Hi NVIDIA,
So I was trying to instantiate OmnikiHelper defined here in IsaacSim 2020.2:
ISAAC/ISAAC_SIM/_build/linux-x86_64/release/exts/omni.isaac.synthetic_utils/omni/isaac/synthetic_utils/scripts/omnikit.py
then these errors popped out, which seems to render the sim step function failed:
[1.984s] [ext: omni.isaac.manip] startup
2020-11-23 03:18:46 [1,978ms] [Error] [carb.scripting-python.plugin] AttributeError: 'NoneType' object has no attribute 'GetPrimAtPath'
At:
/home/tad/ISAAC/ISAAC_SIM/_build/linux-x86_64/release/exts/omni.isaac.manip/omni/isaac/manip/scripts/extension.py(209): load_bindings
/home/tad/ISAAC/ISAAC_SIM/_build/linux-x86_64/release/exts/omni.isaac.manip/omni/isaac/manip/scripts/extension.py(135): on_startup
/home/tad/ISAAC/ISAAC_SIM/_build/target-deps/kit_sdk_release/_build/linux-x86_64/release/plugins/bindings-python/omni/ext/impl/_internal.py(207): _startup_ext
/home/tad/ISAAC/ISAAC_SIM/_build/target-deps/kit_sdk_release/_build/linux-x86_64/release/plugins/bindings-python/omni/ext/impl/_internal.py(219): startup_all_extensions_in_module
/home/tad/ISAAC/ISAAC_SIM/_build/target-deps/kit_sdk_release/_build/linux-x86_64/release/plugins/bindings-python/omni/ext/impl/_internal.py(253): startup_all_extensions_in_module
/home/tad/ISAAC/ISAAC_SIM/_build/target-deps/kit_sdk_release/_build/linux-x86_64/release(3): <module>
2020-11-23 03:18:46 [1,978ms] [Error] [omni.ext.plugin] [ext: omni.isaac.manip] Failed to process python module extension in '/home/tad/ISAAC/ISAAC_SIM/_build/linux-x86_64/release/exts/omni.isaac.manip/.'.
and
2020-11-23 02:00:30 [3,142ms] [Error] [omni.kit.ui.python] Model.getValueAs() failed (path: "/persistent/audio/context/streamerFile"). Error: Unable to cast Python instance to C++ type (compile in debug mode for details)
[3.151s] [ext: omni.kit.builtin.profiler] startup
[3.152s] [ext: omni.kit.builtin.provide_feedback_window] startup
[3.152s] [ext: omni.kit.builtin.render_settings_window] startup
[3.160s] [ext: omni.kit.builtin.test_runner] startup
[3.168s] [ext: omni.utils.collect_tool] startup
[3.168s] [ext: omni.utils.movie_capture] startup
[3.168s] [ext: omni.utils.utilities_menu] startup
[3.169s] [ext: omni.assetimport] startup
2020-11-23 02:00:30 [3,320ms] [Error] [omni.ui.python] Unable to cast Python instance to C++ type (compile in debug mode for details)
2020-11-23 02:00:30 [3,426ms] [Error] [omni.stageupdate.python] AttributeError: 'NoneType' object has no attribute 'is_flat'
At:
ISAAC/ISAAC_SIM/_build/target-deps/kit_sdk_release/_build/linux-x86_64/release/exts/omni.kit.widget.stage-0.1.0/omni/kit/widget/stage/stage_model.py(386): _on_attach
Would you have any idea about them?
P/s: I specified the parameters as self.update(dt=1/30.0, physics_dt=1/120.0, physics_substeps=4).
