia-container-csv-cudnn/stable,now 8.2.1.32-1+cuda10.2 arm64 [installed]
nvidia-container-csv-tensorrt/stable,now 8.2.1.8-1+cuda10.2 arm64 [installed]
nvidia-container-csv-visionworks/stable,now 1.6.0.501 arm64 [installed]
nvidia-container-runtime/stable,now 3.7.0-1 all [installed]
nvidia-container-toolkit/stable,now 1.7.0-1 arm64 [installed]
nvidia-cuda/stable 4.6.2-b5 arm64
nvidia-cuda-doc/bionic 9.1.85-3ubuntu1 all
nvidia-cudnn8/stable 4.6.2-b5 arm64
nvidia-docker2/stable,now 2.8.0-1 all [installed]
nvidia-jetpack/stable 4.6.2-b5 arm64
nvidia-l4t-3d-core/stable 32.7.2-20220420143418 arm64 [upgradable from: 32.7.1-20220219090432]
nvidia-l4t-apt-source/stable 32.7.2-20220420143418 arm64 [upgradable from: 32.7.1-20220219090432]
nvidia-l4t-bootloader/stable 32.7.2-20220420143418 arm64 [upgradable from: 32.7.1-20220219090432]
nvidia-l4t-camera/stable 32.7.2-20220420143418 arm64 [upgradable from: 32.7.1-20220219090432]
nvidia-l4t-configs/stable 32.7.2-20220420143418 arm64 [upgradable from: 32.7.1-20220219090432]
nvidia-l4t-core/stable 32.7.2-20220420143418 arm64 [upgradable from: 32.7.1-20220219090432]
nvidia-l4t-cuda/stable 32.7.2-20220420143418 arm64 [upgradable from: 32.7.1-20220219090432]
nvidia-l4t-firmware/stable 32.7.2-20220420143418 arm64 [upgradable from: 32.7.1-20220219090432]
nvidia-l4t-gputools/stable 32.7.2-20220420143418 arm64 [upgradable from: 32.7.1-20220219090432]
nvidia-l4t-graphics-demos/stable 32.7.2-20220420143418 arm64 [upgradable from: 32.7.1-20220219090432]
nvidia-l4t-gstreamer/stable 32.7.2-20220420143418 arm64 [upgradable from: 32.7.1-20220219090432]
nvidia-l4t-init/stable 32.7.2-20220420143418 arm64 [upgradable from: 32.7.1-20220219090432]
nvidia-l4t-initrd/stable 32.7.2-20220420143418 arm64 [upgradable from: 32.7.1-20220219090432]
nvidia-l4t-jetson-io/stable 32.7.2-20220420143418 arm64 [upgradable from: 32.7.1-20220219090432]
nvidia-l4t-jetson-multimedia-api/stable 32.7.2-20220420143418 arm64 [upgradable from: 32.7.1-20220219090432]
nvidia-l4t-kernel/stable 4.9.253-tegra-32.7.2-20220420143418 arm64 [upgradable from: 4.9.253-tegra-32.7.1-20220219090432]
nvidia-l4t-kernel-dtbs/stable 4.9.253-tegra-32.7.2-20220420143418 arm64 [upgradable from: 4.9.253-tegra-32.7.1-20220219090432]
nvidia-l4t-kernel-headers/stable 4.9.253-tegra-32.7.2-20220420143418 arm64 [upgradable from: 4.9.253-tegra-32.7.1-20220219090432]
nvidia-l4t-libvulkan/stable 32.7.2-20220420143418 arm64 [upgradable from: 32.7.1-20220219090432]
nvidia-l4t-multimedia/stable 32.7.2-20220420143418 arm64 [upgradable from: 32.7.1-20220219090432]
nvidia-l4t-multimedia-utils/stable 32.7.2-20220420143418 arm64 [upgradable from: 32.7.1-20220219090432]
nvidia-l4t-oem-config/stable 32.7.2-20220420143418 arm64 [upgradable from: 32.7.1-20220219090432]
nvidia-l4t-tools/stable 32.7.2-20220420143418 arm64 [upgradable from: 32.7.1-20220219090432]
nvidia-l4t-wayland/stable 32.7.2-20220420143418 arm64 [upgradable from: 32.7.1-20220219090432]
nvidia-l4t-weston/stable 32.7.2-20220420143418 arm64 [upgradable from: 32.7.1-20220219090432]
nvidia-l4t-x11/stable 32.7.2-20220420143418 arm64 [upgradable from: 32.7.1-20220219090432]
nvidia-l4t-xusb-firmware/stable 32.7.2-20220420143418 arm64 [upgradable from: 32.7.1-20220219090432]
nvidia-opencv/stable 4.6.2-b5 arm64
nvidia-prime/bionic-updates 0.8.16~0.18.04.1 all
nvidia-settings/bionic-updates,bionic-security 470.57.01-0ubuntu0.18.04.1 arm64
nvidia-tensorrt/stable 4.6.2-b5 arm64
nvidia-visionworks/stable 4.6.2-b5 arm64
nvidia-vpi/stable 4.6.2-b5 arm64
For my project, I need JetPack 4.6.1 and all of the Debian packages to be the correct versions for L4T 32.7.1. Does anyone know why these other versions might be getting installed, and is there a way I can confirm that only the correct versions end up on my device? Thanks in advance.
