Upgraded Ubuntu to 23.10 to a bad surprise! The external monitor is showing purple tint colour!
$ nvidia-smi
Tue Nov 7 13:48:08 2023
| NVIDIA-SMI 535.129.03 Driver Version: 535.129.03 CUDA Version: 12.2 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA RTX A2000 Laptop GPU Off | 00000000:01:00.0 On | N/A |
| N/A 57C P5 10W / 60W | 815MiB / 4096MiB | 31% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 26704 G /usr/lib/xorg/Xorg 437MiB |
| 0 N/A N/A 28908 C+G ...416580964,443157025533222934,262144 366MiB |
$ dpkg -l |grep -i nvidia
ii libaccinj64-12.0:amd64 12.0.146~12.0.1-2 amd64 NVIDIA ACCINJ Library (64-bit)
ii libcu++-dev 1.9.0-3 all NVIDIA C++ Standard Library
ii libcublas12:amd64 12.0.2.224~12.0.1-2 amd64 NVIDIA cuBLAS Library
ii libcublaslt12:amd64 12.0.2.224~12.0.1-2 amd64 NVIDIA cuBLASLt Library
ii libcudart12:amd64 12.0.146~12.0.1-2 amd64 NVIDIA CUDA Runtime Library
ii libcufft11:amd64 11.0.1.95~12.0.1-2 amd64 NVIDIA cuFFT Library
ii libcufftw11:amd64 11.0.1.95~12.0.1-2 amd64 NVIDIA cuFFTW Library
ii libcuinj64-12.0:amd64 12.0.146~12.0.1-2 amd64 NVIDIA CUINJ Library (64-bit)
ii libcupti-dev:amd64 12.0.146~12.0.1-2 amd64 NVIDIA CUDA Profiler Tools Interface development files
ii libcupti-doc 12.0.146~12.0.1-2 all NVIDIA CUDA Profiler Tools Interface documentation
ii libcupti12:amd64 12.0.146~12.0.1-2 amd64 NVIDIA CUDA Profiler Tools Interface runtime library
ii libcurand10:amd64 11.1.1+~10.3.1.124~12.0.1-2 amd64 NVIDIA cuRAND Library
ii libcusolver11:amd64 11.4.3.1~12.0.1-2 amd64 NVIDIA cuSOLVER Library
ii libcusolvermg11:amd64 11.4.3.1~12.0.1-2 amd64 NVIDIA cuSOLVERmg Library
ii libcusparse12:amd64 12.0.1.140~12.0.1-2 amd64 NVIDIA cuSPARSE Library
ii libnppc12:amd64 12.0.1.104~12.0.1-2 amd64 NVIDIA Performance Primitives core runtime library
ii libnppial12:amd64 12.0.1.104~12.0.1-2 amd64 NVIDIA Performance Primitives lib for Image Arithmetic and Logic
ii libnppicc12:amd64 12.0.1.104~12.0.1-2 amd64 NVIDIA Performance Primitives lib for Image Color Conversion
ii libnppidei12:amd64 12.0.1.104~12.0.1-2 amd64 NVIDIA Performance Primitives lib for Image Data Exchange and Initialization
ii libnppif12:amd64 12.0.1.104~12.0.1-2 amd64 NVIDIA Performance Primitives lib for Image Filters
ii libnppig12:amd64 12.0.1.104~12.0.1-2 amd64 NVIDIA Performance Primitives lib for Image Geometry transforms
ii libnppim12:amd64 12.0.1.104~12.0.1-2 amd64 NVIDIA Performance Primitives lib for Image Morphological operations
ii libnppist12:amd64 12.0.1.104~12.0.1-2 amd64 NVIDIA Performance Primitives lib for Image Statistics
ii libnppisu12:amd64 12.0.1.104~12.0.1-2 amd64 NVIDIA Performance Primitives lib for Image Support
ii libnppitc12:amd64 12.0.1.104~12.0.1-2 amd64 NVIDIA Performance Primitives lib for Image Threshold and Compare
ii libnpps12:amd64 12.0.1.104~12.0.1-2 amd64 NVIDIA Performance Primitives for signal processing runtime library
ii libnvidia-cfg1-535:amd64 535.129.03-0ubuntu0.23.10.1 amd64 NVIDIA binary OpenGL/GLX configuration library
ii libnvidia-common-535 535.129.03-0ubuntu0.23.10.1 all Shared files used by the NVIDIA libraries
ii libnvidia-compute-535:amd64 535.129.03-0ubuntu0.23.10.1 amd64 NVIDIA libcompute package
ii libnvidia-decode-535:amd64 535.129.03-0ubuntu0.23.10.1 amd64 NVIDIA Video Decoding runtime libraries
ii libnvidia-encode-535:amd64 535.129.03-0ubuntu0.23.10.1 amd64 NVENC Video Encoding runtime library
ii libnvidia-extra-535:amd64 535.129.03-0ubuntu0.23.10.1 amd64 Extra libraries for the NVIDIA driver
ii libnvidia-fbc1-535:amd64 535.129.03-0ubuntu0.23.10.1 amd64 NVIDIA OpenGL-based Framebuffer Capture runtime library
ii libnvidia-gl-535:amd64 535.129.03-0ubuntu0.23.10.1 amd64 NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii libnvidia-ml-dev:amd64 12.0.140~12.0.1-2 amd64 NVIDIA Management Library (NVML) development files
ii libnvjitlink12:amd64 12.0.140~12.0.1-2 amd64 NVIDIA Compiler JIT LTO Library
ii libnvjpeg12:amd64 12.0.1.102~12.0.1-2 amd64 NVIDIA JPEG library (nvJPEG)
ii libnvrtc-builtins12.0:amd64 12.0.140~12.0.1-2 amd64 CUDA Runtime Compilation (NVIDIA NVRTC Builtins Library)
ii libnvrtc12:amd64 12.0.140~12.0.1-2 amd64 CUDA Runtime Compilation (NVIDIA NVRTC Library)
ii libnvtoolsext1:amd64 12.0.140~12.0.1-2 amd64 NVIDIA Tools Extension Library
ii libnvvm4:amd64 12.0.140~12.0.1-2 amd64 NVIDIA NVVM Library
ii nsight-compute 2022.4.1.6~12.0.1-2 amd64 NVIDIA Nsight Compute
ii nsight-compute-target:amd64 2022.4.1.6~12.0.1-2 amd64 NVIDIA Nsight Compute (target specific libraries)
ii nsight-systems 2022.4.2.50~12.0.1-2 amd64 NVIDIA Nsight Systems
ii nsight-systems-target:amd64 2022.4.2.50~12.0.1-2 amd64 NVIDIA Nsight Systems (target specific libraries)
ii nvidia-compute-utils-535 535.129.03-0ubuntu0.23.10.1 amd64 NVIDIA compute utilities
ii nvidia-cuda-dev:amd64 12.0.146~12.0.1-2 amd64 NVIDIA CUDA development files
ii nvidia-cuda-gdb 12.0.140~12.0.1-2 amd64 NVIDIA CUDA Debugger (GDB)
ii nvidia-cuda-toolkit 12.0.140~12.0.1-2 amd64 NVIDIA CUDA development toolkit
ii nvidia-cuda-toolkit-doc 12.0.1-2 all NVIDIA CUDA and OpenCL documentation
ii nvidia-dkms-535 535.129.03-0ubuntu0.23.10.1 amd64 NVIDIA DKMS package
ii nvidia-driver-535 535.129.03-0ubuntu0.23.10.1 amd64 NVIDIA driver metapackage
ii nvidia-firmware-535-535.113.01 535.113.01-0ubuntu3 amd64 Firmware files used by the kernel module
ii nvidia-firmware-535-535.129.03 535.129.03-0ubuntu0.23.10.1 amd64 Firmware files used by the kernel module
ii nvidia-kernel-common-535 535.129.03-0ubuntu0.23.10.1 amd64 Shared files used with the kernel module
ii nvidia-kernel-source-535 535.129.03-0ubuntu0.23.10.1 amd64 NVIDIA kernel source package
ii nvidia-opencl-dev:amd64 12.0.140~12.0.1-2 amd64 NVIDIA OpenCL development files
ii nvidia-prime 0.8.17.2 all Tools to enable NVIDIA's Prime
ii nvidia-profiler 12.0.146~12.0.1-2 amd64 NVIDIA Profiler for CUDA and OpenCL
ii nvidia-settings 510.47.03-0ubuntu1 amd64 Tool for configuring the NVIDIA graphics driver
ii nvidia-utils-535 535.129.03-0ubuntu0.23.10.1 amd64 NVIDIA driver support binaries
ii nvidia-visual-profiler 12.0.146~12.0.1-2 amd64 NVIDIA Visual Profiler for CUDA and OpenCL
ii screen-resolution-extra 0.18.3 all Extension for the nvidia-settings control panel
ii xserver-xorg-video-nvidia-535 535.129.03-0ubuntu0.23.10.1 amd64 NVIDIA binary Xorg driver
$ sudo modprobe -vvv nvidia
modprobe: INFO: ../libkmod/libkmod.c:404 kmod_set_log_fn() custom logging function 0x560c0e3cf0e0 registered
modprobe: DEBUG: ../libkmod/libkmod-index.c:757 index_mm_open() file=/lib/modules/6.5.0-10-generic/modules.dep.bin
modprobe: DEBUG: ../libkmod/libkmod-index.c:757 index_mm_open() file=/lib/modules/6.5.0-10-generic/modules.alias.bin
modprobe: DEBUG: ../libkmod/libkmod-index.c:757 index_mm_open() file=/lib/modules/6.5.0-10-generic/modules.symbols.bin
modprobe: DEBUG: ../libkmod/libkmod-index.c:757 index_mm_open() file=/lib/modules/6.5.0-10-generic/modules.builtin.alias.bin
modprobe: DEBUG: ../libkmod/libkmod-index.c:757 index_mm_open() file=/lib/modules/6.5.0-10-generic/modules.builtin.bin
modprobe: DEBUG: ../libkmod/libkmod-module.c:579 kmod_module_new_from_lookup() input alias=nvidia, normalized=nvidia
modprobe: DEBUG: ../libkmod/libkmod.c:634 kmod_search_moddep() use mmaped index 'modules.dep' modname=nvidia
modprobe: DEBUG: ../libkmod/libkmod.c:442 kmod_pool_get_module() get module name='nvidia' found=(nil)
modprobe: DEBUG: ../libkmod/libkmod.c:450 kmod_pool_add_module() add 0x560c0f3adfa0 key='nvidia'
modprobe: DEBUG: ../libkmod/libkmod.c:442 kmod_pool_get_module() get module name='drm' found=(nil)
modprobe: DEBUG: ../libkmod/libkmod.c:450 kmod_pool_add_module() add 0x560c0f3ae0e0 key='drm'
modprobe: DEBUG: ../libkmod/libkmod-module.c:196 kmod_module_parse_depline() add dep: /lib/modules/6.5.0-10-generic/kernel/drivers/gpu/drm/drm.ko.zst
modprobe: DEBUG: ../libkmod/libkmod-module.c:202 kmod_module_parse_depline() 1 dependencies for nvidia
modprobe: DEBUG: ../libkmod/libkmod-module.c:584 kmod_module_new_from_lookup() lookup=nvidia found=1
modprobe: DEBUG: ../libkmod/libkmod.c:539 lookup_builtin_file() use mmaped index 'modules.builtin' modname=nvidia
modprobe: DEBUG: ../libkmod/libkmod-module.c:469 kmod_module_unref() kmod_module 0x560c0f3adfa0 released
modprobe: DEBUG: ../libkmod/libkmod.c:458 kmod_pool_del_module() del 0x560c0f3adfa0 key='nvidia'
modprobe: DEBUG: ../libkmod/libkmod-module.c:469 kmod_module_unref() kmod_module 0x560c0f3ae0e0 released
modprobe: DEBUG: ../libkmod/libkmod.c:458 kmod_pool_del_module() del 0x560c0f3ae0e0 key='drm'
modprobe: INFO: ../libkmod/libkmod.c:371 kmod_unref() context 0x560c0f3ad490 released
What should I do?
