TX1 Module Product Certification and Lifecycle
Hi all,
My team had selected TX1 Module for you new product development. We would like to find out more
  1.  Does the module(TX1) follow any IPC standards, what is the IPC class does the module fulfil?
  2.  Any MOQ requirement for purchase? Understand from NVIDIA the standard quality is 1000pcs. Make sample purchase of about 20~30pcs?
  3.  What will be the possible lifecycle of the product or if there is any roadmap?
  4.  What is the cost for getting the Module?
  5.  In our used case we may be exposed to hush environment, which may have high vibration, shock. Example meeting mil spec grade for shock/vibration/EMI/EMC and etc...?
Thank You
Alan73,
Sorry for late response but in case you are still looking for information, here is the pointer for some of your questions,
  1. What will be the possible lifecycle of the product or if there is any roadmap?
    https://developer.nvidia.com/embedded/community/lifecycle
  2. What is the cost for getting the Module?
    https://developer.nvidia.com/embedded/buy/jetson-tx1
  3. In our used case we may be exposed to hush environment, which may have high vibration, shock. Example meeting mil spec grade for shock/vibration/EMI/EMC and etc…?
    Section 5.4 of datasheet: https://developer.nvidia.com/embedded/downloads#?search=Jetson%20TX1%20Module%20Data%20Sheet
