The log is shown below.
[ 5318.214108] watchdog: watchdog0: watchdog did not stop!
[ 5318.221469] systemd-shutdow: 38 output lines suppressed due to ratelimiting
[ 5319.286795] reboot: Restarting system
ÿäÿâShutdown state requested 1
Rebooting system ...
ÿâ
[0000.054] W> RATCHET: MB1 binary ratchet value 4 is too large than ratchet level 2 from HW fuses.
[0000.062] I> MB1 (prd-version: 1.5.1.9-t194-41334769-73a9b7ef)
[0000.067] I> Boot-mode: Coldboot
[0000.070] I> Chip revision : A02
[0000.073] I> Bootrom patch version : 15 (correctly patched)
[0000.079] I> ATE fuse revision : 0x200
[0000.082] I> Ram repair fuse : 0x0
[0000.085] I> Ram Code : 0x2
[0000.088] I> rst_source : 0xb
[0000.090] I> rst_level : 0x1
[0000.094] I> Boot-device: eMMC
[0000.109] I> sdmmc DDR50 mode
[0000.113] I> Active Boot chain : 0
[0000.116] I> Boot-device: eMMC
[0000.120] W> MB1_PLATFORM_CONFIG: device prod data is empty in MB1 BCT.
[0000.126] I> Temperature = 42500
[0000.129] W> Skipping boost for clk: BPMP_CPU_NIC
[0000.133] W> Skipping boost for clk: BPMP_APB
[0000.137] W> Skipping boost for clk: AXI_CBB
[0000.141] W> Skipping boost for clk: AON_CPU_NIC
[0000.146] W> Skipping boost for clk: CAN1
[0000.149] W> Skipping boost for clk: CAN2
[0000.154] I> Boot-device: eMMC
[0000.156] I> Boot-device: eMMC
[0000.166] I> Sdmmc: HS400 mode enabled
[0000.170] I> ECC region[0]: Start:0x0, End:0x0
[0000.175] I> ECC region[1]: Start:0x0, End:0x0
[0000.179] I> ECC region[2]: Start:0x0, End:0x0
[0000.183] I> ECC region[3]: Start:0x0, End:0x0
[0000.187] I> ECC region[4]: Start:0x0, End:0x0
[0000.191] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0000.197] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.201] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.206] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.210] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.216] E> FAILED: Thermal config
[0000.223] E> FAILED: MEMIO rail config
[0000.241] I> Boot-device: eMMC
[0000.250] I> sdmmc bdev is already initialized
[0000.325] I> MB1 done
ÿýÿàmain enter
SPE VERSION #: R01.00.14 Created: Sep 19 2018 @ 11:03:21
HW Function test
Start Scheduler.
in late init
ÿâ
[0000.333] I> Welcome to MB2(TBoot-BPMP) (version: 00.00.2018.32-mobile-6fc80c72)
[0000.334] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0000.335] I> Default Heap @ [0xd486400 - 0xd48a400]
[0000.335] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0000.341] W> device prod register failed
[0000.345] I> gpio framework initialized
[0000.349] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driver
[0000.356] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon' driver
[0000.364] I> No valid sdcard_params in mb1_bct
[0000.368] I> Boot-device: eMMC
[0000.371] I> Boot_device: SDMMC_BOOT instance: 3
[0000.380] I> sdmmc-3 params source = boot args
[0000.381] I> sdmmc bdev is already initialized
[0000.384] I> sdmmc-3 params source = boot args
[0000.418] I> Found 17 partitions in SDMMC_BOOT (instance 3)
[0000.434] I> Found 43 partitions in SDMMC_USER (instance 3)
[0000.435] I> Active Boot chain : 0
[0000.441] I> parsing oem signed section of bpmp-fw header done
[0000.448] I> bpmp-fw binary init read from storage
[0000.449] I> oem authentication of bpmp-fw header done
[0000.451] I> bpmp-fw binary done read from storage
[0000.452] I> bpmp-fw: Authentication init Done
[0000.459] I> parsing oem signed section of cpubl header done
[0000.465] I> cpubl binary init read from storage
[0000.466] I> bpmp-fw: Authentication Finalize Done
[0000.467] I> oem authentication of cpubl header done
[0000.467] I> cpubl binary done read from storage
[0000.468] I> cpubl: Authentication init Done
[0000.476] I> parsing oem signed section of rce header done
[0000.483] I> rce binary init read from storage
[0000.483] I> Relocating BR-BCT
[0000.484] I> cpubl: Authentication Finalize Done
[0000.487] I> oem authentication of rce header done
[0000.491] I> rce binary done read from storage
[0000.496] I> rce: Authentication init Done
[0000.506] I> parsing oem signed section of ape header done
[0000.512] I> ape binary init read from storage
[0000.513] I> rce: Authentication Finalize Done
[0000.514] I> oem authentication of ape header done
[0000.518] I> ape binary done read from storage
[0000.522] I> ape: Authentication init Done
[0000.533] I> parsing oem signed section of tos header done
[0000.539] I> tos binary init read from storage
[0000.540] I> ape: Authentication Finalize Done
[0000.541] I> oem authentication of tos header done
[0000.545] I> tos binary done read from storage
[0000.549] I> tos: Authentication init Done
[0000.559] I> parsing oem signed section of bpmp-fw-dtb header done
[0000.566] I> bpmp-fw-dtb binary init read from storage
[0000.567] I> tos: Authentication Finalize Done
[0000.570] I> oem authentication of bpmp-fw-dtb header done
[0000.577] I> bpmp-fw-dtb binary done read from storage
[0000.579] I> bpmp-fw-dtb: Authentication init Done
[0000.590] I> parsing oem signed section of cpubl-dtb header done
[0000.596] I> cpubl-dtb binary init read from storage
[0000.597] I> bpmp-fw-dtb: Authentication Finalize Done
[0000.632] I> oem authentication of cpubl-dtb header done
[0000.633] I> cpubl-dtb binary done read from storage
[0000.633] I> cpubl-dtb: Authentication init Done
[0000.640] I> parsing oem signed section of eks header done
[0000.647] I> eks binary init read from storage
[0000.647] I> cpubl-dtb: Authentication Finalize Done
[0000.648] I> oem authentication of eks header done
[0000.648] I> eks binary done read from storage
[0000.649] I> eks: Authentication init Done
[0000.649] I> eks: Authentication Finalize Done
[0000.653] I> EKB detected (length: 0x410) @ VA:0x52700400
ÿäNOTICE: BL31: v1.3(release):b5eeb33
NOTICE: BL31: Built : 02:21:00, Apr 17 2022
ipc-unittest-main: 1519: Welcome to IPC unittest!!!
ipc-unittest-main: 1531: waiting forever
ipc-unittest-srv: 329: Init unittest services!!!
hwkey-agent: 41: hwkey-agent is running!!
hwkey-agent: 347: key_mgnt_processing .......
hwkey-agent: 255: Setting EKB key 0 to slot 14
hwkey-agent: 178: Init hweky-agent services!!
luks-srv: 40: luks-srv is running!!
luks-srv: 157: Init luks-srv IPC services!!
platform_bootstrap_epilog: trusty bootstrap complete
ÿâ
welcome to lk
calling constructors
initializing heap
creating bootstrap completion thread
top of bootstrap2()
initializing platform
bpmp: platform_init
tag is e73a758761f0c6d24a1e69a2ac6b5035
tag_show initialized
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec_get_ec_list: found 45 ecs
ec initialized
ec_mrq initialized
vmon_populate_monitors: found 3 monitors
vmon initialized
adc initialized
fmon_populate_monitors: found 73 monitors
fmon initialized
fmon_mrq initialized
reset initialized
nvhs initialized
392 clocks registered
WARNING: pll_c4 has no dyn ramp
clk_mrq_init: mrq handler registered
clk initialized
nvlink initialized
io_dpd initialized
io_dpd initialized
thermal initialized
i2c5 controller initialized
initialized i2c mrq handling
i2c initialized
regulator initialized
avfs_clk_platform initialized
soctherm initialized
aotag initialized
powergate initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
avfs_ccplex_platform initialized
tj_max: dt node not found
tj_init initialized
uphy_mrq_init: mrq handler registered
uphy_dt initialized
uphy initialized
safereg_init: period 80 ms
ec_late initialized
mrq initialized
ÿá
[0001.158] I> Welcome to Cboot
ÿâfmon_post initialized
ÿá[0001.158] I> Cboot Version: t194-38d30025
[0001.159] I> CPU-BL Params @ 0xf2820000
[0001.159] I> 0) Base:0x00000000 Size:0x00000000
[0001.162] I> 1) Base:0xf1100000 Size:0x00100000
[0001.167] I> 2) Base:0xf2000000 Size:0x00200000
[0001.171] I> 3) Base:0xf1200000 Size:0x00200000
[0001.176] I> 4) Base:0xf1000000 Size:0x00100000
[0001.180] I> 5) Base:0xf0f00000 Size:0x00100000
[0001.185] I> 6) Base:0xf3800000 Size:0x00400000
ÿâclk_set_parent failed for clk i2c2, parent pll_aon (-22)
clk_set_parent failed for clk i2c8, parent pll_aon (-22)
clk_dt_late initialized
machine_check initialized
pm_post initialized
dbells initialized
avfs_clk_platform_post initialized
dmce initialized
cvc initialized
ccplex_avfs_hw_init: nafll_cluster0: not monitored
ccplex_avfs_hw_init: nafll_cluster1: not monitored
ccplex_avfs_hw_init: nafll_cluster2: not monitored
ccplex_avfs_hw_init: nafll_cluster3: not monitored
avfs_clk_mach_post initialized
regulator_post initialized
rm initialized
sc7_diag initialized
thermal_test initialized
serial_late initialized
clk_post initialized
clk_dt_post initialized
mc_reg initialized
pg_post initialized
dyn_modules initialized
sku_debugfs initialized
speedo_debugfs initialized
adc_debugfs initialized
clk_debugfs initialized
ÿá[0001.189] I> 7) Base:0xf1c00000 Size:0x00400000
[0001.269] I> 8) Base:0xf0e00000 Size:0x00100000
[0001.273] I> 9) Base:0xf0d00000 Size:0x00100000
[0001.277] I> 10) Base:0xf3000000 Size:0x00800000
[0001.282] I> 11) Base:0x40000000 Size:0x00040000
[0001.286] I> 12) Base:0xf0c00000 Size:0x00100000
[0001.291] I> 13) Base:0x40046000 Size:0x00002000
[0001.295] I> 14) Base:0x40048000 Size:0x00002000
[0001.300] I> 15) Base:0xac000000 Size:0x00004000
[0001.304] I> 16) Base:0x4004a000 Size:0x00002000
[0001.309] I> 17) Base:0xf0b00000 Size:0x00100000
ÿâemc_debugfs initialized
dvs_debugfs initialized
fmon_debugfs initialized
vmon_debugfs initialized
pg_debugfs initialized
profile_fs initialized
debugfs_cons initialized
mail_fs initialized
profile initialized
cvc_debugfs initialized
dmce_debugfs initialized
ec_debugfs initialized
rm_debugfs initialized
soctherm_debug initialized
gr_reader initialized
mods initialized
dt_fs initialized
debugfs_mrq initialized
debug_mrq initialized
debug_safereg initialized
initializing target
calling apps_init()
starting app shell
entering main console loop
] ÿá[0001.313] I> 18) Base:0x4004c000 Size:0x00002000
[0001.368] I> 19) Base:0xf2200000 Size:0x00600000
[0001.372] I> 20) Base:0x4004e000 Size:0x00002000
[0001.377] I> 21) Base:0xf0ad0000 Size:0x0000c000
[0001.381] I> 22) Base:0x00000000 Size:0x00000000
[0001.386] I> 23) Base:0xf0ae0000 Size:0x00020000
[0001.390] I> 24) Base:0xf6000000 Size:0x02000000
[0001.395] I> 25) Base:0x40050000 Size:0x00002000
[0001.399] I> 26) Base:0x40040000 Size:0x00006000
[0001.404] I> 27) Base:0xf1800000 Size:0x00400000
[0001.408] I> 28) Base:0xf4c00000 Size:0x01400000
[0001.413] I> 29) Base:0xf1400000 Size:0x00400000
[0001.417] I> 30) Base:0x00000000 Size:0x00000000
[0001.422] I> 31) Base:0x00000000 Size:0x00000000
[0001.426] I> 32) Base:0xf8000000 Size:0x08000000
[0001.430] I> 33) Base:0x00000000 Size:0x00000000
[0001.435] I> 34) Base:0xf3c00000 Size:0x01000000
[0001.439] I> 35) Base:0xab000000 Size:0x01000000
[0001.444] I> 36) Base:0xa0000000 Size:0x0b000000
[0001.448] I> 37) Base:0xf2800000 Size:0x00800000
[0001.453] I> 38) Base:0x80000000 Size:0x20000000
[0001.457] I> 39) Base:0xb0000000 Size:0x08000000
[0001.462] I> 40) Base:0x00000000 Size:0x00000000
[0001.466] I> 41) Base:0x00000000 Size:0x00000000
[0001.471] I> 42) Base:0x00000000 Size:0x00000000
[0001.475] I> 43) Base:0x00000000 Size:0x00000000
[0001.480] I> 44) Base:0x00000000 Size:0x00000000
[0001.484] I> 45) Base:0x00000000 Size:0x00000000
[0001.488] GIC-SPI Target CPU: 0
[0001.491] Interrupts Init done
[0001.494] calling constructors
[0001.497] initializing heap
[0001.500] I> Heap: [0xa069ab80 ... 0xab000000]
[0001.504] initializing threads
[0001.507] initializing timers
[0001.510] creating bootstrap completion thread
[0001.514] top of bootstrap2()
[0001.517] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0001.522] initializing platform
[0001.525] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0001.530] W> device prod register failed
[0001.534] I> Bl_dtb @0xaaf00000
[0001.540] W> "plugin-manager" doesn't exist, creating
[0001.542] W> "ids" doesn't exist, creating
[0001.546] W> "connection" doesn't exist, creating
[0001.550] W> "configs" doesn't exist, creating
[0001.565] E> failed to read label property for node 227404: 13
[0001.568] E> failed to read reg property for node 227492: 13
[0001.570] E> failed to read label property for node 227544: 13
[0001.573] E> failed to read label property for node 227612: 13
[0001.579] E> failed to read label property for node 227648: 13
[0001.584] E> failed to read label property for node 227684: 13
[0001.589] E> failed to read reg property for node 227752: 13
[0001.595] E> failed to read label property for node 227804: 13
[0001.601] I> Find /i2c@3160000's alias i2c0
[0001.604] I> Reading eeprom i2c=0 address=0x50
[0001.633] I> Device at /i2c@3160000:0x50
[0001.633] I> Reading eeprom i2c=0 address=0x56
[0001.658] I> Device at /i2c@3160000:0x56
[0001.659] I> Find /i2c@3180000's alias i2c2
[0001.659] I> Reading eeprom i2c=2 address=0x54
[0001.661] E> I2C: slave not found in slaves.
[0001.661] E> I2C: Could not write 0 bytes to slave: 0x00a8 with repeat start true.
[0001.662] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.663] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa8 at 0x00000000 via instance 2.
[0001.672] E> eeprom: Failed to read I2C slave device
[0001.677] I> Eeprom read failed 0x3526070d
[0001.681] I> Reading eeprom i2c=2 address=0x57
[0001.685] E> I2C: slave not found in slaves.
[0001.689] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start true.
[0001.697] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.702] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 2.
[0001.712] E> eeprom: Failed to read I2C slave device
[0001.717] I> Eeprom read failed 0x3526070d
[0001.721] I> Reading eeprom i2c=2 address=0x52
[0001.725] E> I2C: slave not found in slaves.
[0001.729] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0001.737] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.743] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 2.
[0001.752] E> eeprom: Failed to read I2C slave device
[0001.757] I> Eeprom read failed 0x3526070d
[0001.762] I> Find /i2c@c240000's alias i2c1
[0001.765] I> Reading eeprom i2c=1 address=0x52
[0001.771] E> I2C: slave not found in slaves.
[0001.773] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0001.781] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.787] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 1.
[0001.796] E> eeprom: Retry to read I2C slave device.
[0001.801] E> I2C: slave not found in slaves.
[0001.805] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0001.813] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.819] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 1.
[0001.828] E> eeprom: Failed to read I2C slave device
[0001.833] I> Eeprom read failed 0x3526070d
[0001.837] I> Reading eeprom i2c=1 address=0x50
[0001.841] E> I2C: slave not found in slaves.
[0001.845] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.853] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.859] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.868] E> eeprom: Retry to read I2C slave device.
[0001.873] E> I2C: slave not found in slaves.
[0001.877] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.885] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.890] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.900] E> eeprom: Failed to read I2C slave device
[0001.905] I> Eeprom read failed 0x3526070d
[0001.909] I> create_pm_ids: id: 2888-0004-400-K, len: 15
[0001.914] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0001.925] I> create_pm_ids: id: 2822-0000-600-G, len: 15
[0001.930] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0001.941] I> Adding plugin-manager/ids/2888-0004-400=/i2c@3160000:module@0x50
[0001.949] W> "i2c@3160000" doesn't exist, creating
[0001.953] W> "module@0x50" doesn't exist, creating
[0001.958] I> Adding plugin-manager/ids/2822-0000-600=/i2c@3160000:module@0x56
[0001.965] W> "module@0x56" doesn't exist, creating
[0001.970] I> Adding plugin-manager/cvm
[0001.973] W> "chip-id" doesn't exist, creating
[0001.977] I> Adding plugin-manager/chip-id/A02
[0001.981] I> Plugin-manager override starting
[0001.986] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0001.994] I> node /plugin-manager/fragement-soft-wdt matches
[0002.002] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0002.006] I> node /plugin-manager/fragment-tegra-ufs-lane10 matches
[0002.018] I> Disable plugin-manager status in FDT
[0002.019] I> Plugin-manager override finished successfully
[0002.019] I> gpio framework initialized
[0002.023] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driver
[0002.031] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon' driver
[0002.037] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x46
[0002.045] W> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0002.052] W> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0002.059] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0002.065] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x44
[0002.072] W> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0002.080] W> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0002.087] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0002.094] I> fixed regulator driver initialized
[0002.106] I> register 'maxim' power off handle
[0002.107] I> virtual i2c enabled
[0002.107] I> registered 'maxim,max20024' pmic
[0002.109] I> tegrabl_gpio_driver_register: register 'max20024-gpio' driver
[0002.115] I> Boot-device: eMMC
[0002.118] I> Boot_device: SDMMC_BOOT instance: 3
[0002.127] I> sdmmc-3 params source = boot args
[0002.127] I> create_pm_ids: id: 2888-0004-400-K, len: 15
[0002.132] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0002.143] I> create_pm_ids: id: 2822-0000-600-G, len: 15
[0002.148] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0002.159] I> sdmmc bdev is already initialized
[0002.164] I> sdmmc-3 params source = boot args
[0002.194] I> Found 17 partitions in SDMMC_BOOT (instance 3)
[0002.207] I> Found 43 partitions in SDMMC_USER (instance 3)
[0002.218] I> enabling 'vdd-hdmi-5v0' regulator
[0002.224] I> regulator 'vdd-hdmi-5v0' already enabled
[0002.224] I> hdmi cable connected
[0002.227] W> set volts not configured for 'vdd-1v0'
[0002.229] W> set volts not configured for 'vdd-1v8-hs'
[0002.230] I> retrieved tmds range from prod_list_hdmi_soc
[0002.235] E> invalid display type
[0002.239] E> invalid display type
[0002.240] E> cannot find any other nvdisp nodes
[0002.256] I> edid read success
[0002.268] I> edid read success
[0002.268] I> width = 640, height = 480, frequency = 25174825
[0002.269] I> width = 1920, height = 1080, frequency = 148500000
[0002.269] I> width = 1280, height = 720, frequency = 74250000
[0002.270] I> width = 640, height = 480, frequency = 25174825
[0002.270] I> width = 720, height = 480, frequency = 26973026
[0002.274] I> width = 720, height = 480, frequency = 26973026
[0002.279] I> width = 1280, height = 720, frequency = 74175824
[0002.285] I> width = 1920, height = 1080, frequency = 148351648
[0002.291] I> Best mode Width = 1920, Height = 1080, freq = 148351648
[0002.301] I> hdmi_enable, starting HDMI initialisation
[0002.306] I> hdmi_enable, HDMI initialisation complete
[0002.316] I> Load in CBoot Boot Options partition and parse it
[0002.323] E> Error -9 when finding node with path /boot-configuration
[0002.323] E> tegrabl_cbo_parse_info: "boot-configuration" not found in CBO file.
[0002.326] I> Using default boot order
[0002.330] I> boot-dev-order :-
[0002.333] I> 1.sd
[0002.334] I> 2.usb
[0002.336] I> 3.nvme
[0002.338] I> 4.emmc
[0002.340] I> 5.net
[0002.342] I> Hit any key to stop autoboot: 4 3 2 1
[0004.350] initializing target
[0004.350] calling apps_init()
[0004.351] starting app kernel_boot_app
[0004.370] I> found decompressor handler: lz4-legacy
[0004.371] I> decompressing BMP blob ...
[0004.382] I> Kernel type = Normal
[0004.383] I> ########## SD (0) boot ##########
[0004.383] I> No sdcard
[0004.383] I> sdcard-0 params source = DT-BL
[0004.384] E> Blockdev open: exit error
[0004.384] E> SD boot failed, err: 724238353
[0004.384] I> ########## USB (0) boot ##########
[0004.395] I> Validate XUSB-FW ...
[0004.396] I> T19x: Authenticate XUSB-FW (bin_type: 11), max size 0x28000
[0004.397] I> Encryption fuse is not ON
[0004.398] I> USB Firmware Version: 60.09 release
[0004.456] I> regulator of usb2-0 already enabled
[0004.465] I> regulator of usb2-1 already enabled
[0004.474] I> regulator of usb2-2 already enabled
[0004.485] I> enabling 'vdd-5v-sata' regulator
[0005.554] I> USB 2.0 port 4 new low-speed USB device detected
[0005.556] W> WARNING: event and command not matching, cmd_trb_ptr = 0xa4ad3000, cmd_ring.dma = 0xa4ad30c0
[0005.657] I> Start to enumerate device
[0005.658] W> handle_command_completion_event: WARNING: Command was not successfully completed (0x11)
[0008.666] W> xusbh_wait_irq: Timed out! status = 0x00
[0011.674] W> xusbh_wait_irq: Timed out! status = 0x00
[0011.675] E> Failed to enumerate USB device
[0011.675] E> failed to start xhci controller
[0011.675] E> Error in init of XUSB host driver, err: 7979000c
[0011.676] W> Failed to initialize device 5-0
[0011.676] E> USB boot failed, err: 2037973004
[0011.676] I> ########## NVME (0) boot ##########
[0011.681] I> Initializing nvme device instance 0
[0011.685] I> Initializing nvme controller
[0011.689] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14180000
[0011.695] I> vpcie3v3-supply not found
[0011.699] I> vpcie12v-supply not found
[0011.703] W> Failed to get nvidia,plat-gpios
[0011.707] I> tegrabl_pcie_soc_preinit: (0):
[0011.711] I> Unpowergate
[0011.713] I> tegrabl_car_clk_disable(0) ...
[0011.717] I> tegrabl_car_rst_set(CORE, 0) ...
[0011.721] I> tegrabl_car_rst_set(APB, 0) ...
[0011.725] I> tegrabl_car_clk_enable(0) ...
[0011.729] I> tegrabl_car_rst_clear(APB, 0) ...
[0011.734] I> tegrabl_set_ctrl_state(0)
[0011.737] I> CLR PCIE_APB:6
[0011.740] I> tegrabl_pcie_soc_init: (0):
[0011.744] I> APPL initialization ...
[0011.747] I> poweron phys
[0011.750] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14180000
[0011.756] I> tegrabl_power_on_phy: power on phy @0x3e30000
[0011.761] I> tegrabl_power_on_phy: power on phy @0x3e40000
[0011.767] I> tegrabl_power_on_phy: power on phy @0x3e50000
[0011.772] I> tegrabl_power_on_phy: power on phy @0x3e60000
[0012.877] C> Failed to link up controller-0
[0012.878] I> PCIe (0) Link is not UP
[0012.878] W> Failed tegrabl_pcie_soc_init(), error=0x12
[0012.879] I> Failed to initialize SoC Host PCIe controller
[0012.879] E> tegrabl_nvme_init: Failed tegrabl_pcie_init(0); error=0x12
[0012.880] W> tegrabl_nvme_bdev_open: Failed NVME INIT; error=0x80800612
[0012.883] W> Failed to open NVME-0, err = 80800612
[0012.888] W> Failed to initialize device 10-0
[0012.892] E> NVME (0) boot failed, err: 0x80800612
[0012.897] I> ########## NVME (1) boot ##########
[0012.901] I> Initializing nvme device instance 1
[0012.905] I> Initializing nvme controller
[0012.910] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14100000
[0012.916] I> vpcie3v3-supply not found
[0012.919] I> vpcie12v-supply not found
[0012.923] W> Failed to get nvidia,plat-gpios
[0012.927] I> tegrabl_pcie_soc_preinit: (1):
[0012.931] I> Unpowergate
[0012.934] I> tegrabl_car_clk_disable(1) ...
[0012.937] I> tegrabl_car_rst_set(CORE, 1) ...
[0012.942] I> tegrabl_car_rst_set(APB, 1) ...
[0012.946] I> tegrabl_car_clk_enable(1) ...
[0012.950] I> tegrabl_car_rst_clear(APB, 1) ...
[0012.954] I> tegrabl_set_ctrl_state(1)
[0012.958] I> CLR PCIE_APB:6
[0012.960] I> tegrabl_pcie_soc_init: (1):
[0012.964] I> APPL initialization ...
[0012.967] I> poweron phys
[0012.970] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14100000
[0012.976] I> tegrabl_power_on_phy: power on phy @0x3e10000
[0013.083] I> PCIe controller-1 link is up
[0013.083] I> tegra_pcie_info[1].cfg0_base = 0x30000000
[0013.084] I> tegra_pcie_info[1].cfg1_base = 0x30020000
[0013.084] I> tegra_pcie_info[1].atu_dma_base = 0x30040000
[0013.085] I> tegra_pcie_bus[1].mem = 0x30200000
[0013.085] I> Scanning busnr: 0 devfn: 0
[0013.085] I> PCIe IDs: 0x1ad210de
[0013.088] I> PCIe RID_CC: 0x60400a1
[0013.092] I> Scanning busnr: 1 devfn: 0
[0013.095] I> PCIe IDs: 0x91711b4b
[0013.099] I> PCIe RID_CC: 0x1060113
[0013.102] I> PCI Config: I/O=0x30100000, Memory=0x30200000
[0013.107] I> IO bar_num=0 bar=0x30100000
[0013.111] I> IO bar_num=1 bar=0x30100008
[0013.115] I> IO bar_num=2 bar=0x30100010
[0013.119] I> IO bar_num=3 bar=0x30100018
[0013.122] I> IO bar_num=4 bar=0x30100020
[0013.126] I> MEM bar_num=5 bar=0x30200000
[0013.130] I> Number of PCIe devices detected: 2
[0013.134] E> tegrabl_nvme_init: Failed tegrabl_pcie_get_dev(1); error=0x0
[0013.141] I> PCIe (1) link is UP
[0013.154] E> Link didn't transition to L2 state
[0013.185] W> tegrabl_nvme_bdev_open: Failed NVME INIT; error=0x80800612
[0013.185] W> Failed to open NVME-1, err = 80800612
[0013.186] W> Failed to initialize device 10-1
[0013.186] E> NVME (1) boot failed, err: 0x80800612
[0013.186] I> ########## NVME (2) boot ##########
[0013.187] I> Initializing nvme device instance 2
[0013.189] I> Initializing nvme controller
[0013.193] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14120000
[0013.199] I> vpcie3v3-supply not found
[0013.202] I> vpcie12v-supply not found
[0013.206] W> Failed to get nvidia,plat-gpios
[0013.210] I> tegrabl_pcie_soc_preinit: (2):
[0013.214] I> Unpowergate
[0013.217] I> tegrabl_car_clk_disable(2) ...
[0013.221] I> tegrabl_car_rst_set(CORE, 2) ...
[0013.225] I> tegrabl_car_rst_set(APB, 2) ...
[0013.229] I> tegrabl_car_clk_enable(2) ...
[0013.233] I> tegrabl_car_rst_clear(APB, 2) ...
[0013.237] I> tegrabl_set_ctrl_state(2)
[0013.241] I> CLR PCIE_APB:6
[0013.243] I> tegrabl_pcie_soc_init: (2):
[0013.247] I> APPL initialization ...
[0013.250] I> poweron phys
[0013.253] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14120000
[0013.259] I> tegrabl_power_on_phy: controller 2 not available
[0013.265] E> Failed to power on phy on controller-2
[0013.270] I> PCIe (2) Link is not UP
[0013.273] W> Failed tegrabl_pcie_soc_init(), error=0x1
[0013.278] I> Failed to initialize SoC Host PCIe controller
[0013.283] E> tegrabl_nvme_init: Failed tegrabl_pcie_init(2); error=0x1
[0013.290] W> tegrabl_nvme_bdev_open: Failed NVME INIT; error=0x80800601
[0013.296] W> Failed to open NVME-2, err = 80800601
[0013.301] W> Failed to initialize device 10-2
[0013.305] E> NVME (2) boot failed, err: 0x80800601
[0013.310] I> ########## NVME (3) boot ##########
[0013.314] I> Initializing nvme device instance 3
[0013.319] I> Initializing nvme controller
[0013.323] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14140000
[0013.329] I> vpcie3v3-supply not found
[0013.332] I> vpcie12v-supply not found
[0013.336] W> Failed to get nvidia,plat-gpios
[0013.340] I> tegrabl_pcie_soc_preinit: (3):
[0013.344] I> Unpowergate
[0013.347] I> tegrabl_car_clk_disable(3) ...
[0013.351] I> tegrabl_car_rst_set(CORE, 3) ...
[0013.355] I> tegrabl_car_rst_set(APB, 3) ...
[0013.359] I> tegrabl_car_clk_enable(3) ...
[0013.363] I> tegrabl_car_rst_clear(APB, 3) ...
[0013.367] I> tegrabl_set_ctrl_state(3)
[0013.371] I> CLR PCIE_APB:6
[0013.373] I> tegrabl_pcie_soc_init: (3):
[0013.377] I> APPL initialization ...
[0013.380] I> poweron phys
[0013.383] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14140000
[0013.389] I> tegrabl_power_on_phy: power on phy @0x3e80000
[0014.495] C> Failed to link up controller-3
[0014.495] I> PCIe (3) Link is not UP
[0014.496] W> Failed tegrabl_pcie_soc_init(), error=0x12
[0014.496] I> Failed to initialize SoC Host PCIe controller
[0014.497] E> tegrabl_nvme_init: Failed tegrabl_pcie_init(3); error=0x12
[0014.497] W> tegrabl_nvme_bdev_open: Failed NVME INIT; error=0x80800612
[0014.501] W> Failed to open NVME-3, err = 80800612
[0014.505] W> Failed to initialize device 10-3
[0014.509] E> NVME (3) boot failed, err: 0x80800612
[0014.514] I> ########## NVME (4) boot ##########
[0014.518] I> Initializing nvme device instance 4
[0014.523] I> Initializing nvme controller
[0014.527] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14160000
[0014.533] I> vpcie3v3-supply not found
[0014.537] I> vpcie12v-supply not found
[0014.540] W> Failed to get nvidia,plat-gpios
[0014.544] I> tegrabl_pcie_soc_preinit: (4):
[0014.548] I> Unpowergate
[0014.551] I> tegrabl_car_clk_disable(4) ...
[0014.555] I> tegrabl_car_rst_set(CORE, 4) ...
[0014.559] I> tegrabl_car_rst_set(APB, 4) ...
[0014.563] I> tegrabl_car_clk_enable(4) ...
[0014.567] I> tegrabl_car_rst_clear(APB, 4) ...
[0014.571] I> tegrabl_set_ctrl_state(4)
[0014.575] I> CLR PCIE_APB:6
[0014.578] I> tegrabl_pcie_soc_init: (4):
[0014.581] I> APPL initialization ...
[0014.585] I> poweron phys
[0014.588] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14160000
[0014.594] I> tegrabl_power_on_phy: controller 4 not available
[0014.599] E> Failed to power on phy on controller-4
[0014.604] I> PCIe (4) Link is not UP
[0014.608] W> Failed tegrabl_pcie_soc_init(), error=0x1
[0014.612] I> Failed to initialize SoC Host PCIe controller
[0014.618] E> tegrabl_nvme_init: Failed tegrabl_pcie_init(4); error=0x1
[0014.624] W> tegrabl_nvme_bdev_open: Failed NVME INIT; error=0x80800601
[0014.631] W> Failed to open NVME-4, err = 80800601
[0014.635] W> Failed to initialize device 10-4
[0014.639] E> NVME (4) boot failed, err: 0x80800601
[0014.644] I> ########## NVME (5) boot ##########
[0014.648] I> Initializing nvme device instance 5
[0014.653] I> Initializing nvme controller
[0014.657] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x141a0000
[0014.663] I> i=0, reg_phandle=0x1b
[0014.669] I> reg_voltage=3300000
[0014.669] I> tegrabl_pcie_enable_regulators: regulator_set_voltage(0x1b, 3300000)
[0014.682] I> enabling 'vdd-3v3-pcie' regulator
[0014.683] I> i=1, reg_phandle=0x1c
[0014.687] I> reg_voltage=1200000
[0014.687] I> tegrabl_pcie_enable_regulators: regulator_set_voltage(0x1c, 1200000)
[0014.700] I> enabling 'vdd-12v-pcie' regulator
[0014.701] I> tegrabl_pcie_soc_preinit: (5):
[0014.703] I> Unpowergate
[0014.706] I> tegrabl_car_clk_disable(5) ...
[0014.710] I> tegrabl_car_rst_set(CORE, 5) ...
[0014.714] I> tegrabl_car_rst_set(APB, 5) ...
[0014.718] I> tegrabl_car_clk_enable(5) ...
[0014.722] I> tegrabl_car_rst_clear(APB, 5) ...
[0014.726] I> tegrabl_set_ctrl_state(5)
[0014.730] I> CLR PCIE_APB:6
[0014.732] I> tegrabl_pcie_soc_init: (5):
[0014.736] I> APPL initialization ...
[0014.739] I> poweron phys
[0014.742] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x141a0000
[0014.748] I> tegrabl_power_on_phy: power on phy @0x3eb0000
[0014.754] I> tegrabl_power_on_phy: power on phy @0x3ec0000
[0014.759] I> tegrabl_power_on_phy: power on phy @0x3ed0000
[0014.764] I> tegrabl_power_on_phy: power on phy @0x3ee0000
[0014.770] I> tegrabl_power_on_phy: power on phy @0x3ef0000
[0014.775] I> tegrabl_power_on_phy: power on phy @0x3f00000
[0014.780] I> tegrabl_power_on_phy: power on phy @0x3f10000
[0014.786] I> tegrabl_power_on_phy: power on phy @0x3f20000
[0015.891] C> Failed to link up controller-5
[0015.891] I> PCIe (5) Link is not UP
[0015.892] I> tegrabl_pcie_disable_regulators: disable regulator 0x1b
[0015.895] I> disabling 'vdd-3v3-pcie' regulator
[0015.896] I> tegrabl_pcie_disable_regulators: disable regulator 0x1c
[0015.899] I> disabling 'vdd-12v-pcie' regulator
[0015.899] W> Failed tegrabl_pcie_soc_init(), error=0x12
[0015.900] I> Failed to initialize SoC Host PCIe controller
[0015.905] E> tegrabl_nvme_init: Failed tegrabl_pcie_init(5); error=0x12
[0015.912] W> tegrabl_nvme_bdev_open: Failed NVME INIT; error=0x80800612
[0015.918] W> Failed to open NVME-5, err = 80800612
[0015.923] W> Failed to initialize device 10-5
[0015.927] E> NVME (5) boot failed, err: 0x80800612
[0015.931] I> ########## Fixed storage boot ##########
[0015.936] I> Loading kernel-bootctrl from partition
[0015.941] I> Loading partition kernel-bootctrl at 0xa4b30000 from device(0x1)
[0015.954] W> tegrabl_get_kernel_bootctrl: magic number(0x00000000) is invalid
[0015.955] W> tegrabl_get_kernel_bootctrl: use default dummy boot control data
[0015.968] I> Already published: 00010003
[0015.968] I> Look for boot partition
[0015.969] I> Fallback: assuming 0th partition is boot partition
[0015.975] I> Set 0th partition is boot partition
[0015.980] I> Detect filesystem
[0016.007] I> Loading extlinux.conf ...
[0016.007] I> Loading extlinux.conf binary from rootfs ...
[0016.007] I> rootfs path: /sdmmc_user/boot/extlinux/extlinux.conf
[0016.050] I> ext4_read_data_from_extent:298: Total file read should not be larger than file stat size
[0016.051] E> file /sdmmc_user/boot/extlinux/extlinux.conf read failed!!
[0016.051] W> Failed to load extlinux.conf binary from rootfs (err=202113305)
[0016.052] E> Failed to find/load /boot/extlinux/extlinux.conf
[0016.053] I> Loading kernel ...
[0016.056] I> No kernel binary path
[0016.059] I> Continue to load from partition ...
[0016.064] I> A/B: bin_type (37) slot 0
[0016.067] I> Loading kernel from partition
[0016.071] I> Loading partition kernel at 0xa4b30000 from device(0x1)
[0016.567] I> Validate kernel ...
[0016.567] I> T19x: Authenticate kernel (bin_type: 37), max size 0x5000000
[0016.568] E> Stage2Signature validation failed with SHA2!!
[0016.568] C> OEM authentication of kernel header failed!
[0016.569] E> Failed to validate kernel binary from partition (err=1077936152)
[0016.569] I> Checking boot.img header magic ... [0016.573] E> Invalid header magic
[0016.577] E> Failed to load kernel, abort booting.
[0016.581] E> Failed extlinux boot.
[0016.585] I> SMD partition is updated.
[0016.636] I> Kernel EP: 0x0, DTB: 0x90000000
[0016.637]
[0016.637] -----------------------------------------------
[0016.639] Synchronous Exception: UNKNOWN EXCEPTION
[0016.641] -----------------------------------------------
[0016.643]
[0016.643] ESR 0x2000000: ec 0x0, il 0x1, iss 0x0
[0016.645] -----------------------------------------------
[0016.647] [Stack Trace]
[0016.648]
[0016.648] => pc:0x00000000, sp:0xA0EAE530
[0016.650] => pc:0xA060F7E4, sp:0xA0EAE760
[0016.654] => pc:0xA060F7F8, sp:0xA0EAE7B0
[0016.658] => pc:0xA060F5E0, sp:0xA0EAE7E0
[0016.662] => pc:0xA060EB54, sp:0xA0EAE7F0
[0016.665] => pc:0xA060EB28, sp:0xA0EAE800
[0016.669] -----------------------------------------------
[0016.674] iframe 0xa0eae440:
[0016.677] x0 0x 90000000 x1 0x 0 x2 0x 0 x3 0x 0
[0016.686] x4 0x 0 x5 0x 20 x6 0x b200123 x7 0x ffffffc0
[0016.695] x8 0x 0 x9 0xffffffffffffffff x10 0x 6 x11 0x 2
[0016.704] x12 0x 1 x13 0x 40 x14 0x 1 x15 0x 2c0
[0016.714] x16 0x 1500 x17 0x 438 x18 0x 0 x19 0x 0
[0016.723] x20 0x 0 x21 0x 0 x22 0x 0 x23 0x 0
[0016.732] x24 0x 0 x25 0x 0 x26 0x 0 x27 0x 0
[0016.741] x28 0x 0 x29 0x a0eae760 lr 0x a060f798 sp 0x a0eae530
[0016.750] elr 0x 0
[0016.753] spsr 0x 400003c9
[0016.756] -----------------------------------------------
[0016.761] panic (caller 0xa0601238): die
[0016.765] HALT: spinning forever...
