Omni Kit Error - Isaac Sim Implementation
I have found an extension called omni.isaac.jetbot in ~./local/share/ov/pkg/isaac_sim-2021.2.1/standalone_examples/api/
and I want to create a modification of the package using my own urdf model for the robot without changing the original folder. I want to make a separate folder with the code. I placed this directory with formatted code in the api directory and used ./python.sh to execute the code, however, it cannot identify the pxr library nor omni.kit.commands library.
  File "/home/omniverse02/Desktop/Carter_RL_Train/carterbot_env.py", line 6, in <module>
    from pxr import UsdGeom, Gf, Sdf, Usd, PhysxSchema, PhysicsSchema, PhysicsSchemaTools, Semantics
  File "/home/omniverse02/.local/share/ov/pkg/isaac_sim-2021.2.1/kit/extscore/omni.usd.libs/pxr/UsdGeom/__init__.py", line 24, in <module>
    from . import _usdGeom
ImportError: /home/omniverse02/.local/share/ov/pkg/isaac_sim-2021.2.1/kit/extscore/omni.usd.libs/bin/libjs.so: undefined symbol: _ZN32pxrInternal_v0_20__pxrReserved__18Tf_PostErrorHelperERKNS_13TfCallContextENS_16TfDiagnosticTypeEPKcz
There was an error running python
I have tried to follow this tutorial to link isaac sim and vscode to use omni kit extensions and i was able to attach the code debugger, but it is still not executing the code: Debugging extensions and apps
What steps should I be taking in order to get my code to work alongside Isaac Sim using the omni kit package?
The following is an example of one of the files using omni.kit.commands and Pxr:
import carb
import omni
from pxr import UsdGeom, Gf, PhysicsSchema
from omni.isaac.dynamic_control import _dynamic_control
from omni.isaac.utils.scripts.nucleus_utils import find_nucleus_server
import numpy as np
# Camera Parameters
FOCAL_LENGTH = 0.75
HORIZONTAL_APERTURE = 2.350
VERTICAL_APERTURE = 2.350
# Drive Parameters
DRIVE_STIFFNESS = 10000.0
# The amount the camera points down at, decrease to raise camera angle
CAMERA_PIVOT = 40.0
class Carter:
    def __init__(self, omni_kit):
        self.omni_kit = omni_kit
        result, nucleus_server = find_nucleus_server()
        if result is False:
            carb.log_error("Couldl not find nucleus server with /Isaac folder")
            return
        self.usd_path = nucleus_server + "/Isaac/Robots/Carter/carter_v1.usd"
        self.robot_prim = None
        self.dc = _dynamic_control.acquire_dynamic_control_interface()
        self.ar = None
    # rotation is in degrees
    def spawn(self, location, rotation):
        # Understand what this command does, check if you can import the city environment
        stage = self.omni_kit.get_stage()
        prefix = "/World/Robot/Carter"
        prim_path = omni.kit.utils.get_stage_next_free_path(stage, prefix, False)
        self.robot_prim = stage.DefinePrim(prim_path, "Xform")
        self.robot_prim.GetReferences().AddReference(self.usd_path)
        xform = UsdGeom.Xformable(self.robot_prim)
        xform_op = xform.AddXformOp(UsdGeom.XformOp.TypeTransform, UsdGeom.XformOp.PrecisionDouble, "")
        mat = Gf.Matrix4d().SetTranslate(location)
        mat.SetRotateOnly(Gf.Rotation(Gf.Vec3d(0, 0, 1), rotation))
        xform_op.Set(mat)
        self.camera_path = prim_path + "/chassis/rgb_camera/carter_camera"
        self.camera_pivot = prim_path + "/chassis/rgb_camera"
        # Set joint drive parameters
        left_wheel_joint = PhysicsSchema.DriveAPI.Get(
            stage.GetPrimAtPath(f"{prim_path}/chassis/left_wheel_joint"), "angular"
        left_wheel_joint.GetDampingAttr().Set(DRIVE_STIFFNESS)
        right_wheel_joint = PhysicsSchema.DriveAPI.Get(
            stage.GetPrimAtPath(f"{prim_path}/chassic/right_wheel_joint"), "angular"
        right_wheel_joint.GetDampingAttr().Set(DRIVE_STIFFNESS)
    def teleport(self, location, rotation, settle=False):
        if self.ar is None:
            self.ar = self.dc.get_articulation(self.robot_prim.GetPath().pathString)
            self.chassis = self.dc.get_articulation_root_body(self.ar)
        self.dc.wake_up_articulation(self.ar)
        rot_quat = Gf.Rotation(Gf.Vec3d(0,0,1), rotation).GetQuaternion()
        tf = _dynamic_control.Transform(
            location,
            (rot_quat.GetImaginary()[0], rot_quat.GetImaginary()[1], rot_quat.GetImaginary()[2], rot_quat.GetReal()),
        self.dc.set_rigid_body_pose(self.chassis, tf)
        self.dc.set_rigid_body_linear_velocity(self.chassis, [0, 0, 0])
        self.dc.set_rigid_body_angular_velocity(self.chassis, [0, 0, 0])
        self.command((0, 0))
        # Settle the robot onto the ground
        if settle:
            frame = 0
            velocity = 1
            while velocity > 0.1 and frame < 120:
                self.omni_kit.update(1.0 / 60.0)
                lin_vel = self.dc.get_rigid_body_linear_velocity(self.chassis)
                velocity = np.linalg.norm([lin_vel.x, lin_vel.y, lin_vel.z])
                frame = frame + 1
    # Activate the camera on the vehicle
    def activate_camera(self):
        # Set camera parameters
        cameraPrim = UsdGeom.Camera(stage.GetPrimAtPath(self.camera_path))
        cameraPrim.GetFocalLengthAttr().Set(FOCAL_LENGTH)
        cameraPrim.GetHorizontalApertureAttr().Set(HORIZONTAL_APERTURE)
        cameraPrim.GetVerticalApertureAttr().Set(VERTICAL_APERTURE)
        # Point camera down at road
        pivot_prim = stage.GetPrimAtPath(self.camera_pivot)
        transform_attr = pivot_prim.GetAttribute("xformOp:transform")
        transform_attr.Set(
            transform_attr.Get().SetRotateOnly(Gf.Matrix3d(Gf.Rotation(Gf.Vec3d(0, 1, 0), CAMERA_PIVOT)))
        vpi = omni.kit.viewport.get_viewport_interface()
        vpi.get_viewport_window().set_active_camera(str(self.camera_path))
    def command(self, motor_value):
        if self.ar is None:
            self.wheel_left = self.dc.find_articulation_dof(self.ar, "left_wheel_joint")
            self.wheel_right = self.dc.find_articulation_dof(self.ar, "right_wheel_joint")
        left_speed = self.wheel_speed_from_motor_value(motor_value[0])
        right_speed = self.wheel_speed_from_motor_value(motor_value[1])
        self.dc.set_dof_velocity_target(self.wheel_left, np.clip(left_speed, -10, 10))
        self.dc.set_dof_velocity_target(self.wheel_right, np.clip(right_speed, -10, 10))
    # idealized motor model
    def wheel_speed_from_motor_value(self, input):
        return input
    def observations(self):
        if self.ar is None:
        dc_pose = self.dc.get_rigid_body_pose(self.chassis)
        dc_lin_vel = self.dc.get_rigid_body_linear_velocity(self.chassis)
        dc_local_lin_vel = self.dc.get_rigid_body_local_linear_velocity(self.chassis)
        dc_ang_vel = self.dc.get_rigid_body_angular_velocity(self.chassis)
        return {
            "pose": (dc_pose.p.x, dc_pose.p.y, dc_pose.p.z, dc_pose.r.w, dc_pose.r.x, dc_pose.r.y, dc_pose.r.z),
            "linear_velocity": (dc_lin_vel.x, dc_lin_vel.y, dc_lin_vel.z),
            "local_linear_velocity": (dc_local_lin_vel.x, dc_local_lin_vel.y, dc_local_lin_vel.z),
            "angular_velocity": (dc_ang_vel.x, dc_ang_vel.y, dc_ang_vel.z),
Hi @asibarra98
You need to launch a SimulationApp instance before importing those modules.
Cite from SimulationApp docstring:
Omniverse loads various plugins at runtime which cannot be imported unless the Toolkit is already running. Thus, it is necessary to launch the Toolkit first from your python application and then import everything else.
If you check the examples the modules are imported after kit execution, such as:
kit = SimulationApp(launch_config=CONFIG)
from omni.isaac.core.utils.extensions import enable_extension
from omni.isaac.core.utils.stage import set_stage_up_axis, add_reference_to_stage
import omni
