I am currently facing an issue while installing and running Isaac Sim. The following error occurs when I try to run my program:
(isaac-sim) TeleVision_Vuer$ python teleop/teleop_isaacsim.py
File "/home/leehe/Work/TeleVision/TeleVision_Vuer/teleop/teleop_isaacsim.py", line 3, in <module>
from omni.isaac.core import World
File "/home/leehe/.local/share/ov/pkg/isaac-sim-2023.1.1/exts/omni.isaac.core/omni/isaac/core/__init__.py", line 11, in <module>
from omni.isaac.core.physics_context.physics_context import PhysicsContext
File "/home/leehe/.local/share/ov/pkg/isaac-sim-2023.1.1/exts/omni.isaac.core/omni/isaac/core/physics_context/__init__.py", line 9, in <module>
File "/home/leehe/.local/share/ov/pkg/isaac-sim-2023.1.1/exts/omni.isaac.core/omni/isaac/core/physics_context/physics_context.py", line 15, in <module>
from omni.isaac.core.utils.prims import get_prim_at_path, get_prim_path, is_prim_path_valid
File "/home/leehe/.local/share/ov/pkg/isaac-sim-2023.1.1/exts/omni.isaac.core/omni/isaac/core/utils/prims.py", line 19, in <module>
from omni.isaac.core.utils.semantics import add_update_semantics
File "/home/leehe/.local/share/ov/pkg/isaac-sim-2023.1.1/exts/omni.isaac.core/omni/isaac/core/utils/semantics.py", line 12, in <module>
from pxr import Semantics, Usd
ImportError: cannot import name 'Semantics' from 'pxr' (/home/leehe/.conda/envs/isaac-sim/lib/python3.10/site-packages/pxr/__init__.py)
I have also checked the pxr directory in my Python environment, and it appears that the Semantics module is missing:
(isaac-sim) site-packages$ cd pxr
(isaac-sim) pxr$ ls
Ar Pcp Sdr UsdHydra UsdRender UsdUtils
Gf Plug Tf UsdLux UsdRi UsdVol
__init__.py pluginfo Trace UsdMedia UsdShade Vt
Kind __pycache__ Usd UsdPhysics UsdSkel Work
Ndr Sdf UsdGeom UsdProc UsdUI
I installed the pxr module using pip, and I have tried different versions of usd-core (23.11, 23.2, and 23.8), but the issue persists.
Has anyone encountered this problem before? Any guidance on how to resolve this would be greatly appreciated.
