Hi
Please find the error logs below… (including the command used to start Ros camera node)
nvidia@tegra-ubuntu:~/catkin_ws/src$ roslaunch realsense_camera zr300_nodelet_rgbd.launch
Checking log directory for disk usage. This may take awhile.
Press Ctrl-C to interrupt
Done checking log file disk usage. Usage is <1GB.
SUMMARY
PARAMETERS
- /camera/camera_nodelet_manager/num_worker_threads: 4
- /camera/depth_rectify_depth/interpolation: 0
- /camera/disparity_depth/max_range: 4.0
- /camera/disparity_depth/min_range: 0.5
- /camera/disparity_registered_sw/max_range: 4.0
- /camera/disparity_registered_sw/min_range: 0.5
- /camera/driver/base_frame_id: camera_link
- /camera/driver/camera_type: ZR300
- /camera/driver/color_fps: 30
- /camera/driver/color_frame_id: camera_rgb_frame
- /camera/driver/color_height: 480
- /camera/driver/color_optical_frame_id: camera_rgb_optica…
- /camera/driver/color_width: 640
- /camera/driver/depth_fps: 30
- /camera/driver/depth_frame_id: camera_depth_frame
- /camera/driver/depth_height: 360
- /camera/driver/depth_optical_frame_id: camera_depth_opti…
- /camera/driver/depth_width: 480
- /camera/driver/enable_color: True
- /camera/driver/enable_depth: True
- /camera/driver/enable_fisheye: True
- /camera/driver/enable_imu: True
- /camera/driver/enable_ir2: True
- /camera/driver/enable_ir: True
- /camera/driver/enable_pointcloud: False
- /camera/driver/enable_tf: True
- /camera/driver/ir2_frame_id: camera_ir2_frame
- /camera/driver/ir_frame_id: camera_ir_frame
- /camera/driver/mode: manual
- /camera/driver/serial_no:
- /camera/driver/usb_port_id:
- /camera/points_xyzrgb_sw_registered/queue_size: 100
- /rosdistro: kinetic
- /rosversion: 1.12.7
NODES
/camera/
camera_nodelet_manager (nodelet/nodelet)
depth_metric (nodelet/nodelet)
depth_metric_rect (nodelet/nodelet)
depth_points (nodelet/nodelet)
depth_rectify_depth (nodelet/nodelet)
depth_registered_sw_metric_rect (nodelet/nodelet)
disparity_depth (nodelet/nodelet)
disparity_registered_sw (nodelet/nodelet)
driver (nodelet/nodelet)
ir_rectify_ir (nodelet/nodelet)
points_xyzrgb_sw_registered (nodelet/nodelet)
register_depth_rgb (nodelet/nodelet)
rgb_debayer (nodelet/nodelet)
rgb_rectify_color (nodelet/nodelet)
rgb_rectify_mono (nodelet/nodelet)
auto-starting new master
process[master]: started with pid [16642]
ROS_MASTER_URI=http://localhost:11311
setting /run_id to 889730c2-92fd-11e7-8348-00044b8ca4d9
process[rosout-1]: started with pid [16655]
started core service [/rosout]
process[camera/camera_nodelet_manager-2]: started with pid [16673]
process[camera/driver-3]: started with pid [16674]
process[camera/rgb_debayer-4]: started with pid [16677]
process[camera/rgb_rectify_mono-5]: started with pid [16690]
process[camera/rgb_rectify_color-6]: started with pid [16700]
process[camera/ir_rectify_ir-7]: started with pid [16708]
[ INFO] [1504700328.558099680]: Initializing nodelet with 4 worker threads.
process[camera/depth_rectify_depth-8]: started with pid [16721]
process[camera/depth_metric_rect-9]: started with pid [16727]
process[camera/depth_metric-10]: started with pid [16749]
process[camera/depth_points-11]: started with pid [16757]
process[camera/register_depth_rgb-12]: started with pid [16763]
process[camera/points_xyzrgb_sw_registered-13]: started with pid [16783]
process[camera/depth_registered_sw_metric_rect-14]: started with pid [16793]
process[camera/disparity_depth-15]: started with pid [16799]
process[camera/disparity_registered_sw-16]: started with pid [16808]
[ERROR] [1504700328.957537359]: /camera/driver - No cameras detected!
[ INFO] [1504700328.957979096]: /camera/driver - Sleeping 5 seconds then retrying to connect
[ERROR] [1504700334.004569597]: /camera/driver - No cameras detected!
[ERROR] [1504700334.004808401]: /camera/driver - Error calling rs_create_context ( api_version:11201 ):
libusb_open(…) returned LIBUSB_ERROR_ACCESS
[FATAL] [1504700334.149766897]: Failed to load nodelet ‘/camera/rgb_rectify_colorof type
image_proc/rectifyto manager
camera_nodelet_manager’
[FATAL] [1504700334.149766897]: Failed to load nodelet ‘/camera/driverof type
realsense_camera/ZR300Nodeletto manager
[FATAL] [1504700334.150121566]: Failed to load nodelet ‘/camera/rgb_rectify_monoof type
[FATAL] [1504700334.150121566]: Failed to load nodelet ‘/camera/depth_rectify_depthof type
[FATAL] [1504700334.150423183]: Failed to load nodelet ‘/camera/rgb_debayerof type
image_proc/debayerto manager
[FATAL] [1504700334.150603974]: Failed to load nodelet ‘/camera/depth_metricof type
depth_image_proc/convert_metricto manager
[FATAL] [1504700334.150915989]: Failed to load nodelet ‘/camera/register_depth_rgbof type
depth_image_proc/registerto manager
[FATAL] [1504700334.151125419]: Failed to load nodelet ‘/camera/points_xyzrgb_sw_registeredof type
depth_image_proc/point_cloud_xyzrgbto manager
[FATAL] [1504700334.151535989]: Failed to load nodelet ‘/camera/depth_registered_sw_metric_rectof type
[FATAL] [1504700334.151683022]: Failed to load nodelet ‘/camera/disparity_registered_swof type
depth_image_proc/disparityto manager
[FATAL] [1504700334.152070682]: Failed to load nodelet ‘/camera/ir_rectify_irof type
[FATAL] [1504700334.152091545]: Failed to load nodelet ‘/camera/depth_metric_rectof type
[FATAL] [1504700334.152488612]: Failed to load nodelet ‘/camera/depth_pointsof type
depth_image_proc/point_cloud_xyzto manager
[FATAL] [1504700334.153307994]: Failed to load nodelet ‘/camera/disparity_depthof type
[camera/register_depth_rgb-12] process has died [pid 16763, exit code 255, cmd /opt/ros/kinetic/lib/nodelet/nodelet load depth_image_proc/register camera_nodelet_manager --no-bond rgb/camera_info:=rgb/camera_info depth/camera_info:=depth/camera_info depth/image_rect:=depth/image_rect_raw depth_registered/image_rect:=depth_registered/sw_registered/image_rect_raw __name:=register_depth_rgb __log:=/home/nvidia/.ros/log/889730c2-92fd-11e7-8348-00044b8ca4d9/camera-register_depth_rgb-12.log].
log file: /home/nvidia/.ros/log/889730c2-92fd-11e7-8348-00044b8ca4d9/camera-register_depth_rgb-12*.log
[camera/driver-3] process has died [pid 16674, exit code 255, cmd /opt/ros/kinetic/lib/nodelet/nodelet load realsense_camera/ZR300Nodelet camera_nodelet_manager depth:=depth color:=rgb ir:=ir ir2:=ir2 __name:=driver __log:=/home/nvidia/.ros/log/889730c2-92fd-11e7-8348-00044b8ca4d9/camera-driver-3.log].
log file: /home/nvidia/.ros/log/889730c2-92fd-11e7-8348-00044b8ca4d9/camera-driver-3*.log
[camera/rgb_debayer-4] process has died [pid 16677, exit code 255, cmd /opt/ros/kinetic/lib/nodelet/nodelet load image_proc/debayer camera_nodelet_manager --no-bond image_raw:=rgb/image_raw image_mono:=rgb/image_mono image_color:=rgb/image_color __name:=rgb_debayer __log:=/home/nvidia/.ros/log/889730c2-92fd-11e7-8348-00044b8ca4d9/camera-rgb_debayer-4.log].
log file: /home/nvidia/.ros/log/889730c2-92fd-11e7-8348-00044b8ca4d9/camera-rgb_debayer-4*.log
[camera/rgb_rectify_mono-5] process has died [pid 16690, exit code 255, cmd /opt/ros/kinetic/lib/nodelet/nodelet load image_proc/rectify camera_nodelet_manager --no-bond image_mono:=rgb/image_mono image_rect:=rgb/image_rect_mono __name:=rgb_rectify_mono __log:=/home/nvidia/.ros/log/889730c2-92fd-11e7-8348-00044b8ca4d9/camera-rgb_rectify_mono-5.log].
log file: /home/nvidia/.ros/log/889730c2-92fd-11e7-8348-00044b8ca4d9/camera-rgb_rectify_mono-5*.log
[camera/rgb_rectify_color-6] process has died [pid 16700, exit code 255, cmd /opt/ros/kinetic/lib/nodelet/nodelet load image_proc/rectify camera_nodelet_manager --no-bond image_mono:=rgb/image_color image_rect:=rgb/image_rect_color __name:=rgb_rectify_color __log:=/home/nvidia/.ros/log/889730c2-92fd-11e7-8348-00044b8ca4d9/camera-rgb_rectify_color-6.log].
log file: /home/nvidia/.ros/log/889730c2-92fd-11e7-8348-00044b8ca4d9/camera-rgb_rectify_color-6*.log
[camera/ir_rectify_ir-7] process has died [pid 16708, exit code 255, cmd /opt/ros/kinetic/lib/nodelet/nodelet load image_proc/rectify camera_nodelet_manager --no-bond image_mono:=ir/image_raw image_rect:=ir/image_rect_ir __name:=ir_rectify_ir __log:=/home/nvidia/.ros/log/889730c2-92fd-11e7-8348-00044b8ca4d9/camera-ir_rectify_ir-7.log].
log file: /home/nvidia/.ros/log/889730c2-92fd-11e7-8348-00044b8ca4d9/camera-ir_rectify_ir-7*.log
[camera/depth_rectify_depth-8] process has died [pid 16721, exit code 255, cmd /opt/ros/kinetic/lib/nodelet/nodelet load image_proc/rectify camera_nodelet_manager --no-bond image_mono:=depth/image_raw image_rect:=depth/image_rect_raw __name:=depth_rectify_depth __log:=/home/nvidia/.ros/log/889730c2-92fd-11e7-8348-00044b8ca4d9/camera-depth_rectify_depth-8.log].
log file: /home/nvidia/.ros/log/889730c2-92fd-11e7-8348-00044b8ca4d9/camera-depth_rectify_depth-8*.log
[camera/depth_metric_rect-9] process has died [pid 16727, exit code 255, cmd /opt/ros/kinetic/lib/nodelet/nodelet load depth_image_proc/convert_metric camera_nodelet_manager --no-bond image_raw:=depth/image_rect_raw image:=depth/image_rect __name:=depth_metric_rect __log:=/home/nvidia/.ros/log/889730c2-92fd-11e7-8348-00044b8ca4d9/camera-depth_metric_rect-9.log].
log file: /home/nvidia/.ros/log/889730c2-92fd-11e7-8348-00044b8ca4d9/camera-depth_metric_rect-9*.log
[camera/depth_metric-10] process has died [pid 16749, exit code 255, cmd /opt/ros/kinetic/lib/nodelet/nodelet load depth_image_proc/convert_metric camera_nodelet_manager --no-bond image_raw:=depth/image_raw image:=depth/image __name:=depth_metric __log:=/home/nvidia/.ros/log/889730c2-92fd-11e7-8348-00044b8ca4d9/camera-depth_metric-10.log].
log file: /home/nvidia/.ros/log/889730c2-92fd-11e7-8348-00044b8ca4d9/camera-depth_metric-10*.log
[camera/depth_points-11] process has died [pid 16757, exit code 255, cmd /opt/ros/kinetic/lib/nodelet/nodelet load depth_image_proc/point_cloud_xyz camera_nodelet_manager --no-bond image_rect:=depth/image_rect_raw points:=depth/points __name:=depth_points __log:=/home/nvidia/.ros/log/889730c2-92fd-11e7-8348-00044b8ca4d9/camera-depth_points-11.log].
log file: /home/nvidia/.ros/log/889730c2-92fd-11e7-8348-00044b8ca4d9/camera-depth_points-11*.log
[camera/points_xyzrgb_sw_registered-13] process has died [pid 16783, exit code 255, cmd /opt/ros/kinetic/lib/nodelet/nodelet load depth_image_proc/point_cloud_xyzrgb camera_nodelet_manager --no-bond rgb/image_rect_color:=rgb/image_rect_color rgb/camera_info:=rgb/camera_info depth_registered/image_rect:=depth_registered/sw_registered/image_rect_raw depth_registered/points:=depth_registered/points __name:=points_xyzrgb_sw_registered __log:=/home/nvidia/.ros/log/889730c2-92fd-11e7-8348-00044b8ca4d9/camera-points_xyzrgb_sw_registered-13.log].
log file: /home/nvidia/.ros/log/889730c2-92fd-11e7-8348-00044b8ca4d9/camera-points_xyzrgb_sw_registered-13*.log
[camera/depth_registered_sw_metric_rect-14] process has died [pid 16793, exit code 255, cmd /opt/ros/kinetic/lib/nodelet/nodelet load depth_image_proc/convert_metric camera_nodelet_manager --no-bond image_raw:=depth_registered/sw_registered/image_rect_raw image:=depth_registered/sw_registered/image_rect __name:=depth_registered_sw_metric_rect __log:=/home/nvidia/.ros/log/889730c2-92fd-11e7-8348-00044b8ca4d9/camera-depth_registered_sw_metric_rect-14.log].
log file: /home/nvidia/.ros/log/889730c2-92fd-11e7-8348-00044b8ca4d9/camera-depth_registered_sw_metric_rect-14*.log
[camera/disparity_depth-15] process has died [pid 16799, exit code 255, cmd /opt/ros/kinetic/lib/nodelet/nodelet load depth_image_proc/disparity camera_nodelet_manager --no-bond left/image_rect:=depth/image_rect_raw right:=projector left/disparity:=depth/disparity __name:=disparity_depth __log:=/home/nvidia/.ros/log/889730c2-92fd-11e7-8348-00044b8ca4d9/camera-disparity_depth-15.log].
log file: /home/nvidia/.ros/log/889730c2-92fd-11e7-8348-00044b8ca4d9/camera-disparity_depth-15*.log
[camera/disparity_registered_sw-16] process has died [pid 16808, exit code 255, cmd /opt/ros/kinetic/lib/nodelet/nodelet load depth_image_proc/disparity camera_nodelet_manager --no-bond left/image_rect:=depth_registered/sw_registered/image_rect_raw right:=projector left/disparity:=depth_registered/disparity __name:=disparity_registered_sw __log:=/home/nvidia/.ros/log/889730c2-92fd-11e7-8348-00044b8ca4d9/camera-disparity_registered_sw-16.log].
log file: /home/nvidia/.ros/log/889730c2-92fd-11e7-8348-00044b8ca4d9/camera-disparity_registered_sw-16*.log
[camera/camera_nodelet_manager-2] process has died [pid 16673, exit code -11, cmd /opt/ros/kinetic/lib/nodelet/nodelet manager __name:=camera_nodelet_manager __log:=/home/nvidia/.ros/log/889730c2-92fd-11e7-8348-00044b8ca4d9/camera-camera_nodelet_manager-2.log].
log file: /home/nvidia/.ros/log/889730c2-92fd-11e7-8348-00044b8ca4d9/camera-camera_nodelet_manager-2*.log
