Can not login with my credentials to connect the server. This is the first time I’m trying
“Wrong credentials or the user does not exist.”
@joyce4 you could try using the fallback credential of admin in both fields and see if it helps.
If you have never logged in, you do not remember your login details? Then you can just delete your local host instantly and re-install a fresh copy and remember them from there. Or as suggested you can use the fallback of “admin” and “admin” to get in. Please do not use complicated usernames and passwords. This is not designed to be a secure system. It is just for you to practice with nucleus. Just make it easy. “Joyce” and “Joyce” are fine.
