I have a few different machines ranging from three K20s to two 2050s and two K10s to a single K20. On all of these setups, when I go to install CUDA 5.5 I receive the following error:
You are attempting to install on an unsupported configuration. Do you wish to continue? ((y)es/(n)o) [ default is no ]:
All of the machines currently have CUDA 5.0 installed on them. The operating systems vary from CentOS 5.9, CentOS 6.4., and RHEL 5.9. I am installing via the run file and not the rpm.
I also noticed that on the download page, RHEL 5 and RHEL 6 point to the same file as of today. However, this may be on purpose.
To install CUDA 5.5, I first bring the machine into runlevel 3. Next I execute the .run executable. Am I missing anything else?
Any idea why I am getting this error?
##Setup A##
OS: CentOS 6.4
Kernel: 2.6.32-358.11.1.el6.x86_64
Output of cat /proc/driver/nvidia/version:
NVRM version: NVIDIA UNIX x86_64 Kernel Module 304.54 Sat Sep 29 00:05:49 PDT 2012
GCC version: gcc version 4.4.7 20120313 (Red Hat 4.4.7-3) (GCC)
Output of nvidia-smi:
Wed Aug 7 13:17:16 2013
| NVIDIA-SMI 4.304.54 Driver Version: 304.54 |
| GPU Name | Bus-Id Disp. | Volatile Uncorr. ECC |
| 0 Tesla K20m | 0000:02:00.0 Off | 0 |
| N/A 29C P8 25W / 225W | 0% 11MB / 4799MB | 0% Default |
| 1 Tesla K20m | 0000:03:00.0 Off | 0 |
| N/A 34C P8 25W / 225W | 0% 11MB / 4799MB | 0% Default |
| 2 Tesla K20m | 0000:84:00.0 Off | 0 |
| N/A 31C P8 25W / 225W | 0% 11MB / 4799MB | 0% Default |
| Compute processes: GPU Memory |
| GPU PID Process name Usage |
| No running compute processes found |
##Setup B##
OS: CentOS 5.9
Kernel: 2.6.18-194.el5
GCC version: gcc version 4.1.2 20080704 (Red Hat 4.1.2-48)
Wed Aug 7 13:23:59 2013
| 0 Tesla C2050 | 0000:02:00.0 Off | 0 |
| 30% 35C P12 N/A / N/A | 0% 6MB / 2687MB | 0% Default |
| 1 Tesla K10.G2.8GB | 0000:05:00.0 Off | 0 |
| N/A 21C P8 15W / 117W | 0% 9MB / 3583MB | 0% Default |
| 2 Tesla K10.G2.8GB | 0000:06:00.0 Off | 0 |
| N/A 19C P8 15W / 117W | 0% 9MB / 3583MB | 0% Default |
| 3 Tesla C2050 | 0000:83:00.0 Off | 0 |
| 30% 34C P12 N/A / N/A | 0% 6MB / 2687MB | 0% Default |
| 4 Tesla K10.G2.8GB | 0000:86:00.0 Off | 0 |
| N/A 20C P8 15W / 117W | 0% 9MB / 3583MB | 0% Default |
| 5 Tesla K10.G2.8GB | 0000:87:00.0 Off | 0 |
| N/A 18C P8 15W / 117W | 0% 9MB / 3583MB | 0% Default |
##Setup C##
Note: I went ahead an installed CUDA 5.5 anyway for testing on this system. Also the Quadro FX 4800 is not being used for CUDA, just to drive a monitor.
OS: Red Hat Enterprise Linux Server release 5.9
Kernel: 2.6.18-194.26.1.el5
NVRM version: NVIDIA UNIX x86_64 Kernel Module 319.37 Wed Jul 3 17:08:50 PDT 2013
GCC version: gcc version 4.1.2 20080704 (Red Hat 4.1.2-54)
Wed Aug 7 13:25:41 2013
| NVIDIA-SMI 5.319.37 Driver Version: 319.37 |
| 0 Quadro FX 4800 Off | 0000:02:00.0 N/A | N/A |
| 35% 56C N/A N/A / N/A | 17MB / 1535MB | N/A Default |
| 1 Tesla K20c Off | 0000:03:00.0 Off | 0 |
| 30% 36C P8 14W / 225W | 13MB / 4799MB | 0% Default |
| 0 Not Supported |
