is there a way to permanently turn off mipmap generation & texture streaming so they’re not back on when restarting USD Composer?
When I deselect them and restart USD Composer, they’re back to being ticked.
@mzaras you can set to keep them off at app launch through modifying the .kit found in the path below via text editor tool:
%userprofile%\AppData\Local\ov\pkg\create-2023.2.1\apps\omni.create.kit~/.local/share/ov/pkg/create-2023.2.1/apps/omni.create.kitthen append the following snippet at the bottom after the last line of #'s (or anywhere in this text file, really, and not having to mess with the original source code) and remember it’ll be case sensitive:
[settings.rtx-transient.resourcemanager]
genMipsForNormalMaps = false
enableTextureStreaming = false
if you are interested to know how to find your way around or wish to add additional preference changes, you can take a look at step by step here:
I would just advise that you will use a lot more memory that way.
Thanks for the howto Simplychenable !
I see Richard3D, thanks for the heads up.
