I’m trying to setup my Jetson TX2 and install SDK components on it, but the installation fails with the following error:
Cannot connect to the device via SSH. Validate that SSH service is running on the device.
Based on the log, it seems like flashing was successful, but installation of SDK components is where the problem is. I did go through the forum about some possible fixes and debugging, but so far I’ve been unlucky to get it fixed.
Additionally, not sure if it’s relevant, but a notification keeps popping up on my host device that says:
Connection failed - Activation of network connection failed (even though I have an active WiFi connection)
I’m running Ubuntu 18.04 on my computer, and if it helps, I’ve attached an excerpt of the log as well for reference. Any help with this issue would be appreciated, thanks!
log (2.8 KB)
