Unity app crashes with Quadro and NVAPI warp and blend
we have some serious issue with our cave solution, our unity executable keep crashing, giving the following error :
  1. Unable to recover from a kernel exception. This application must close. Error code 3
This error occurs only after we warp our screens with the NVAPI Warp and blend solution.
If we don’t warp our displays, the app start correctly.
Also, if we warp our displays, then we try to start the app and it crashes, it is impossible to Unwarp our displays.
If we do Unwarp before trying to start the app, it works nicely.
We have trouble knowing what is going on actually, CPu and GPU pilots are up to date, we are using 2 RTX QUADRO 4000, with a Intel core I13.
I also put every power settings to maximum use.
Do you have any ideas why this kernel keep crashing with our configuration ?
