Unable to Perform Isaac ROS ZED Setup
I followed this getting started guide to use a ZED2 camera with Isaac ROS.
However, at step 6, when I try to run the following command :
colcon build --symlink-install --packages-up-to zed_wrapper
I encounter some compilation issues :
buildOut.txt (19.8 KB)
Additionally, at the end of step 5, I receive the following error:
sudo chmod +x ${ISAAC_ROS_WS}/src/isaac_ros_common/docker/scripts/install-zed-aarch64.sh &&
Running in chroot, ignoring request.
sed: can’t read /etc/systemd/system/nvargus-daemon.service: No such file or directory
ZED SDK installation complete !
I’m not sure what I’m doing wrong. I have followed all the prerequisites :
Setup :
I hope this isn’t a duplicate issue.
Thank you in advance for your help !
Hi @cyprien.menard.act
Thank you for your detailed post. It is possible that the ZED Link driver on the host is not correctly installed
Try to run on your host:
sudo apt install libqt5core5a
Reference: How to use ZED X with Docker - Stereolabs
Best,
Raffaello
Thanks for the response.
Unfortunately, that didn’t resolve the issue.
The package was already installed:
Reading package lists… Done
Building dependency tree… Done
Reading state information… Done
libqt5core5a is already the newest version (5.15.3+dfsg-2ubuntu0.2).
libqt5core5a set to manually installed.
0 upgraded, 0 newly installed, 0 to remove and 72 not upgraded.
I removed the Docker image and rebuilt it to ensure a clean base environment.
I noticed there are other topics with similar issues. I’m investigating with the engineering team. I’ll keep you posted
Could you please share the links to the related topics so I can follow the progress?
We are currently working to fix this issue, and a minor update will be released soon.
Thank you for following up on this thread.
Best,
Raffafello
