TX2 - Sample 11 Camera Object Identification Error
I’ve run samples 9 and 10 successfully, but when I run sample 11, I see:
. [omitted many more lines of this]
CONSUMER: acquireFd 1828717865 (1 frames)
CONSUMER: releaseFd 1828717865 (1 frames)
[ERROR] (NvV4l2ElementPlane.cpp:834) <conv> Capture Plane:Timed out waiting for dqthread
CONSUMER: Done.
PRODUCER: Done -- exiting.
I’m not seeing a window pop up showing the video feed and potential labels, like in the JetsonHacks video which uses this example.
Any suggestions?
Hi Apollys, Do you run ‘export DISPLAY=:0’?
Also we encourage you to run TensorRT. Please refer to the samples:
tegra_multimedia_api\samples\04_video_dec_trt
tegra_multimedia_api\samples\backend
tegra_multimedia_api\samples\frontend
Yes, I have run the export display command. I will test sample 04 when I get the chance.
What command line parameters should I enter to run 04? I don’t see a sample video file anywhere to run it on.
