Hello .
I’ve got a startup failure while running Omniverse-kit on Ubuntu 22.04.
After running ./repo.sh launch, here is the error message below:
u@PC-Q:~/Documents/00_KIT106/kit-app-template$ ./repo.sh launch
[ctrl+c to Exit]
? Select with arrow keys which App you would like to launch: my_company.my_usd_composer.kit
launching my_company.my_usd_composer.kit!
[Info] [carb] Logging to file: /home/u/.nvidia-omniverse/logs/Kit/My USD Composer/0.1/kit_20250311_160802.log
[0.250s] [ext: omni.kit.async_engine-0.0.1] startup
[0.521s] [ext: omni.client.lib-1.0.0] startup
[0.556s] [ext: omni.metrics.core-0.0.1] startup
[0.556s] [ext: omni.client-1.2.2] startup
[0.564s] [ext: omni.blobkey-1.1.2] startup
[0.564s] [ext: omni.assets.plugins-0.0.0] startup
[0.566s] [ext: omni.datastore-0.0.0] startup
[0.574s] [ext: omni.stats-1.0.1] startup
[0.576s] [ext: omni.hsscclient-1.1.1] startup
[0.577s] [ext: omni.activity.core-1.0.1] startup
[0.579s] [ext: omni.ujitso.default-1.0.0] startup
2025-03-11 08:08:03 [471ms] [Warning] [omni.datastore] OmniHub is inaccessible
[0.586s] [ext: omni.gpu_foundation.shadercache.vulkan-1.0.0] startup
[0.591s] [ext: omni.activity.profiler-1.0.4] startup
[0.594s] [ext: omni.gpu_foundation-0.0.0] startup
[0.617s] [ext: carb.windowing.plugins-1.0.0] startup
[0.633s] [ext: omni.kit.renderer.init-0.0.0] startup
2025-03-11 08:08:03 [581ms] [Error] [omni.platforminfo.plugin] failed to find the package that core 0 belongs to.
2025-03-11 08:08:03 [581ms] [Error] [omni.platforminfo.plugin] failed to find the package that core 1 belongs to.
2025-03-11 08:08:03 [581ms] [Error] [omni.platforminfo.plugin] failed to find the package that core 2 belongs to.
2025-03-11 08:08:03 [581ms] [Error] [omni.platforminfo.plugin] failed to find the package that core 3 belongs to.
2025-03-11 08:08:03 [581ms] [Error] [omni.platforminfo.plugin] failed to find the package that core 4 belongs to.
2025-03-11 08:08:03 [581ms] [Error] [omni.platforminfo.plugin] failed to find the package that core 5 belongs to.
2025-03-11 08:08:03 [581ms] [Error] [omni.platforminfo.plugin] failed to find the package that core 6 belongs to.
//skip
2025-03-11 08:08:03 [582ms] [Error] [omni.platforminfo.plugin] failed to find the package that core 32 belongs to.
2025-03-11 08:08:03 [582ms] [Error] [omni.platforminfo.plugin] all CPU packages were empty! Failed to find any available CPU cores.
2025-03-11 08:08:03 [582ms] [Error] [omni.platforminfo.plugin] failed to retrieve CPU information.
X Error of failed request: GLXBadFBConfig
Major opcode of failed request: 150 (GLX)
Minor opcode of failed request: 0 ()
Serial number of failed request: 225
Current serial number in output stream: 225
[03/11/25 16:08:03] ERROR error running: /home/u/Documents/00_KIT106/kit-app-template/_build/linux-x86_64/release/my_company.my_usd_composer.kit.sh, code: 2, message: "" launch.py:92
We are running on a Ubuntu KVM environment with those settings:
- Kit :Releases · NVIDIA-Omniverse/kit-app-template
- OS: Ubuntu 22.04
- Graphics: NVIDIA L40S-12Q
- Driver Version: 570.124.06
I’ve tried reinstalling the driver by following the instruction but we still have no luck.
Any suggestions would be really appreciated. Thanks again for the help.
