Black Screen after login - Ubuntu 22.04, RTX 3060, Nvidia Driver 470, Displayport
Hi, I’ve recently installed Ubuntu on my desktop PC alongside Windows 11 (on a separate drive partition). Things were working well for a couple of days but I now just get a black screen after I login to Ubuntu and I can’t do anything (other than open a terminal using ctrl-alt-f5). I am using an Ultrawide LG monitor which I have switched to using DisplayPort 1.1.
Everything is updated to the latest versions but I can’t for the life of me figure out what is going wrong - the graphics card works fine when I boot onto my Windows 11 partition.
I’ve tried switching to using HDMI on the graphics card but that just shows a black screen from boot i.e. no boot screen, BIOS, etc.
Below is my nvidia-bug-reporter.sh output log:
nvidia-bug-report.log.gz (315.8 KB)
Any help/ideas would be greatly appreciated.
I have a similar problem. My external display, connected via USB-C, goes black after login.
Here’s a link to a video showing the issue: [kubuntu 22.04] External display issue - YouTube
The weird part is that the screen is detected by the xrandr, here’s the result
xrandr -q
Screen 0: minimum 320 x 200, current 1920 x 1080, maximum 16384 x 16384
eDP connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 310mm x 174mm
   2560x1440    120.00 +  60.00
   1920x1200    120.00
   1920x1080    120.00*
   1600x1200    120.00
   1680x1050    120.00
   1280x1024    120.00
   1440x900     120.00
   1280x800     120.00
   1280x720     120.00
   1024x768     120.00
   800x600      120.00
   640x480      120.00
HDMI-A-0 disconnected (normal left inverted right x axis y axis)
DP-1-0.1 connected (normal left inverted right x axis y axis)
   1920x1080     60.00 +  59.94    50.00
   1680x1050     59.95
   1440x900      59.89
   1440x576      50.00
   1440x480      59.94
   1280x1024     75.02    60.02
   1280x960      60.00
   1280x720      60.00    59.94    50.00
   1152x864      75.00
   1024x768      75.03    70.07    60.00
   800x600       75.00    72.19    60.32    56.25
   720x576       50.00
   720x480       59.94
   640x480       75.00    72.81    59.94    59.93
DP-1-0 disconnected (normal left inverted right x axis y axis)
DP-1-1 disconnected (normal left inverted right x axis y axis)
Here’s the result for the nvidia-smi
Fri Nov 11 18:21:12 2022
| NVIDIA-SMI 520.56.06    Driver Version: 520.56.06    CUDA Version: 11.8     |
| GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|                               |                      |               MIG M. |
|   0  NVIDIA GeForce ...  Off  | 00000000:01:00.0 Off |                  N/A |
| N/A   51C    P8     7W /  N/A |    125MiB /  4096MiB |      0%      Default |
|                               |                      |                  N/A |
| Processes:        |
|  GPU   GI   CI        PID   Type   Process name                  GPU Memory |
|        ID   ID                                                   Usage      |
|    0   N/A  N/A      1199      G   /usr/lib/xorg/Xorg                 44MiB |
|    0   N/A  N/A      5660    C+G   ...141527590322221790,131072       79MiB |
Running the nvidia-xconfig solves the external display issue but “kills” the primary display of the laptop, ie, external displays work fine but the laptop’s display goes black.,
@generix sorry for tagging you but, after looking reading old forums issues, you seem to have a black belt in solving this kind of issues. Do you have any idea how to solve this?
ADDITIONAL INFORMATION
Laptop Model: Asus ROG Zephyrus G14 GA401QE
CPU: Ryzen 5900HS
GPU: Nvidia 3050 Ti
NVidia drivers info: Driver Version: 520.56.06 CUDA Version: 11.8
Please run nvidia-bug-report.sh as root and attach the resulting nvidia-bug-report.log.gz file to your post.
