As part of a project, I’m trying to move positions, rotations of a mesh that is part of a larger mesh. I cannot apply pose changes or even get the camera to look at the sub-item.
Been having some problems with using ‘look_at’ for anything other than a top level xform object. In the example below when I focus on the worker object (in tutorial worker example) the camera changes rotation appropriately but when I show a sub-item like the ‘baseball_cap’ , it doesn’t seem to work. Anyone has any ideas?
baseball_cap = rep.get.prims(path_pattern="/Replicator/Ref_03/ManRoot/Worker/Baseball_cap")
main_prim = rep.get.prims(path_pattern="/Replicator/Ref_01")
with rep.trigger.on_frame(num_frames=10000):
rep.randomizer.env_props(75)
rep.randomizer.worker()
with camera:
# this works, camera focusses on main_prim
rep.modify.pose(position=rep.distribution.uniform((-50, 200, 50), (500, 500, 50)), look_at=main_prim)
# the following does not work
rep.modify.pose(position=rep.distribution.uniform((-50, 200, 50), (500, 500, 50)), look_at=baseball_cap)
