Since our project need to test WIFI RF performance on TX2,
Would you please help provide TX2 WIFI(CYW4354)MFG driver
(bcmdhd.ko, fw_wifi_nvram.txt, fw_wifi_mfg.bin,…etc) to us?
Thank you
pei-lan_yeh
Thank you
pei-lan_yeh
Hi pei-lan_yeh,
Sorry that we can only provide you those included in BSP. For example, you can find bcmdhd.ko from Jetpack.
Customers should not require the MFG wifi driver.
The process for TX2 is the same as TX1 – so please refer to below doc for now:
[url]https://developer.nvidia.com/embedded/dlc/Jetson-TX1-OEM-Wireless-Compliance-Guide[/url]
What should we do if the antenna that we are using is different form the TX2 developer kit?
For such case, the wireless guide should help. Please refer to it on our download center.
The Wireless guide(JETSON TX1 AND JETSON TX2 OEM WIRELESS COMPLIANCE GUIDE) states that :
To use NVIDIA certificates for their own products, use the following.
Customers must use the same antenna type and equal or lower gain than what is
provided with the Jetson TX1 and Jetson TX2 developer kits as described in Table 4
(both developer kits use the same antenna and cable).
Our design uses a different type of antenna than the one on the development kit. So we are unable to use the
NVIDIA module certificates. I did another search for wireless guides and found nothing relevant. Please point me to the
specific download that would be of help to get my design certified.
Then you may need to contact Cypress for the certification process.
