Hi everyone,
I’m setting up Omniverse Nucleus (Enterprise, Docker Compose deployment) and can access the web UI following this method(https://docs.omniverse.nvidia.com/nucleus/latest/enterprise/cloud/cloud_aws_ec2.html). However, I’m stuck at the login screen with the error:
“Wrong credentials or the user does not exist.”
What I’ve done so far:
- Successfully deployed the Nucleus stack via Docker Compose (
nucleus-stack-ssl.yml) - All containers are up and running (confirmed via
docker ps) - NGINX is listening on port 443, and I can
curlthe login page successfully - DNS is correctly routing the domain to the reverse proxy EC2 (checked via
nslookup) - Logs from
nucleus-authshow:
InternalCredentials.auth: { "status": "DENIED" }
- Tried logging in with
omniverse/MASTER_PASSWORD,omniverse/omniverseandadmin/admincredentials, but received the same error. - Tried POSTing to
/omni/auth/internal/register, but got WebSocket error (likely expected due to registration being disabled)
Question:
- Is there a default admin user for Nucleus Enterprise installations (e.g.
omniverse)? - If self-registration is disabled (
can_register: false), how should I create the first user or reset the admin password? - Is there a supported way to bootstrap a user account after initial deployment in Enterprise mode?
Any help would be much appreciated — thanks in advance!
