I have a fresh install of Jetpack 6.2 (JetPack SDK | NVIDIA Developer) on an Nvidia Orin Nano. I am trying to install v4l-utils, but I am encountering errors whenever I use apt. It seems impossible to install or uninstall anything, due to errors in nvidia-l4t-* packages. Here is the full output:
$ sudo apt install v4l-utils
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
The following packages were automatically installed and are no longer required:
libslirp0 slirp4netns
Use 'sudo apt autoremove' to remove them.
The following additional packages will be installed:
libv4l2rds0
The following NEW packages will be installed
libv4l2rds0 v4l-utils
0 to upgrade, 2 to newly install, 0 to remove and 0 not to upgrade.
8 not fully installed or removed.
Need to get 669 kB of archives.
After this operation, 2,200 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 http://ports.ubuntu.com/ubuntu-ports jammy/main arm64 libv4l2rds0 arm64 1.22.1-2build1 [17.4 kB]
Get:2 http://ports.ubuntu.com/ubuntu-ports jammy/universe arm64 v4l-utils arm64 1.22.1-2build1 [652 kB]
Fetched 669 kB in 2s (346 kB/s)
debconf: Delaying package configuration, since apt-utils is not installed.
Selecting previously unselected package libv4l2rds0:arm64.
(Reading database ... 200658 files and directories currently installed.)
Preparing to unpack .../libv4l2rds0_1.22.1-2build1_arm64.deb ...
Unpacking libv4l2rds0:arm64 (1.22.1-2build1) ...
Selecting previously unselected package v4l-utils.
Preparing to unpack .../v4l-utils_1.22.1-2build1_arm64.deb ...
Unpacking v4l-utils (1.22.1-2build1) ...
Setting up nvidia-l4t-bootloader (36.4.7-20250918154033) ...
/opt/nvidia/l4t-bootloader-config/nv-l4t-bootloader-config.sh: line 555: warning: command substitution: ignored null byte in input
Error: Unsupported board ID: .
Exiting...
INFO. Dump slots info:
Current version: 36.4.3
Capsule update status: 0
Current bootloader slot: A
Active bootloader slot: A
num_slots: 2
slot: 0, status: normal
slot: 1, status: normal
INFO. Dump nv_boot_control.conf:
TNSPEC ----1-0-jetson-orin-nano-devkit-super-
TEGRA_CHIPID 0x23
TEGRA_OTA_BOOT_DEVICE /dev/mtdblock0
TEGRA_OTA_GPT_DEVICE /dev/mtdblock0
ERROR. Cannot find COMPATIBLE_SPEC in /etc/nv_boot_control.conf.
Starting bootloader post-install procedure.
ERROR. The esp is not mounted to /boot/efi.
dpkg: error processing package nvidia-l4t-bootloader (--configure):
installed nvidia-l4t-bootloader package post-installation script subprocess returned error exit status 1
Setting up libv4l2rds0:arm64 (1.22.1-2build1) ...
Setting up nvidia-l4t-kernel (5.15.148-tegra-36.4.7-20250918154033) ...
Using the existing boot entry 'primary'
Exiting...
Starting kernel post-install procedure.
Rootfs AB is not enabled.
ERROR. Procedure for A_kernel update FAILED.
Cannot install package. Exiting...
dpkg: error processing package nvidia-l4t-kernel (--configure):
installed nvidia-l4t-kernel package post-installation script subprocess returned error exit status 1
dpkg: dependency problems prevent configuration of nvidia-l4t-kernel-headers:
nvidia-l4t-kernel-headers depends on nvidia-l4t-kernel (= 5.15.148-tegra-36.4.7-20250918154033); however:
Package nvidia-l4t-kernel is not configured yet.
dpkg: error processing package nvidia-l4t-kernel-headers (--configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of nvidia-l4t-jetson-io:
nvidia-l4t-jetson-io depends on nvidia-l4t-kernel (>> 5.15.148-tegra-36.4-0); however:
nvidia-l4t-jetson-io depends on nvidia-l4t-kernel (<< 5.15.148-tegra-36.5-0); however:
dpkg: error processing package nvidia-l4t-jetson-io (--configure):
Setting up v4l-utils (1.22.1-2build1) ...
No apport report written because the error message indicates it's a follow-up error from a previous failure.
No apport report written because MaxReports has already been reached
dpkg: dependency problems prevent configuration of nvidia-l4t-kernel-oot-modules:
nvidia-l4t-kernel-oot-modules depends on nvidia-l4t-kernel (= 5.15.148-tegra-36.4.7-20250918154033); however:
dpkg: error processing package nvidia-l4t-kernel-oot-modules (--configure):
dpkg: dependency problems prevent configuration of nvidia-l4t-display-kernel:
nvidia-l4t-display-kernel depends on nvidia-l4t-kernel (= 5.15.148-tegra-36.4.7-20250918154033); however:
dpkg: error processing package nvidia-l4t-display-kernel (--configure):
dpkg: dependency problems prevent configuration of nvidia-l4t-kernel-oot-headers:
nvidia-l4t-kernel-oot-headers depends on nvidia-l4t-kernel (= 5.15.148-tegra-36.4.7-20250918154033); however:
dpkg: error processing package nvidia-l4t-kernel-oot-headers (--configure):
dpkg: dependency problems prevent configuration of nvidia-l4t-kernel-dtbs:
nvidia-l4t-kernel-dtbs depends on nvidia-l4t-kernel (= 5.15.148-tegra-36.4.7-20250918154033); however:
dpkg: error processing package nvidia-l4t-kernel-dtbs (--configure):
Processing triggers for man-db (2.10.2-1) ...
Processing triggers for libc-bin (2.35-0ubuntu3.13) ...
Processing triggers for nvidia-l4t-initrd (36.4.7-20250918154033) ...
Include /etc/nv-update-initrd/list.d/binlist
Include /etc/nv-update-initrd/list.d/modules
nv-update-initrd: Updating /boot/initrd from /etc/nv-update-initrd/list.d for kernel version 5.15.148-tegra..
Add /usr/sbin/nvluks-srv-app
Add /lib/modules/5.15.148-tegra/updates/drivers/net/ethernet/nvidia/nvethernet/nvethernet.ko
Add /lib/modules/5.15.148-tegra/updates/drivers/nvpps/nvpps.ko
Add /lib/modules/5.15.148-tegra/updates/drivers/net/ethernet/realtek/r8126/r8126.ko
Add /lib/modules/5.15.148-tegra/updates/drivers/net/ethernet/realtek/r8168/r8168.ko
Add /lib/modules/5.15.148-tegra/modules*
Add /lib/modules/5.15.148-tegra/kernel/drivers/nvme/host/nvme.ko
Add /lib/modules/5.15.148-tegra/kernel/drivers/nvme/host/nvme-core.ko
Add /lib/modules/5.15.148-tegra/kernel/drivers/thermal/tegra/tegra-bpmp-thermal.ko
Add /lib/modules/5.15.148-tegra/kernel/drivers/pwm/pwm-tegra.ko
Add /lib/modules/5.15.148-tegra/kernel/drivers/hwmon/pwm-fan.ko
Add /lib/modules/5.15.148-tegra/kernel/drivers/pci/controller/dwc/pcie-tegra194.ko
Add /lib/modules/5.15.148-tegra/kernel/drivers/phy/tegra/phy-tegra194-p2u.ko
Add /lib/modules/5.15.148-tegra/kernel/drivers/usb/gadget/udc/tegra-xudc.ko
Add /lib/modules/5.15.148-tegra/kernel/drivers/usb/typec/ucsi/typec_ucsi.ko
Add /lib/modules/5.15.148-tegra/kernel/drivers/usb/typec/ucsi/ucsi_ccg.ko
Add /lib/modules/5.15.148-tegra/kernel/drivers/usb/typec/typec.ko
Updating modprobe.d configuration directories for modprobe..
Add config /etc/modprobe.d/alsa-base.conf
Add config /etc/modprobe.d/bcmdhd.conf
Add config /etc/modprobe.d/blacklist-ath_pci.conf
Add config /etc/modprobe.d/blacklist.conf
Add config /etc/modprobe.d/blacklist-firewire.conf
Add config /etc/modprobe.d/blacklist-framebuffer.conf
Add config /etc/modprobe.d/blacklist-modem.conf
Add config-link /etc/modprobe.d/blacklist-oss.conf
Add config /etc/modprobe.d/blacklist-rare-network.conf
Add config /etc/modprobe.d/denylist-nouveau.conf
Add config /etc/modprobe.d/denylist-oot-modules-audio.conf
Add config /etc/modprobe.d/denylist-ramoops.conf
Add config /etc/modprobe.d/denylist-tegra-safety.conf
Add config /etc/modprobe.d/denylist-tpm-ftpm-tee.conf
Add config /etc/modprobe.d/disable-algif_aead.conf
Add config /etc/modprobe.d/iwlwifi.conf
Add config /etc/modprobe.d/nvgpu.conf
Add config /etc/modprobe.d/nvidia-display.conf
Add config /etc/modprobe.d/tegra-udrm.conf
Add config /lib/modprobe.d/aliases.conf
Add config /lib/modprobe.d/fbdev-blacklist.conf
Add config /lib/modprobe.d/systemd.conf
Cleaning up the temporary directory for updating the initrd..
Errors were encountered while processing:
nvidia-l4t-kernel
E: Sub-process /usr/bin/dpkg returned an error code (1)
