When I try to open the system, I get the following error while installing the operating system.
It always says “Reserved SVD code 0”.
I can’t find out what the solution is.
You could start with describing your HW configuration.
Thank you for your answer.
But The system based on Nvdia jetson tx2 does not open at all! It does not start from the SD card. I can’t intervene outside. Is there a way to rebuild it? This card is inserted in the driverless vehicle.
This forum is for NVIDIA Linux desktop support.
You should seek help in this forum.
