this is first i use nucleus , i already change the setting to keep the setting be green but it still “Wrong credentials or the user does not exist.”
I just want to know what is the username and password, it’s i set it when i create the localhost? the username dosnt work, spend heavy time on that
If you did not change the default password then it should be:
Username → admin
Password → admin
you can also try
username:password
omniverse:omniverse
YOU ARE THE MAN
THANK YOOOOOOU
