Unable to boot and force recovery mode
Hello, I am using Jetson AGX Xavier, and I did some changes in the kernel file of eMMC. Now the system does not boot and I can not access to the force recovery mode. Below you can see the log file.
The error is: ERROR: PARTUUID=ac13edb4-8338-479b-bb7d-b27f27cbc595 mount fail…
How can I fix this and go into recovery mode ?
Jetson UEFI firmware (version 3.1-32827747 built on 2023-03-19T14:56:32+00:00)
ESC   to enter Setup.
F11   to enter Boot Manager Menu.
Enter to continue boot.
**  WARNING: Test Key is used.  **
      L4TLauncher: Attempting Direct Boot
L4T boot options
0: primary kernel
1: backup kernel
Press 0-1 to boot selection within 3.0 seconds.
Press any other key to boot default (Option: 0)
EFI stub: Booting Linux Kernel...
EFI stub: Using DTB from configuration table
EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path
EFI stub: Exiting boot services and installing virtual address map...
▒▒I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
I/TC: Secondary CPU 2 initializing
I/TC: Secondary CPU 2 switching to normal world boot
I/TC: Secondary CPU 3 initializing
I/TC: Secondary CPU 3 switching to normal world boot
I/TC: Secondary CPU 4 initializing
I/TC: Secondary CPU 4 switching to normal world boot
I/TC: Secondary CPU 5 initializing
I/TC: Secondary CPU 5 switching to normal world boot
I/TC: Secondary CPU 6 initializing
I/TC: Secondary CPU 6 switching to normal world boot
I/TC: Secondary CPU 7 initializing
I/TC: Secondary CPU 7 switching to normal world boot
▒▒[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x4e0f0040]
[    0.000000] Linux version 5.10.104-tegra (root@swdev33) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2020.08) 9.3.0, GNU ld (GNU Binutils) 2.33.1) #2 SMP PREEMPT Wed Apr 26 15:23:54 EDT 2023
[    0.000000] Machine model: Jetson-AGXi
[    0.000000] efi: EFI v2.70 by EDK II
[    0.000000] efi: RTPROP=0x73ef97b18 SMBIOS=0xffff0000 SMBIOS 3.0=0x720170000 MEMATTR=0x7200d6018 ESRT=0x7202bd318 RNG=0x743f9dd18 MEMRESERVE=0x7200d8f18
[    0.000000] efi: seeding entropy pool
[    0.000000] esrt: Reserving ESRT space from 0x00000007202bd318 to 0x00000007202bd350.
[    0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'fb0_carveout': base 0x0000000000000000, size 0 MiB
[    0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'fb1_carveout': base 0x0000000000000000, size 0 MiB
[    0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'fb2_carveout': base 0x0000000000000000, size 0 MiB
[    0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'fb3_carveout': base 0x0000000000000000, size 0 MiB
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x000000074a7fffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x00000000abffffff]
[    0.000000]   node   0: [mem 0x00000000ac010000-0x00000000ffddffff]
[    0.000000]   node   0: [mem 0x00000000fffe0000-0x00000000ffffffff]
[    0.000000]   node   0: [mem 0x0000000100000000-0x000000071fb4cfff]
[    0.000000]   node   0: [mem 0x000000071fb4d000-0x000000071fce2fff]
[    0.000000]   node   0: [mem 0x000000071fce3000-0x000000071fd0ffff]
[    0.000000]   node   0: [mem 0x000000071fd10000-0x000000071fd2ffff]
[    0.000000]   node   0: [mem 0x000000071fd30000-0x000000072015ffff]
[    0.000000]   node   0: [mem 0x0000000720160000-0x000000072017ffff]
[    0.000000]   node   0: [mem 0x0000000720180000-0x0000000720c2ffff]
[    0.000000]   node   0: [mem 0x0000000720c30000-0x0000000720e2ffff]
[    0.000000]   node   0: [mem 0x0000000720e30000-0x0000000720e7ffff]
[    0.000000]   node   0: [mem 0x0000000720e80000-0x00000007210affff]
[    0.000000]   node   0: [mem 0x00000007210b0000-0x00000007210effff]
[    0.000000]   node   0: [mem 0x00000007210f0000-0x000000072122ffff]
[    0.000000]   node   0: [mem 0x0000000721230000-0x000000072129ffff]
[    0.000000]   node   0: [mem 0x00000007212a0000-0x00000007212fffff]
[    0.000000]   node   0: [mem 0x0000000721300000-0x00000007218cffff]
[    0.000000]   node   0: [mem 0x00000007218d0000-0x000000072196ffff]
[    0.000000]   node   0: [mem 0x0000000721970000-0x0000000721a1ffff]
[    0.000000]   node   0: [mem 0x0000000721a20000-0x0000000721abffff]
[    0.000000]   node   0: [mem 0x0000000721ac0000-0x0000000721b4ffff]
[    0.000000]   node   0: [mem 0x0000000721b50000-0x0000000721beffff]
[    0.000000]   node   0: [mem 0x0000000721bf0000-0x00000007225bffff]
[    0.000000]   node   0: [mem 0x00000007225c0000-0x000000072279ffff]
[    0.000000]   node   0: [mem 0x00000007227a0000-0x0000000743f4ffff]
[    0.000000]   node   0: [mem 0x0000000743f50000-0x0000000743f9ffff]
[    0.000000]   node   0: [mem 0x0000000743fa0000-0x0000000747cbffff]
[    0.000000]   node   0: [mem 0x000000074a000000-0x000000074a7fffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x000000074a7fffff]
[    0.000000] On node 0, zone DMA: 32 pages in unavailable ranges
[    0.000000] On node 0, zone Normal: 320 pages in unavailable ranges
[    0.000000] cma: Reserved 64 MiB at 0x00000000fbc00000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 32 pages/cpu s90200 r8192 d32680 u131072
[    0.000000] Detected PIPT I-cache on CPU0
[    0.000000] CPU features: detected: Virtualization Host Extensions
[    0.000000] CPU features: kernel page table isolation forced ON by KASLR
[    0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[    0.000000] CPU features: detected: Spectre-v2
[    0.000000] CPU features: detected: NVIDIA Carmel CNP erratum
[    0.000000] alternatives: patching kernel code
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 7000080
[    0.000000] Kernel command line: root=PARTUUID=ac13edb4-8338-479b-bb7d-b27f27cbc595 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 rootfstype=ext4 video=efifb:off
[    0.000000] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
[    0.000000] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x00000000ebc00000-0x00000000fbc00000] (256MB)
[    0.000000] Memory: 27550380K/28445376K available (18240K kernel code, 3280K rwdata, 7404K rodata, 4032K init, 1422K bss, 829460K reserved, 65536K cma-reserved)
[    0.000000] random: get_random_u64 called from __kmem_cache_create+0x34/0x420 with crng_init=0
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=8.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000]  Rude variant of Tasks RCU enabled.
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[    0.000003] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[    0.000525] Console: colour dummy device 80x25
[    0.001679] printk: console [tty0] enabled
[    0.001746] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[    0.001780] pid_max: default: 32768 minimum: 301
[    0.001926] LSM: Security Framework initializing
[    0.001981] Yama: becoming mindful.
[    0.002019] SELinux:  Initializing.
[    0.002169] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.002244] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.005427] rcu: Hierarchical SRCU implementation.
[    0.005686] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build
[    0.006381] DTS File Name: tegra194-agxi-cti-AGX101.dts
[    0.006407] DTB Build time: <unknown>
[    0.008758] Tegra Revision: A02 SKU: 0x99 CPU Process: 0 SoC Process: 0
[    0.009056] Remapping and enabling EFI services.
[    0.010245] smp: Bringing up secondary CPUs ...
[    0.044519] Detected PIPT I-cache on CPU1
[    0.044579] CPU1: Booted secondary processor 0x0000000001 [0x4e0f0040]
[    0.074049] Detected PIPT I-cache on CPU2
[    0.074127] CPU2: Booted secondary processor 0x0000000100 [0x4e0f0040]
[    0.103499] Detected PIPT I-cache on CPU3
[    0.103572] CPU3: Booted secondary processor 0x0000000101 [0x4e0f0040]
[    0.132935] Detected PIPT I-cache on CPU4
[    0.133014] CPU4: Booted secondary processor 0x0000000200 [0x4e0f0040]
[    0.162268] Detected PIPT I-cache on CPU5
[    0.162333] CPU5: Booted secondary processor 0x0000000201 [0x4e0f0040]
[    0.191685] Detected PIPT I-cache on CPU6
[    0.191820] CPU6: Booted secondary processor 0x0000000300 [0x4e0f0040]
[    0.221047] Detected PIPT I-cache on CPU7
[    0.221174] CPU7: Booted secondary processor 0x0000000301 [0x4e0f0040]
[    0.221729] smp: Brought up 1 node, 8 CPUs
[    0.221980] SMP: Total of 8 processors activated.
[    0.222033] CPU features: detected: Privileged Access Never
[    0.222058] CPU features: detected: LSE atomic instructions
[    0.222075] CPU features: detected: User Access Override
[    0.222091] CPU features: detected: 32-bit EL0 Support
[    0.222107] CPU features: detected: RAS Extension Support
[    0.222122] CPU features: detected: CRC32 instructions
[    0.222157] CPU features: detected: 32-bit EL1 Support
[    0.288702] CPU: All CPU(s) started at EL2
[    0.297294] devtmpfs: initialized
[    0.317982] Registered cp15_barrier emulation handler
[    0.318085] Registered setend emulation handler
[    0.318129] KASLR enabled
[    0.318396] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.318431] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    0.319645] pinctrl core: initialized pinctrl subsystem
[    0.320621] SMBIOS 3.0.0 present.
[    0.320646] DMI: Unknown Jetson-AGXi/Jetson-AGXi, BIOS 3.1-32827747 03/19/2023
[    0.321174] NET: Registered protocol family 16
[    0.323755] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
[    0.325414] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.327128] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.327216] audit: initializing netlink subsys (disabled)
[    0.327513] audit: type=2000 audit(0.324:1): state=initialized audit_enabled=0 res=1
[    0.327982] thermal_sys: Registered thermal governor 'step_wise'
[    0.327988] thermal_sys: Registered thermal governor 'power_allocator'
[    0.328010] thermal_sys: Registered thermal governor 'pid_thermal_gov'
[    0.329405] cpuidle: using governor menu
[    0.329673] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.330175] ASID allocator initialised with 32768 entries
[    0.330399] Serial: AMBA PL011 UART driver
[    0.332903] Tegra reboot handler registered.
[    0.385398] mc: mapped MMIO address: 0xffff800010ee0000 -> 0x2c10000
[    0.385451] mc: mapped MMIO address: 0xffff800010f00000 -> 0x2c20000
[    0.385475] mc: mapped MMIO address: 0xffff800010f20000 -> 0x2c30000
[    0.385501] mc: mapped MMIO address: 0xffff800010f40000 -> 0x2c40000
[    0.385526] mc: mapped MMIO address: 0xffff800010f60000 -> 0x2c50000
[    0.385554] mc: mapped MMIO address: 0xffff800010f80000 -> 0x2b80000
[    0.385578] mc: mapped MMIO address: 0xffff800010fa0000 -> 0x2b90000
[    0.385604] mc: mapped MMIO address: 0xffff800010fc0000 -> 0x2ba0000
[    0.385629] mc: mapped MMIO address: 0xffff800010fe0000 -> 0x2bb0000
[    0.385656] mc: mapped MMIO address: 0xffff800011000000 -> 0x1700000
[    0.385682] mc: mapped MMIO address: 0xffff800011020000 -> 0x1710000
[    0.385708] mc: mapped MMIO address: 0xffff800011040000 -> 0x1720000
[    0.385730] mc: mapped MMIO address: 0xffff800011060000 -> 0x1730000
[    0.385754] mc: mapped MMIO address: 0xffff800011080000 -> 0x1740000
[    0.385776] mc: mapped MMIO address: 0xffff8000110a0000 -> 0x1750000
[    0.385802] mc: mapped MMIO address: 0xffff8000110c0000 -> 0x1760000
[    0.385824] mc: mapped MMIO address: 0xffff8000110e0000 -> 0x1770000
[    0.385905] mc-err: mcerr ops are set to t19x
[    0.397235] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.397255] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.397265] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.397277] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    0.403257] ACPI: Interpreter disabled.
[    0.404666] iommu: Default domain type: Translated
[    0.404729] eventlib_kernel: keventlib is initialized, test id: 0
[    0.405032] SCSI subsystem initialized
[    0.405177] usbcore: registered new interface driver usbfs
[    0.405215] usbcore: registered new interface driver hub
[    0.405265] usbcore: registered new device driver usb
[    0.405635] mc: Linux media interface: v0.10
[    0.405662] videodev: Linux video capture interface: v2.00
[    0.405904] pps_core: LinuxPPS API ver. 1 registered
[    0.405913] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.405929] PTP clock support registered
[    0.406129] tegra_wdt_t18x 30c0000.watchdog: Expiry count is deprecated
[    0.406409] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[    0.406494] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[    0.407010] Registered efivars operations
[    0.407320] FPGA manager framework
[    0.407381] Advanced Linux Sound Architecture Driver Initialized.
[    0.407836] Bluetooth: Core ver 2.22
[    0.407867] NET: Registered protocol family 31
[    0.407876] Bluetooth: HCI device and connection manager initialized
[    0.407893] Bluetooth: HCI socket layer initialized
[    0.407907] Bluetooth: L2CAP socket layer initialized
[    0.407938] Bluetooth: SCO socket layer initialized
[    0.409258] camchar: rtcpu character device driver loaded
[    0.409888] clocksource: Switched to clocksource arch_sys_counter
[    0.688805] VFS: Disk quotas dquot_6.6.0
[    0.688868] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.689223] pnp: PnP ACPI: disabled
[    0.700520] la/ptsa driver initialized.
[    0.700634] NET: Registered protocol family 2
[    0.700879] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.710953] tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 bytes, linear)
[    0.711180] TCP established hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.712032] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[    0.712443] TCP: Hash tables configured (established 262144 bind 65536)
[    0.712592] UDP hash table entries: 16384 (order: 7, 524288 bytes, linear)
[    0.712884] UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes, linear)
[    0.713327] NET: Registered protocol family 1
[    0.714083] RPC: Registered named UNIX socket transport module.
[    0.714097] RPC: Registered udp transport module.
[    0.714106] RPC: Registered tcp transport module.
[    0.714114] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.714130] PCI: CLS 0 bytes, default 64
[    0.714347] Trying to unpack rootfs image as initramfs...
[    0.897021] Freeing initrd memory: 9120K
[    0.901080] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    0.901362] kvm [1]: IPA Size Limit: 40 bits
[    0.901859] kvm [1]: vgic interrupt IRQ9
[    0.902492] kvm [1]: VHE mode initialized successfully
[    0.903811] Initialise system trusted keyrings
[    0.904068] workingset: timestamp_bits=46 max_order=23 bucket_order=0
[    0.909423] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.910188] NFS: Registering the id_resolver key type
[    0.910215] Key type id_resolver registered
[    0.910224] Key type id_legacy registered
[    0.910292] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.910309] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.910332] ntfs: driver 2.1.32 [Flags: R/W].
[    0.920015] NET: Registered protocol family 38
[    0.920034] Key type asymmetric registered
[    0.920044] Asymmetric key parser 'x509' registered
[    0.920082] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[    0.920265] io scheduler mq-deadline registered
[    0.920278] io scheduler kyber registered
[    0.926370] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[    0.930061] tegradccommon 15200000.display-hub: Nvhost Channel map failed
[    0.930158] scrncapt: init (heads:4 wins:6 planes:4)
[    0.931053] EINJ: ACPI disabled.
[    0.933240] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[    0.933261] tegra-pmc: ### PMC reset source: MAINSWRST
[    0.933270] tegra-pmc: ### PMC reset level: L1
[    0.933278] tegra-pmc: ### PMC reset status reg: 0x2d
[    0.933319] tegra-pmc: PMC Prod config success
[    0.938377] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    2.357463] printk: console [ttyTCU0] enabled
[    2.362980] arm-smmu 10000000.iommu: probing hardware configuration...
[    2.367850] arm-smmu 10000000.iommu: SMMUv2 with:
[    2.372386] arm-smmu 10000000.iommu:         stage 1 translation
[    2.377758] arm-smmu 10000000.iommu:         stage 2 translation
[    2.378746] random: fast init done
[    2.383262] arm-smmu 10000000.iommu:         nested translation
[    2.392247] arm-smmu 10000000.iommu:         stream matching with 128 register groups
[    2.399165] arm-smmu 10000000.iommu:         64 context banks (0 stage-2 only)
[    2.409031] arm-smmu 10000000.iommu:         Supported page sizes: 0x00001000
[    2.412535] arm-smmu 10000000.iommu:         Stage-1: 48-bit VA -> 48-bit IPA
[    2.419092] arm-smmu 10000000.iommu:         Stage-2: 48-bit IPA -> 48-bit PA
[    2.426459] arm-smmu 12000000.iommu: probing hardware configuration...
[    2.432129] arm-smmu 12000000.iommu: SMMUv2 with:
[    2.436853] arm-smmu 12000000.iommu:         stage 1 translation
[    2.442105] arm-smmu 12000000.iommu:         stage 2 translation
[    2.447549] arm-smmu 12000000.iommu:         nested translation
[    2.453214] arm-smmu 12000000.iommu:         stream matching with 128 register groups
[    2.460136] arm-smmu 12000000.iommu:         64 context banks (0 stage-2 only)
[    2.469992] arm-smmu 12000000.iommu:         Supported page sizes: 0x00001000
[    2.473248] arm-smmu 12000000.iommu:         Stage-1: 48-bit VA -> 48-bit IPA
[    2.480084] arm-smmu 12000000.iommu:         Stage-2: 48-bit IPA -> 48-bit PA
[    2.487386] arm-smmu-suspend 12000000.smmu_suspend: arm_smmu_suspend probe successful
[    2.497433] tegra_profiler: version: 1.151, samples/io: 51/30
[    2.500261] tegra_profiler: auth: init
[    2.504338] THERMAL EST: found 3 subdevs
[    2.508172] THERMAL EST num_resources: 0
[    2.511779] [THERMAL EST subdev 0]
[    2.515100] [THERMAL EST subdev 1]
[    2.518497] [THERMAL EST subdev 2]
[    2.522017] THERMAL EST: Found 2 profiles, default profile is quiet
[    2.528209] THERMAL EST: thz register success.
[    2.532706] THERMAL EST: end of probe, return err: 0
[    2.537907] nvsciipc: loaded module
[    2.543987] tun: Universal TUN/TAP device driver, 1.6
[    2.546924] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[    2.553766] hns3: Copyright (c) 2017 Huawei Corporation.
[    2.559314] e1000e: Intel(R) PRO/1000 Network Driver
[    2.564250] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    2.570068] igb: Intel(R) Gigabit Ethernet Network Driver
[    2.575637] igb: Copyright (c) 2007-2014 Intel Corporation.
[    2.581697] PPP generic driver version 2.4.2
[    2.585747] PPP BSD Compression module registered
[    2.590616] PPP Deflate Compression module registered
[    2.595588] PPP MPPE Compression module registered
[    2.600872] usbcore: registered new interface driver r8152
[    2.606362] usbcore: registered new interface driver asix
[    2.611707] usbcore: registered new interface driver ax88179_178a
[    2.617823] usbcore: registered new interface driver cdc_ether
[    2.623769] usbcore: registered new interface driver net1080
[    2.629120] usbcore: registered new interface driver cdc_subset
[    2.635412] usbcore: registered new interface driver zaurus
[    2.641125] usbcore: registered new interface driver cdc_ncm
[    2.646544] usbcore: registered new interface driver aqc111
[    2.652148] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    2.658508] ohci-pci: OHCI PCI platform driver
[    2.662563] ohci-platform: OHCI generic platform driver
[    2.668390] tegra-xusb 3610000.xhci: Adding to iommu group 0
[    2.674567] usbcore: registered new interface driver uas
[    2.679093] usbcore: registered new interface driver usb-storage
[    2.685086] mousedev: PS/2 mouse device common for all mice
[    2.690597] usbcore: registered new interface driver xpad
[    2.698112] tegra_rtc c2a0000.rtc: registered as rtc1
[    2.701382] tegra_rtc c2a0000.rtc: setting system clock to 1970-01-01T00:00:32 UTC (32)
[    2.709109] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[    2.715362] i2c /dev entries driver
[    2.718685] tegra-i2c 3160000.i2c: Adding to iommu group 1
[    2.724390] tegra-i2c c240000.i2c: Adding to iommu group 1
[    2.729756] tegra-i2c 3180000.i2c: Adding to iommu group 1
[    2.735497] tegra-i2c 3190000.i2c: Adding to iommu group 1
[    2.740912] tegra-i2c 31b0000.i2c: Adding to iommu group 1
[    2.746022] tegra-i2c 31c0000.i2c: Adding to iommu group 1
[    2.751473] tegra-i2c c250000.i2c: Adding to iommu group 1
[    2.757433] FPGA Driver for Tier4 Cameras.
[    2.761063] MAX9295 Driver for TIER4 C1 camera : 2023-04-26 12:55:53
[    2.767104] MAX9296 Driver for TIERIV Camera : 2023-04-26 12:55:53
[    2.773409] TIERIV Automotive HDR Camera driver : 2023-04-26 12:55:54
[    2.785055] tegra-oc-event d280000.soctherm-oc-event: OC driver initialized
[    2.787333] device-mapper: uevent: version 1.0.3
[    2.791916] device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: dm-devel@redhat.com
[    2.801549] cpuidle: Initializing cpuidle driver
[    2.806277] sdhci: Secure Digital Host Controller Interface driver
[    2.811274] sdhci: Copyright(c) Pierre Ossman
[    2.815479] Synopsys Designware Multimedia Card Interface Driver
[    2.821698] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.827838] sdhci-tegra 3460000.sdhci: Adding to iommu group 2
[    2.828069] sdhci-tegra 3400000.sdhci: Adding to iommu group 3
[    2.828690] SMCCC: SOC_ID: ID = jep106:036b:0019 Revision = 0x00000102
[    2.829459] tegra-bpmp bpmp: firmware: 128431eec76692047e1ac1ebc0392266
[    2.851650] max77620 4-003c: PMIC Version OTP:0x51 and ES:0x1
[    2.867195] vdd-1v0: supplied by regulator-dummy
[    2.872745] vdd-1v8-hs: supplied by regulator-dummy
[    2.877575] vdd-1v8-ls: supplied by regulator-dummy
[    2.882440] vdd-1v8-ao: supplied by regulator-dummy
[    2.886379] vddio-ddr-1v1: supplied by regulator-dummy
[    2.890902] vdd-rtc: supplied by regulator-dummy
[    2.892663] spmic-ldo1: supplied by regulator-dummy
[    2.893998] vdd-ao-3v3: supplied by regulator-dummy
[    2.903202] vddio-emmc-3v3: supplied by regulator-dummy
[    2.909495] spmic-ldo4: supplied by regulator-dummy
[    2.910835] vdd-usb-3v3: supplied by regulator-dummy
[    2.917972] vddio-sdmmc1-3v3: supplied by regulator-dummy
[    2.924156] vdd-csi-1v2: supplied by vdd-1v8-ls
[    2.929869] spmic-ldo8: supplied by vdd-1v8-ls
[    2.931338] gpio-510 (gpio_default): hogged as output/high
[    2.933072] gpio-511 (gpio_default): hogged as output/high
[    2.940319] gpiochip0: registered GPIOs 504 to 511 on max77620-gpio
[    3.079274] max77686-rtc max77620-rtc: registered as rtc0
[    3.080610] max77620-power max20024-power: Event recorder REG_NVERC : 0x0
[    3.080957] max77620 4-003c: max77620 probe successful
▒▒debugfs initialized
▒▒[    3.739433] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[    3.740329] hid: raw HID events driver (C) Jiri Kosina
[    3.741074] usbcore: registered new interface driver usbhid
[    3.741220] usbhid: USB HID core driver
[    3.743132] tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 4
[    3.744189] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
▒▒[    33.540395] Camera-FW on t194-rce-safe started
TCU early console enabled.
[    33.612983] Camera-FW on t194-rce-safe ready SHA1=26f9e5f7 (crt 0.775 ms, total boot 73.393 ms)
▒▒[    3.827233] tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-0xbfee01ff size=131584
[    3.827910] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[    3.829049] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[1x448]=0x1900-0x1b40 TX[1x448]=0x1b40-0x1d80
[    3.829734] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d80-0x3e00 TX[1x8192]=0x3e00-0x5e80
[    3.831398] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e80-0xaf00 TX[64x320]=0xaf00-0xff80
[    3.832031] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff80-0x18000 TX[512x64]=0x18000-0x20080
[    3.832637] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: diag: ver=0 grp=1 RX[1x64]=0x20080-0x20140 TX[1x64]=0x20140-0x20200
[    3.833973] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (52)
[    3.834309] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[    3.836020] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=6 sha1=26f9e5f7dc48f7914a7654904022cf8ae53e1e9f
[    3.842385] tegra_aon c1a0000.aon: Adding to iommu group 5
[    3.849766] tegra_aon c1a0000.aon: tegra aon driver probe OK
[    3.854591] tegra186-aondbg aondbg: aondbg driver probe() OK
[    3.862565] denver_knobs_init:MTS_VERSION:55637613
[    3.877562] t19x_cache tegra-cache: probed
[    3.880361] optee: probing for conduit method.
[    3.881438] optee: revision 3.19 (3f29c61f)
[    3.883008] optee: dynamic shared memory is enabled
[    3.885359] optee: initialized driver
[    3.887693] nvpmodel: initialized successfully
[    3.889198] tegra_hv: get_hvd: not initialized yet
[    3.893991] user_ivc_mempool: hypervisor not present
[    3.899433] usbcore: registered new interface driver snd-usb-audio
[    3.906411] u32 classifier
[    3.907688]     input device check on
[    3.911494]     Actions configured
[    3.914770] Initializing XFRM netlink socket
[    3.919608] NET: Registered protocol family 10
[    3.925765] Segment Routing with IPv6
[    3.927122] NET: Registered protocol family 17
[    3.931322] NET: Registered protocol family 15
[    3.935948] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    3.949389] Bluetooth: RFCOMM socket layer initialized
[    3.954308] Bluetooth: RFCOMM ver 1.11
[    3.957836] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    3.964028] Bluetooth: HIDP socket layer initialized
[    3.969944] 9pnet: Installing 9P2000 support
[    3.973131] Key type dns_resolver registered
[    3.978986] registered taskstats version 1
[    3.981608] Loading compiled-in X.509 certificates
[    4.022232] Loaded X.509 cert 'Build time autogenerated kernel key: ddfe18cb0ec4e3d22bc9bcf82c396882fcb00aa8'
[    4.024022] tegra194-pcie 14180000.pcie: Adding to iommu group 6
[    4.029442] tegra194-pcie 14180000.pcie: host bridge /pcie@14180000 ranges:
[    4.029777] tegra194-pcie 14180000.pcie:       IO 0x0038100000..0x00381fffff -> 0x0038100000
[    4.030223] tegra194-pcie 14180000.pcie:      MEM 0x1800000000..0x1b3fffffff -> 0x1800000000
[    4.030495] tegra194-pcie 14180000.pcie:      MEM 0x1b40000000..0x1bffffffff -> 0x0040000000
[    4.141950] tegra194-pcie 14180000.pcie: Link up
[    4.151760] tegra194-pcie 14180000.pcie: PCI host bridge to bus 0000:00
[    4.151933] pci_bus 0000:00: root bus resource [bus 00-ff]
[    4.152059] pci_bus 0000:00: root bus resource [io  0x0000-0xfffff] (bus address [0x38100000-0x381fffff])
[    4.152264] pci_bus 0000:00: root bus resource [mem 0x1800000000-0x1b3fffffff pref]
[    4.152426] pci_bus 0000:00: root bus resource [mem 0x1b40000000-0x1bffffffff] (bus address [0x40000000-0xffffffff])
[    4.152690] pci 0000:00:00.0: [10de:1ad0] type 01 class 0x060400
[    4.152983] pci 0000:00:00.0: PME# supported from D0 D3hot D3cold
[    4.156557] pci 0000:01:00.0: [144d:a808] type 00 class 0x010802
[    4.156862] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[    4.161181] pci 0000:00:00.0: BAR 14: assigned [mem 0x1b40000000-0x1b400fffff]
[    4.161404] pci 0000:01:00.0: BAR 0: assigned [mem 0x1b40000000-0x1b40003fff 64bit]
[    4.161687] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[    4.161853] pci 0000:00:00.0:   bridge window [mem 0x1b40000000-0x1b400fffff]
[    4.162095] pci 0000:00:00.0: Max Payload Size set to  256/ 256 (was  256), Max Read Rq  512
[    4.162415] pci 0000:01:00.0: Max Payload Size set to  256/ 256 (was  128), Max Read Rq  512
[    4.170550] pcieport 0000:00:00.0: Adding to iommu group 6
[    4.175858] pcieport 0000:00:00.0: PME: Signaling with IRQ 24
[    4.181740] pcieport 0000:00:00.0: AER: enabled with IRQ 24
[    4.187671] nvme 0000:01:00.0: Adding to iommu group 6
[    4.192613] nvme nvme0: pci function 0000:01:00.0
[    4.197275] nvme 0000:01:00.0: enabling device (0000 -> 0002)
[    4.197973] tegra194-pcie 14100000.pcie: Adding to iommu group 7
[    4.208941] nvme nvme0: missing or invalid SUBNQN field.
[    4.210329] tegra194-pcie 14100000.pcie: host bridge /pcie@14100000 ranges:
[    4.214028] nvme nvme0: Shutdown timeout set to 8 seconds
[    4.221128] tegra194-pcie 14100000.pcie:       IO 0x0030100000..0x00301fffff -> 0x0030100000
[    4.234873] tegra194-pcie 14100000.pcie:      MEM 0x1200000000..0x122fffffff -> 0x1200000000
[    4.243362] tegra194-pcie 14100000.pcie:      MEM 0x1230000000..0x123fffffff -> 0x0040000000
[    4.262954] nvme nvme0: 8/0/0 default/read/poll queues
[    4.272772]  nvme0n1: p1
[    4.357935] tegra194-pcie 14100000.pcie: Link up
[    4.359372] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00
[    4.359531] pci_bus 0001:00: root bus resource [bus 00-ff]
[    4.359649] pci_bus 0001:00: root bus resource [io  0x100000-0x1fffff] (bus address [0x30100000-0x301fffff])
[    4.359854] pci_bus 0001:00: root bus resource [mem 0x1200000000-0x122fffffff pref]
[    4.360014] pci_bus 0001:00: root bus resource [mem 0x1230000000-0x123fffffff] (bus address [0x40000000-0x4fffffff])
[    4.360279] pci 0001:00:00.0: [10de:1ad2] type 01 class 0x060400
[    4.360575] pci 0001:00:00.0: PME# supported from D0 D3hot D3cold
[    4.363987] pci 0001:01:00.0: [8086:1533] type 00 class 0x020000
[    4.364267] pci 0001:01:00.0: reg 0x10: [mem 0x00000000-0x0007ffff]
[    4.364567] pci 0001:01:00.0: reg 0x18: [io  0x0000-0x001f]
[    4.364772] pci 0001:01:00.0: reg 0x1c: [mem 0x00000000-0x00003fff]
[    4.365739] pci 0001:01:00.0: PME# supported from D0 D3hot D3cold
[    4.380596] pci 0001:00:00.0: BAR 14: assigned [mem 0x1230000000-0x12300fffff]
[    4.380817] pci 0001:00:00.0: BAR 13: assigned [io  0x100000-0x100fff]
[    4.381021] pci 0001:01:00.0: BAR 0: assigned [mem 0x1230000000-0x123007ffff]
[    4.381251] pci 0001:01:00.0: BAR 3: assigned [mem 0x1230080000-0x1230083fff]
[    4.382716] pci 0001:01:00.0: BAR 2: assigned [io  0x100000-0x10001f]
[    4.389278] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[    4.394336] pci 0001:00:00.0:   bridge window [io  0x100000-0x100fff]
[    4.400639] pci 0001:00:00.0:   bridge window [mem 0x1230000000-0x12300fffff]
[    4.408083] pci 0001:00:00.0: Max Payload Size set to  256/ 256 (was  256), Max Read Rq  512
[    4.416789] pci 0001:01:00.0: Max Payload Size set to  256/ 512 (was  128), Max Read Rq  512
[    4.425604] pcieport 0001:00:00.0: Adding to iommu group 7
[    4.430960] pcieport 0001:00:00.0: PME: Signaling with IRQ 26
[    4.436776] pcieport 0001:00:00.0: AER: enabled with IRQ 26
[    4.442592] igb 0001:01:00.0: Adding to iommu group 7
[    4.447527] igb 0001:01:00.0: enabling device (0000 -> 0002)
[    4.485857] pps pps0: new PPS source ptp0
[    4.486149] igb 0001:01:00.0: added PHC on eth0
[    4.486281] igb 0001:01:00.0: Intel(R) Gigabit Ethernet Network Connection
[    4.486477] igb 0001:01:00.0: eth0: (PCIe:2.5Gb/s:Width x1) 00:0c:8b:b4:17:af
[    4.486775] igb 0001:01:00.0: eth0: PBA No: 000300-000
[    4.486935] igb 0001:01:00.0: Using MSI-X interrupts. 4 rx queue(s), 4 tx queue(s)
[    4.488787] tegra194-pcie 14140000.pcie: Adding to iommu group 8
[    4.495502] tegra194-pcie 14140000.pcie: host bridge /pcie@14140000 ranges:
[    4.501521] tegra194-pcie 14140000.pcie:       IO 0x0034100000..0x00341fffff -> 0x0034100000
[    4.509739] tegra194-pcie 14140000.pcie:      MEM 0x1280000000..0x12afffffff -> 0x1280000000
[    4.518488] tegra194-pcie 14140000.pcie:      MEM 0x12b0000000..0x12bfffffff -> 0x0040000000
[    5.634257] tegra194-pcie 14140000.pcie: Phy link never came up
[    5.634540] tegra194-pcie 14140000.pcie: PCI host bridge to bus 0003:00
[    5.634683] pci_bus 0003:00: root bus resource [bus 00-ff]
[    5.634816] pci_bus 0003:00: root bus resource [io  0x200000-0x2fffff] (bus address [0x34100000-0x341fffff])
[    5.635003] pci_bus 0003:00: root bus resource [mem 0x1280000000-0x12afffffff pref]
[    5.635172] pci_bus 0003:00: root bus resource [mem 0x12b0000000-0x12bfffffff] (bus address [0x40000000-0x4fffffff])
[    5.635437] pci 0003:00:00.0: [10de:1ad2] type 01 class 0x060400
[    5.635725] pci 0003:00:00.0: PME# supported from D0 D3hot D3cold
[    5.641389] pci 0003:00:00.0: PCI bridge to [bus 01-ff]
[    5.641553] pci 0003:00:00.0: Max Payload Size set to  256/ 256 (was  256), Max Read Rq  512
[    5.642093] pcieport 0003:00:00.0: Adding to iommu group 8
[    5.642488] pcieport 0003:00:00.0: PME: Signaling with IRQ 28
[    5.642939] pcieport 0003:00:00.0: AER: enabled with IRQ 28
[    5.643548] pci_bus 0003:01: busn_res: [bus 01-ff] is released
[    5.643995] pci 0003:00:00.0: Removing from iommu group 8
[    5.644169] pci_bus 0003:00: busn_res: [bus 00-ff] is released
[    5.650728] tegra194-pcie 141a0000.pcie: Adding to iommu group 9
[    5.762272] tegra194-pcie 141a0000.pcie: host bridge /pcie@141a0000 ranges:
[    5.762449] tegra194-pcie 141a0000.pcie:       IO 0x003a100000..0x003a1fffff -> 0x003a100000
[    5.762655] tegra194-pcie 141a0000.pcie:      MEM 0x1c00000000..0x1f3fffffff -> 0x1c00000000
[    5.762837] tegra194-pcie 141a0000.pcie:      MEM 0x1f40000000..0x1fffffffff -> 0x0040000000
[    6.870273] tegra194-pcie 141a0000.pcie: Phy link never came up
[    6.870560] tegra194-pcie 141a0000.pcie: PCI host bridge to bus 0005:00
[    6.870700] pci_bus 0005:00: root bus resource [bus 00-ff]
[    6.870826] pci_bus 0005:00: root bus resource [io  0x300000-0x3fffff] (bus address [0x3a100000-0x3a1fffff])
[    6.871017] pci_bus 0005:00: root bus resource [mem 0x1c00000000-0x1f3fffffff pref]
[    6.871169] pci_bus 0005:00: root bus resource [mem 0x1f40000000-0x1fffffffff] (bus address [0x40000000-0xffffffff])
[    6.871440] pci 0005:00:00.0: [10de:1ad0] type 01 class 0x060400
[    6.871714] pci 0005:00:00.0: PME# supported from D0 D3hot D3cold
[    6.877431] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[    6.877583] pci 0005:00:00.0: Max Payload Size set to  256/ 256 (was  256), Max Read Rq  512
[    6.878109] pcieport 0005:00:00.0: Adding to iommu group 9
[    6.878533] pcieport 0005:00:00.0: PME: Signaling with IRQ 30
[    6.879037] pcieport 0005:00:00.0: AER: enabled with IRQ 30
[    6.879635] pci_bus 0005:01: busn_res: [bus 01-ff] is released
[    6.880108] pci 0005:00:00.0: Removing from iommu group 9
[    6.880294] pci_bus 0005:00: busn_res: [bus 00-ff] is released
[    6.899579] host1x 13e10000.host1x: Adding to iommu group 10
[    6.911560] host1x 13e10000.host1x: initialized
[    6.912116] iommu_context_dev 13e10000.host1x:ctx0: Adding to iommu group 11
[    6.912480] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56, iommu=smmu.0x0000000012000000)
[    6.913158] iommu_context_dev 13e10000.host1x:ctx1: Adding to iommu group 12
[    6.919865] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57, iommu=smmu.0x0000000012000000)
[    6.929948] iommu_context_dev 13e10000.host1x:ctx2: Adding to iommu group 13
[    6.936912] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58, iommu=smmu.0x0000000012000000)
[    6.946546] iommu_context_dev 13e10000.host1x:ctx3: Adding to iommu group 14
[    6.953274] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59, iommu=smmu.0x0000000012000000)
[    6.963437] iommu_context_dev 13e10000.host1x:ctx4: Adding to iommu group 15
[    6.970359] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60, iommu=smmu.0x0000000012000000)
[    6.980131] iommu_context_dev 13e10000.host1x:ctx5: Adding to iommu group 16
[    6.987337] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61, iommu=smmu.0x0000000012000000)
[    6.997072] iommu_context_dev 13e10000.host1x:ctx6: Adding to iommu group 17
[    7.004316] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62, iommu=smmu.0x0000000012000000)
[    7.014080] iommu_context_dev 13e10000.host1x:ctx7: Adding to iommu group 18
[    7.021295] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63, iommu=smmu.0x0000000012000000)
[    7.030963] falcon 15340000.vic: Adding to iommu group 19
[    7.039827] falcon 15340000.vic: initialized
[    7.041170] falcon 15380000.nvjpg: Adding to iommu group 19
[    7.048788] falcon 15380000.nvjpg: initialized
[    7.051255] falcon 154c0000.nvenc: Adding to iommu group 19
[    7.059923] falcon 154c0000.nvenc: initialized
[    7.061464] falcon 15a80000.nvenc1: Adding to iommu group 19
[    7.070093] falcon 15a80000.nvenc1: initialized
[    7.071880] nvdec 15480000.nvdec: Adding to iommu group 19
[    7.081370] nvdec 15480000.nvdec: initialized
[    7.081688] nvdec 15140000.nvdec1: Adding to iommu group 19
[    7.091358] nvdec 15140000.nvdec1: initialized
[    7.092021] tsec 15500000.tsec: Adding to iommu group 20
[    7.099721] tsec 15500000.tsec: initialized
[    7.101624] tsec 15100000.tsecb: Adding to iommu group 21
[    7.109050] tsec 15100000.tsecb: initialized
[    7.118189] gpiochip1: registered GPIOs 335 to 503 on tegra194-gpio
[    7.119064] gpiochip2: registered GPIOs 305 to 334 on tegra194-gpio-aon
[    7.124141] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[    7.131761] tegra194-isp5 13e10000.host1x:isp@14800000: Adding to iommu group 22
[    7.138336] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: context isolation disabled due to no IOMMU
[    7.146175] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: initialized
[    7.152272] driver not enabled, cannot register any devices
[    7.157780] tegra194-vi5 15c10000.vi: Adding to iommu group 23
[    7.164169] scare-pigeon 13e10000.host1x:vi-thi@15f00000: context isolation disabled due to no IOMMU
[    7.172735] scare-pigeon 13e10000.host1x:vi-thi@15f00000: initialized
[    7.179047] scare-pigeon 13e10000.host1x:isp-thi@14b00000: context isolation disabled due to no IOMMU
[    7.188758] scare-pigeon 13e10000.host1x:isp-thi@14b00000: initialized
[    7.195181] pva 16000000.pva0: Adding to iommu group 24
[    7.215237] pva 16000000.pva0: initialized
[    7.216523] pva 16800000.pva1: Adding to iommu group 25
[    7.222257] pva 16800000.pva1: initialized
[    7.223422] nvdla 15880000.nvdla0: Adding to iommu group 26
[    7.229708] nvdla 15880000.nvdla0: initialized
[    7.230378] nvdla 158c0000.nvdla1: Adding to iommu group 27
[    7.234895] nvdla 158c0000.nvdla1: initialized
[    7.236816] tegradccommon 15200000.display-hub: host1x channel mapped
[    7.237488] tegradc 15200000.display: Adding to iommu group 28
[    7.237497] tegra_cec 3960000.tegra_cec: dt=1 start=0x03960000 end=0x03960FFF irq=70
[    7.237526] tegra_cec 3960000.tegra_cec: Unpowergated DISP
[    7.237550] tegradc 15210000.display: Adding to iommu group 28
[    7.237696] tegra_cec 3960000.tegra_cec: Enable clock result: 0.
[    7.237930] tegra_cec 3960000.tegra_cec: cec_add_sysfs ret=0
[    7.237934] tegra_cec 3960000.tegra_cec: probed
[    7.238194] tegra-gpcdma 2600000.dma: Adding to iommu group 1
[    7.238284] tegra_cec 3960000.tegra_cec: tegra_cec_init started
[    7.238309] tegradc 15220000.display: Adding to iommu group 28
[    7.238710] tegradc 15230000.display: Adding to iommu group 28
[    7.239257] tegra-gpcdma 2600000.dma: GPC DMA driver register 31 channels
[    7.239372] kfuse 3830000.kfuse: initialized
[    7.239590] tegra-fuse-burn efuse-burn: shutdown limit check disabled
[    7.239654] tegra-fuse-burn efuse-burn: Fuse burn driver initialized
[    7.239861] serial-tegra 3100000.serial: Adding to iommu group 1
[    7.240138] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 35, base_baud = 0) is a TEGRA_UART
[    7.240257] tegradccommon 15200000.display-hub: dc_common syncpt # 1 allocated
[    7.240564] serial-tegra 3110000.serial: Adding to iommu group 1
[    7.240845] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 36, base_baud = 0) is a TEGRA_UART
[    7.254447] tegra-i2c 31e0000.i2c: Adding to iommu group 1
[    7.259489] tegradccommon 15200000.display-hub: dma mapping done
[    7.266995] pca954x 8-0070: pca954x_probe: could not read force bus number
[    7.384342] pca954x 8-0070: probe failed
[    7.388341] pca954x: probe of 8-0070 failed with error -121
[    7.395899] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 2047000 KHz, changing to: 2035200 KHz
[    7.405217] tegra194-cpufreq ccplex: probed with BWMGR
[    7.411212] sdhci-tegra 3460000.sdhci: BWMGR client registration for eMC Successful
[    7.411572] vdd-usb-vbus0: supplied by vdd-ac-bat
[    7.412155] sdhci-tegra 3400000.sdhci: Got CD GPIO
[    7.412216] sdhci-tegra 3400000.sdhci: BWMGR client registration for eMC Successful
[    7.421318] irq: IRQ239: trimming hierarchy from :interrupt-controller@3881000
[    7.425440] tegra194-isp5 13e10000.host1x:isp@14800000: initialized
[    7.427361] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 239
[    7.427682] mmc0: CQHCI version 5.10
[    7.434952] driver not enabled, cannot register any devices
[    7.440260] tegra194-vi5 15c10000.vi: initialized
[    7.456471] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit
[    7.458397] driver not enabled, cannot register any devices
[    7.459408] tegradc 15210000.display: disp0 connected to head1->sor
[    7.483641] tegra-xusb 3610000.xhci: Firmware timestamp: 2022-03-16 11:07:43 UTC, Version: 60.13 release
[    7.488055] generic_infoframe_type: 0x87
[    7.497813] tegra-xusb 3610000.xhci: xHCI Host Controller
[    7.501309] tegradc 15210000.display: DT parsed successfully
[    7.502998] mmc1: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit
[    7.507073] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[    7.512743] tegradc 15210000.display: dc.1 probe not in device tree order, deferring
[    7.521223] tegra-xusb 3610000.xhci: hcc params 0x0184ff25 hci version 0x110 quirks 0x0000000000050810
[    7.528167] tegradc 15230000.display: mandatory prop:nvidia,dc-connector not defined
[    7.535801] tegra-xusb 3610000.xhci: irq 197, io mem 0x03610000
[    7.545226] tegradc: probe of 15230000.display failed with error -22
[    7.545310] tegradc 15220000.display: disp0 connected to head2->sor1
[    7.545335] generic_infoframe_type: 0x87
[    7.545369] tegradc 15220000.display: DT parsed successfully
[    7.545374] tegradc 15220000.display: dc.2 probe not in device tree order, deferring
[    7.552989] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[    7.570696] mmc0: Command Queue Engine enabled
[    7.571887] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    7.575514] mmc0: periodic cache flush enabled
[    7.581425] usb usb1: Product: xHCI Host Controller
[    7.581449] usb usb1: Manufacturer: Linux 5.10.104-tegra xhci-hcd
[    7.589324] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[    7.597702] usb usb1: SerialNumber: 3610000.xhci
[    7.598081] hub 1-0:1.0: USB hub found
[    7.602759] mmcblk0: mmc0:0001 G1J38E 59.3 GiB
[    7.609254] hub 1-0:1.0: 4 ports detected
[    7.613733] mmcblk0rpmb: mmc0:0001 G1J38E partition 3 4.00 MiB, chardev (510:0)
[    7.619201] tegra-xusb 3610000.xhci: xHCI Host Controller
[    7.634992]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15
[    7.636031] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[    7.675420] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[    7.682998] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[    7.691163] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    7.698331] usb usb2: Product: xHCI Host Controller
[    7.703243] usb usb2: Manufacturer: Linux 5.10.104-tegra xhci-hcd
[    7.709112] usb usb2: SerialNumber: 3610000.xhci
[    7.714292] hub 2-0:1.0: USB hub found
[    7.717469] hub 2-0:1.0: 4 ports detected
[    7.724017] tegradc 15200000.display: disp0 connected to head0->sor2
[    7.726944] nvethernet 2490000.ethernet: Adding to iommu group 29
[    7.728354] tegradc 15200000.display: tegra_dc_parse_panel_ops: could not find panel for sor2
[    7.734832] nvethernet 2490000.ethernet: failed to read skip mac reset flag, default 0
[    7.743215] tegradc 15200000.display: err:-19 parsing panel_ops
[    7.743345] tegradc 15210000.display: disp0 connected to head1->sor
[    7.751080] nvethernet 2490000.ethernet: failed to read MDIO address
[    7.757237] generic_infoframe_type: 0x87
[    7.763523] nvethernet 2490000.ethernet: setting to default DMA bit mask
[    7.763530] nvethernet 2490000.ethernet: set default TXQ to TC mapping
[    7.769702] tegradc 15210000.display: DT parsed successfully
[    7.773582] nvethernet 2490000.ethernet: Setting default PTP RX queue
[    7.773593] nvethernet 2490000.ethernet: Failed to read DMA Tx ring size, using default [1024]
[    7.773597] nvethernet 2490000.ethernet: Failed to read DMA Rx ring size, using default [1024]
[    7.773619] nvethernet 2490000.ethernet: missing nvidia,pad_auto_cal_pu_offset, setting default 0
[    7.773628] nvethernet 2490000.ethernet: missing nvidia,pad_auto_cal_pd_offset, setting default 0
[    7.781943] nvethernet 2490000.ethernet: failed to get eqos_rx_m clk
[    7.786862] tegradc 15210000.display: dc.1 probe not in device tree order, deferring
[    7.792142] nvethernet 2490000.ethernet: failed to get eqos_rx_input clk
[    7.792147] nvethernet 2490000.ethernet: failed to get eqos_tx_divider clk
[    7.793796] nvethernet 2490000.ethernet: Ethernet MAC address: 48:b0:2d:55:ba:08
[    7.798879] tegradc 15220000.display: disp0 connected to head2->sor1
[    7.815629] generic_infoframe_type: 0x87
[    7.833490] tegradc 15220000.display: DT parsed successfully
[    7.839813] nvethernet 2490000.ethernet: Macsec not supported/Not enabled in DT
[    7.840821] nvethernet 2490000.ethernet: eth1 (HW ver: 50) created with 1 DMA channels
[    7.847649] tegradc 15220000.display: Display dc.(____ptrval____) registered with id=0
[    7.855750] irq: IRQ241: trimming hierarchy from :pmc@c360000
[    7.862554] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 15681600 KB/s
[    7.869116] irq: IRQ242: trimming hierarchy from :interrupt-controller@3881000
[    7.875514] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 1066500000 Hz
[    7.875518] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 358400000 Hz
[    7.875823] tegradc 15220000.display: vblank syncpt # 8 for dc 2
[    7.879595] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[    7.884968] tegradc 15220000.display: vpulse3 syncpt # 9 for dc 2
[    7.886258] tegradc 15220000.display: hdmi: invalid prod list prod_list_hdmi_board
[    7.893447] tegra-se-nvhost 15810000.se: Adding to iommu group 30
[    7.900735] tegradc 15220000.display: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[    7.910285] tegra-se-nvhost 15810000.se: initialized
[    7.949832] tegradc 15220000.display: probed
[    7.958513] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[    8.002364] Console: switching to colour frame buffer device 240x67
[    8.002572] tegra-se-nvhost 15820000.se: Adding to iommu group 31
[    8.008182] tegradc 15220000.display: fb registered
[    8.008244] irq: IRQ243: trimming hierarchy from :pmc@c360000
[    8.014973] tegra-se-nvhost 15820000.se: initialized
[    8.021086] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[    8.027120] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[    8.030138] tegra_nvdisp_handle_pd_enable: Unpowergated Head2 pd
[    8.036236] tegra-se-nvhost 15830000.se: Adding to iommu group 32
[    8.043741] tegradc 15220000.display: supply avdd_hdmi not found, using dummy regulator
[    8.048558] tegra-se-nvhost 15830000.se: initialized
[    8.054473] tegradc 15220000.display: supply avdd_hdmi_pll not found, using dummy regulator
[    8.063408] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[    8.072972] tegradc 15220000.display: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[    8.076023] tegra-se-nvhost 15840000.se: Adding to iommu group 33
[    8.083476] tegradc 15220000.display: hdmi: get YCC quant from EDID.
[    8.091204] tegra-se-nvhost 15840000.se: initialized
[    8.100732] extcon-disp-state external-connection:disp-state: cable 47 state 1
[    8.105162] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[    8.108178] Extcon AUX1(HDMI) enable
[    8.108318] tegradc 15210000.display: disp1 connected to head1->sor
[    8.116679] tegra_actmon d230000.actmon: in actmon_register()...
[    8.121668] generic_infoframe_type: 0x87
[    8.121726] tegradc 15210000.display: DT parsed successfully
[    8.125224] tegra_actmon d230000.actmon: bwmgr_disable = 0
[    8.131559] tegradc 15210000.display: dc.1 probe not in device tree order, deferring
[    8.137740] tegra_actmon d230000.actmon: initialization Completed for the device mc_all
[    8.142309] tegradc 15210000.display: disp1 connected to head1->sor
[    8.147592] hvc_sysfs: hypervisor is not present
[    8.152653] generic_infoframe_type: 0x87
[    8.183118] tegradc 15210000.display: DT parsed successfully
[    8.188677] tegradc 15210000.display: dc.1 probe not in device tree order, deferring
[    8.197056] tegradc 15210000.display: disp1 connected to head1->sor
[    8.202524] generic_infoframe_type: 0x87
[    8.206745] tegradc 15210000.display: DT parsed successfully
[    8.211857] ALSA device list:
[    8.212479] tegradc 15210000.display: dc.1 probe not in device tree order, deferring
[    8.215294]   No soundcards found.
[    8.227367] Freeing unused kernel memory: 4032K
[    8.231568] Run /init as init process
▒▒WARNING: clock_disable: clk_power_ungate on gated domain 27 for gpcclk
▒▒[    8.243321] tegradc 15220000.display: blank - powerdown
[    8.257944] tegra_cec 3960000.tegra_cec: physical address: 10:00.
[    8.280277] extcon-disp-state external-connection:disp-state: cable 47 state 0
[    8.280281] Extcon AUX1(HDMI) disable
[    8.284509] Root device found: PARTUUID=ac13edb4-8338-479b-bb7d-b27f27cbc595
[    8.303689] tegra_nvdisp_handle_pd_disable: Powergated Head2 pd
[    8.304595] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[    8.362068] tegradc 15220000.display: unblank
[    8.363372] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[    8.363614] tegra_nvdisp_handle_pd_enable: Unpowergated Head2 pd
[    8.369533] tegradc 15220000.display: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[    8.371062] tegradc 15220000.display: hdmi: get YCC quant from EDID.
[    8.375066] extcon-disp-state external-connection:disp-state: cable 47 state 1
[    8.375070] Extcon AUX1(HDMI) enable
[    8.387838] tegradc 15220000.display: sync windows ret = 247
[    8.409682] extcon-disp-state external-connection:disp-state: cable 53 state 1
[    8.409686] Extcon HDMI: HPD enabled
[    8.409690] tegradc 15220000.display: hdmi: plugged
[   10.229546] tegra-xusb 3610000.xhci: entering ELPG done
[   10.465936] tegra_cec 3960000.tegra_cec: timeout in tegra_cec_native_write_l:193.
[   10.467358] tegra_cec 3960000.tegra_cec: Sent <Text View On> res: -62.
[   10.468665] tegra_cec 3960000.tegra_cec: tegra_cec_init Done.
[   10.737747] random: crng init done
[   27.953475] ERROR: PARTUUID=ac13edb4-8338-479b-bb7d-b27f27cbc595 mount fail...
You don’t need to fix things before go into recovery mode. Recovery mode is hardware event. No software is involved.
If this is NV developer kit, then you only need to press button to enter recovery mode…
Please follow
https://docs.nvidia.com/jetson/archives/l4t-archived/l4t-3273/index.html#page/Tegra%20Linux%20Driver%20Package%20Development%20Guide/quick_start.html#
Also, in case you have a wrong concept. Recovery mode didn’t fix anything. It is just make the board able to get flashed by another x86 host.
Added clarification: Recovery mode in no way changes the Jetson, nor does it depend in any way on flashed software. Recovery mode turns the Jetson into a custom USB device which is understood only by the custom driver. That driver is known as the “driver package”, and runs on the host PC during flash (needed because Jetsons don’t have a BIOS). JetPack/SDK Manager is just a GUI front end to the flash software…the driver package. If a Jetson cannot go into recovery mode, then it has hardware failure. If a Jetson cannot boot, then it is likely just in need of flashing (you really can’t “brick” a system without a BIOS without trying through extraordinary effort).
The problem is accidentally I changed the extlinux.conf file and I don’t remember the actual PARTUUID. My extlinux.conf file is:
TIMEOUT 30
DEFAULT primary
MENU TITLE L4T boot options
LABEL primary
      MENU LABEL primary kernel
      LINUX /boot/Image
      FDT /boot/dtb/kernel_tegra194-agxi-cti-AGX101.dtb
      INITRD /boot/initrd
      APPEND ${cbootargs} root=PARTUUID=6b35a334-77e3-43f1-87b0-3974c0c4832a rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 rootfstype=ext4 video=efifb:off
# When testing a custom kernel, it is recommended that you create a backup of
# the original kernel and add a new entry to this file so that the device can
# fallback to the original kernel. To do this:
# 1, Make a backup of the original kernel
#      sudo cp /boot/Image /boot/Image.backup
# 2, Copy your custom kernel into /boot/Image
# 3, Uncomment below menu setting lines for the original kernel
# 4, Reboot
# LABEL backup
#    MENU LABEL backup kernel
#    LINUX /boot/Image.backup
#    FDT /boot/dtb/kernel_tegra194-agxi-cti-AGX101.dtb
#    INITRD /boot/initrd
#    APPEND ${cbootargs}
So I typed ‘blkid’ and the result is:
/dev/mmcblk0p1: UUID="c0b141f6-deba-476a-9fe9-4236138f8d84" TYPE="ext4" PARTLABEL="APP" PARTUUID="6b35a334-77e3-43f1-87b0-3974c0c4832a"
/dev/mmcblk0p2: PARTLABEL="kernel" PARTUUID="2c479bdc-c5c5-4cab-801e-211b7c05c24f"
/dev/mmcblk0p3: PARTLABEL="kernel-dtb" PARTUUID="5e6731f6-43d9-4735-9523-6a04528a213e"
/dev/mmcblk0p4: PARTLABEL="reserved_for_chain_A_user" PARTUUID="586101f6-fcd7-40c0-b30a-1a234561821f"
/dev/mmcblk0p5: PARTLABEL="kernel_b" PARTUUID="76176378-2bfe-41fd-a2d5-da48ccc09067"
/dev/mmcblk0p6: PARTLABEL="kernel-dtb_b" PARTUUID="58250e69-e247-4dbc-b985-2d0870bad251"
/dev/mmcblk0p7: PARTLABEL="reserved_for_chain_B_user" PARTUUID="1192bab6-23e1-48a5-b0aa-a523a7ab5538"
/dev/mmcblk0p8: PARTLABEL="recovery" PARTUUID="51c85472-954a-40f1-8719-c349a7f7fd3c"
/dev/mmcblk0p9: PARTLABEL="recovery-dtb" PARTUUID="34e30d2d-c98e-4dfc-a7bc-816709a92a61"
/dev/mmcblk0p10: PARTLABEL="RECROOTFS" PARTUUID="2aa88f54-db28-42a2-86ae-ec304ac10f09"
/dev/mmcblk0p11: UUID="28FB-BC5E" TYPE="vfat" PARTLABEL="esp" PARTUUID="39d81f01-d19b-4556-9c4b-3147f7203912"
/dev/mmcblk0p12: PARTLABEL="recovery_alt" PARTUUID="7617ce72-55d0-4a4b-bd82-bb31ea312f6c"
/dev/mmcblk0p13: PARTLABEL="recovery-dtb_alt" PARTUUID="7c4881ce-575f-4a96-b6f2-bf5337906d54"
/dev/mmcblk0p14: PARTLABEL="esp_alt" PARTUUID="085339a6-782f-4bed-a74a-40265cf4e519"
/dev/mmcblk0p15: PARTLABEL="UDA" PARTUUID="74929c11-f4d7-49e5-83a0-3b5283f05a46"
After that, I changed the PARTUUID in extlinux.conf file with the PARTUUID of mmcblk0p1 which is “6b35a334-77e3-43f1-87b0-3974c0c4832a”.
Now my system gives me an error of this
[    9.292949] tegra_actmon d230000.actmon: in actmon_register()...
[    9.297829] tegra_actmon d230000.actmon: bwmgr_disable = 0
[    9.303660] tegra_actmon d230000.actmon: initialization Completed for the device mc_all
[    9.311671] hvc_sysfs: hypervisor is not present
[    9.367309] ALSA device list:
[    9.367416]   No soundcards found.
[    9.368627] Freeing unused kernel memory: 4032K
[    9.368911] Run /init as init process
▒▒[    9.418838] Root device found: PARTUUID=6b35a334-77e3-43f1-87b0-3974c0c4832a
[    9.475654] tegra_cec 3960000.tegra_cec: Can't find physical address.
[    9.475818] tegra_cec 3960000.tegra_cec: tegra_cec_init Done.
[    9.842990] EXT4-fs (mmcblk0p1): recovery complete
[    9.843144] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[    9.852842] Rootfs mounted over PARTUUID=6b35a334-77e3-43f1-87b0-3974c0c4832a
[    9.880019] Switching from initrd to actual rootfs
[    9.887070] Kernel panic - not syncing: Attempted to kill init! exitcode=0x00007f00
[    9.887276] CPU: 7 PID: 1 Comm: chroot Not tainted 5.10.104-tegra #2
[    9.887409] Hardware name: Unknown Jetson-AGXi/Jetson-AGXi, BIOS 3.1-32827747 03/19/2023
[    9.887575] Call trace:
[    9.887639]  dump_backtrace+0x0/0x1d0
[    9.887718]  show_stack+0x2c/0x40
[    9.887794]  dump_stack+0xd8/0x138
[    9.887865]  panic+0x178/0x380
[    9.887934]  do_exit+0xaa8/0xab0
[    9.888013]  do_group_exit+0x48/0xb0
[    9.888088]  __arm64_sys_exit_group+0x24/0x30
[    9.888178]  el0_svc_common.constprop.0+0x7c/0x1c0
[    9.888275]  do_el0_svc+0x34/0xa0
[    9.888350]  el0_svc+0x1c/0x30
[    9.888417]  el0_sync_handler+0xa8/0xb0
[    9.888497]  el0_sync+0x16c/0x180
[    9.888570] SMP: stopping secondary CPUs
[    9.888664] Kernel Offset: 0x4a0c2e4a0000 from 0xffff800010000000
[    9.888781] PHYS_OFFSET: 0xffffb3a240000000
[    9.889040] CPU features: 0x8240002,03802a30
[    9.889355] Memory Limit: none
[    9.889582] ---[ end Kernel panic - not syncing: Attempted to kill init! exitcode=0x00007f00 ]---
What should I do to fix this?
You could clone, fix this on the clone, and then flash the fixed clone. This isn’t too hard, but it takes a lot of disk space and time. Normally I advise people to test via an added entry in extlinux.conf, while leaving the original entry alone (thus having a backup boot option).
To get a clone, from the “Linux_for_Tegra/” directory:
sudo ./flash.sh -r -K APP -g my_backup.img jetson-agx-xavier-devkit mmcblk0p1
In the above the target expects an AGX Xavier dev kit. This will produce two files, my_backup.img and my_backup.img.raw. To find out more about this, including examples of loopback mount and examination:
https://forums.developer.nvidia.com/t/how-to-make-image-snapshot-of-agx-orin-and-restore-it/268304/2
