Unable to flash a Jestson TX2i module using SKDManager on Ubuntu 18-04
I am not able to flush a Jestson TX2i module using SKDManager on Ubuntu 18-04.
The usb connection is on all the time (monitored it separately) and I am following the instructions to:
Power on the Jetson TX2i while holding down the FORCE RECOVERY button and pressing the RESET button. Then realese the RESET button and after a while the FORCE RECOVERY button. The gui for sdkmanagers displayed the appropriate messages during this process. Here is the error I am getting:
10:21:45 ERROR: Flash Jetson TX2 - flash: File “/home/labuser/nvidia/nvidia_sdk/JetPack_4.6.4_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/tegraflash.py”, line 1296, in
10:21:45 ERROR: Flash Jetson TX2 - flash: tegraflash_run_commands()
10:21:45 ERROR: Flash Jetson TX2 - flash: File “/home/labuser/nvidia/nvidia_sdk/JetPack_4.6.4_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/tegraflash.py”, line 1155, in tegraflash_run_commands
10:21:45 ERROR: Flash Jetson TX2 - flash: interpreter.onecmd(command)
10:21:45 ERROR: Flash Jetson TX2 - flash: File “/usr/lib/python3.6/cmd.py”, line 217, in onecmd
10:21:45 ERROR: Flash Jetson TX2 - flash: return func(arg)
10:21:45 ERROR: Flash Jetson TX2 - flash: File “/home/labuser/nvidia/nvidia_sdk/JetPack_4.6.4_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/tegraflash.py”, line 785, in do_dump
10:21:45 ERROR: Flash Jetson TX2 - flash: tegraflash_dump(exports, args)
10:21:45 ERROR: Flash Jetson TX2 - flash: File “/home/labuser/nvidia/nvidia_sdk/JetPack_4.6.4_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/tegraflash_internal.py”, line 1375, in tegraflash_dump
10:21:45 ERROR: Flash Jetson TX2 - flash: tegraflash_dumpeeprom(args, dump_args[1:])
10:21:45 ERROR: Flash Jetson TX2 - flash: File “/home/labuser/nvidia/nvidia_sdk/JetPack_4.6.4_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/tegraflash_internal.py”, line 1453, in tegraflash_dumpeeprom
10:21:45 ERROR: Flash Jetson TX2 - flash: run_command(command)
10:21:45 ERROR: Flash Jetson TX2 - flash: File “/home/labuser/nvidia/nvidia_sdk/JetPack_4.6.4_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/tegraflash_internal.py”, line 202, in run_command
10:21:45 ERROR: Flash Jetson TX2 - flash: log = print_process(process, enable_print)
10:21:45 ERROR: Flash Jetson TX2 - flash: File “/home/labuser/nvidia/nvidia_sdk/JetPack_4.6.4_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/tegraflash_internal.py”, line 178, in print_process
10:21:45 ERROR: Flash Jetson TX2 - flash: for string in process.communicate()[0].decode(‘utf-8’).split(‘\n’):
10:21:45 ERROR: Flash Jetson TX2 - flash: UnicodeDecodeError: ‘utf-8’ codec can’t decode byte 0xa4 in position 16: invalid start byte
10:21:45 ERROR: Flash Jetson TX2 - flash: — Error: Reading board information failed.
10:21:45 INFO: Flash Jetson TX2 - flash: [ Component Install Finished with Error ]
10:21:45 INFO: Flash Jetson TX2 - flash: [host] [ 5.86 MB released. Disk Avail: 141.43 GB ]
10:21:45 INFO: Flash Jetson TX2 - flash: [ NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP Install took 9s ]
10:21:45 ERROR: Flash Jetson TX2 - flash: command terminated with error
can you try if installing with the flashing scripts provided in our BSP helps?
Or go back to JetPack 4.6.3/L4T R32.7.3
https://docs.nvidia.com/jetson/archives/l4t-archived/l4t-3273/index.html
