Unable to flash Jetson AGX Orin 64 GB developer kit with Jetpack 5.1.2 using SDK Manager 2.1.0
After adding the bash function, I get a similar error on flashing
10:46:00 INFO: Flash Jetson Linux - flash: 16896+0 records in
10:46:00 INFO: Flash Jetson Linux - flash: 16896+0 records out
10:46:00 INFO: Flash Jetson Linux - flash: 16896 bytes (17 kB, 16 KiB) copied, 0.0194705 s, 868 kB/s
10:46:00 INFO: Flash Jetson Linux - flash: Writing primary_gpt partition done
10:46:00 ERROR: Flash Jetson Linux - flash: Error: Invalid argument during seek for read on /dev/mmcblk0
10:46:00 ERROR: Flash Jetson Linux - flash: [ 1]: l4t_flash_from_kernel: Error: partprobe failed. This indicates that:
10:46:00 INFO: Flash Jetson Linux - flash: - the xml indicates the gpt is larger than the device storage
10:46:00 INFO: Flash Jetson Linux - flash: - the xml might be invalid
10:46:00 INFO: Flash Jetson Linux - flash: - the device might have a problem.
10:46:00 INFO: Flash Jetson Linux - flash: Please make correction.
10:46:00 INFO: Flash Jetson Linux - flash: Flash failure
10:46:00 INFO: Flash Jetson Linux - flash: Cleaning up..
sdkm logs are attached.
SDKM_logs_JetPack_5.1.2_Linux_for_Jetson_AGX_Orin_modules_2024-05-13_10-41-24.zip (351.7 KB)
