I was on 20.04, and both displays were working without any issues. But, ever since I upgraded to 22.04, only the external display is working, and the primary display is black with a non-blinking cursor. (It blinks initially but stays stable after the external display starts output).
I tried removing xorg.conf file and placing a blank xorg.conf file. This results in both of the displays not working.
If I change the prime-select to intel and primary display works and the external display doesn’t show any output.
I tried adding the intel device to xorg.conf but, it’s not working, as well.
Here’s lspci | grep "VGA":
00:02.0 VGA compatible controller: Intel Corporation CoffeeLake-H GT2 [UHD Graphics 630]
01:00.0 VGA compatible controller: NVIDIA Corporation TU116M [GeForce GTX 1660 Ti Mobile] (rev a1)
xrandr -q:
Screen 0: minimum 8 x 8, current 1920 x 1080, maximum 32767 x 32767
DP-0 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 597mm x 336mm
3840x2160 29.97 + 29.97 25.00 23.98
2560x1440 59.95
1920x1080 60.00* 59.94 50.00 29.97 25.00 23.98
1680x1050 59.95
1600x1200 60.00
1600x900 60.00
1440x480 59.94
1280x1024 75.02 60.02
1280x800 59.81
1280x720 60.00 59.94 50.00
1024x768 75.03 60.00
800x600 75.00 60.32
720x576 50.00
720x480 59.94
640x480 75.00 59.94 59.93
DP-1 disconnected (normal left inverted right x axis y axis)
HDMI-0 disconnected (normal left inverted right x axis y axis)
