The SATA Standard Connector for SSD applied to TX2 reference circuit diagram P2597-B04 will be applied to M.2 B type Connector to support M.2 SATA SSD. There seems to be no change in the circuit interface other than the power supply. So, I would like to inquire whether there is any problem or additional consideration in the operation of M.2 SATA SSD.
Trumany
2
Hi, it should be no problem, TX2 supports SATA SSD.
Related topics
| I made a tx2 carrier board by myself, sata to msata,Unable to identify msata hard drive | 15 | 1644 | May 25, 2020 | |
| Expand mSATA SSD | 4 | 631 | April 20, 2020 | |
| TX1 and TX2 support PCIe NVME SSD with M.2 connector? | 1 | 1845 | August 10, 2018 | |
| is there any pcie ssd compatible with TX2? | 7 | 7243 | June 11, 2020 | |
| Can Jetson TX2 boot from SATA drive? | 6 | 920 | March 7, 2023 | |
| the problem about mSATA | 4 | 2675 | January 1, 2021 | |
| 请教一下,tx2的开发板支持的固态硬盘接口是什么? | 4 | 1045 | March 21, 2023 | |
| Problem about mSATA | 11 | 1851 | May 2, 2018 | |
| TX2 NX M.2 to PCIe mSATA SSD | 3 | 1029 | August 25, 2022 | |
| Jetson Tx2 - Wifi card on M.2 connector with SDIO interface | 5 | 1149 | July 28, 2020 |
