Thank you for your response. It worked. But I got another segmentation fault while working on it.
I was trying to load Dofbot sample application.
It did not work as per the steps in the link. https://docs.omniverse.nvidia.com/app_isaacsim/app_isaacsim/sample_dofbot.html
I mean, it did not load the DofBot.
The steps I followed was,
Isaac Examples → Controlling → Manipulation → DofBot Picking.
Since that was not working, I went into the examples, and selected DofBot.usd (Isaac/Robots/Dofbot/dofbot.usd), and it crashed. (1st log)
I tried to run the docker run command again, with the --entrypoint flag, and it crashed again and again. (logs 2 and 3).
Can you please suggest what I shall do?
docker_logs_2.zip (1.6 MB)
Below is the crash log for the 1st case.
2021-10-11 20:15:29 [3,176,261ms] [Fatal] [carb.crashreporter-breakpad.plugin] libcarb.tasking.plugin.so!std::thread::_State_impl<std::thread::_Invoker<std::tuple<void (carb::tasking::Scheduler::)(unsigned int, int, carb::cpp20::latch), carb::tasking::Scheduler*, unsigned int, int, carb::cpp20::latch*> > >::_M_run()
2021-10-11 20:15:29 [3,176,269ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.usd.so!std::_Function_base::_Base_manageromni::usd::OmniUsdMessenger::Impl::Impl(omni::usd::UsdContext*):{lambda(carb::events::IEvent*)#1}::_M_manager(std::_Any_data&, std::_Function_base::_Base_manageromni::usd::OmniUsdMessenger::Impl::Impl(omni::usd::UsdContext*):{lambda(carb::events::IEvent*)#1} const&, std::_Manager_operation)
2021-10-11 20:15:29 [3,176,278ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpthread.so.0!funlockfile
2021-10-11 20:15:29 [3,176,285ms] [Fatal] [carb.crashreporter-breakpad.plugin] librtx.neuraylib.plugin.so!std::basic_string<char, std::char_traits, std::allocator > std::operator+<char, std::char_traits, std::allocator >(std::basic_string<char, std::char_traits, std::allocator >&&, char const*)
2021-10-11 20:15:29 [3,176,294ms] [Fatal] [carb.crashreporter-breakpad.plugin] librtx.neuraylib.plugin.so!std::__detail::_Compiler<std::regex_traits >::_M_assertion()
2021-10-11 20:15:29 [3,176,300ms] [Fatal] [carb.crashreporter-breakpad.plugin] librtx.neuraylib.plugin.so!std::__detail::_Compiler<std::regex_traits >::_M_assertion()
2021-10-11 20:15:29 [3,176,307ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.usd.so!std::basic_string<char, std::char_traits, std::allocator > std::operator+<char, std::char_traits, std::allocator >(std::basic_string<char, std::char_traits, std::allocator >&&, char const*)
2021-10-11 20:15:29 [3,176,313ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.usd.so!std::basic_string<char, std::char_traits, std::allocator > std::operator+<char, std::char_traits, std::allocator >(std::basic_string<char, std::char_traits, std::allocator >&&, char const*)
2021-10-11 20:15:29 [3,176,320ms] [Fatal] [carb.crashreporter-breakpad.plugin] libcarb.tasking.plugin.so!std::thread::_State_impl<std::thread::_Invoker<std::tuple<void (carb::tasking::ThreadPool::)(), carb::tasking::ThreadPool> > >::~_State_impl()
2021-10-11 20:15:29 [3,176,327ms] [Fatal] [carb.crashreporter-breakpad.plugin] libcarb.tasking.plugin.so!std::thread::_State_impl<std::thread::_Invoker<std::tuple<void (carb::tasking::ThreadPool::)(), carb::tasking::ThreadPool> > >::~_State_impl()
2021-10-11 20:15:29 [3,176,333ms] [Fatal] [carb.crashreporter-breakpad.plugin] libcarb.tasking.plugin.so!std::thread::_State_impl<std::thread::_Invoker<std::tuple<void (carb::tasking::ThreadPool::)(), carb::tasking::ThreadPool> > >::~_State_impl()
2021-10-11 20:15:29 [3,176,340ms] [Fatal] [carb.crashreporter-breakpad.plugin] libcarb.tasking.plugin.so!make_fcontext
Regards,
Sagar Surendran
