Hi all,
I forgot my localhost username and password, and haven’t ‘Create Account’ in log in of interface, what can I do to fix it?
@isyihui i am just another user, and the fallback credential that you can use is admin for both fields. from there, you should be able to reset your other account password if you’d like to regain access to the projects saved under that account or simply keep with admin if you are the owner of the comp.
you can also use omniverse for both fields.
Thank you so much! I’ve just connected service of omniverse successfully.
Thank you Simplychenable!
