请教一下,tx2的开发板支持的固态硬盘接口是什么?
如题,tx2的开发板支持的固态硬盘接口是什么,手册 上写的是SATA,但没写是2.0还是3.0!
If you looked into the TX2 Design Guide and module datasheet in DLC, you will get: The SATA controller enables a control path from the module to an external SATA device. A SSD / HDD / ODD drive can be connected. Controller can support the maximum throughput of a Gen 2 drive.
Does this mean that TX2 actually supports SATA2.0? If so, if the SSD I am connecting to is SATA3.0, does it support the same, just not reaching 3.0 speed?
Yes, TX2 supports up to 3.0 Gbps.
thanks
