I have bought a seed’s lab j101 carrie board ,link below
After I flash it with jetpack 4.4 , the carrier board is not able to detect the SD Card.
What is the reason and how will I resolve this issue ?
Did you follow their instructions? Custom carrier boards require changes to software (so you couldn’t just flash without following all of the setup). I see they have a fairly extensive list of instructions for boot from SD card. It would also depend on what you mean by “can’t detect”. Does it boot, but not to the SD card? Does it not even try to boot? Did you get a serial console boot log (which would be needed regardless of who helps…I see they have a forum as well, but it is for their specific products)?
