I have Version: 5.0.2-b231 of jetpack, flashed long ago on SSD NVMe by SDK manager. Now I would like to upgrade to JP6.0, and there are many threads where the Manager doesn’t see the board, I have the same problem.
Although the board is probably in forced recovery mode because when I check with
sudo dmesg --follow
I get:
[ 222.730162] usb 1-1: new high-speed USB device number 7 using xhci_hcd
[ 222.880000] usb 1-1: New USB device found, idVendor=0955, idProduct=7023, bcdDevice= 4.01
[ 222.880014] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 222.880021] usb 1-1: Product: APX
[ 222.880026] usb 1-1: Manufacturer: NVIDIA Corp.
Which means that devkit is in recovery mode according to Quick Start — Jetson Linux Developer Guide documentation
Can I flash the board using: Flashing Support — Jetson Linux Developer Guide documentation
$ sudo ./flash.sh <board> nvme0n1p<x>
i.e.
$ sudo ./flash.sh jetson-agx-orin-devkit /dev/nvme0n1
Like in After AGX Orin enters the recovery mode, the USB APX driver is incorrectly identified - #9 by linuxdev
Or is it more involved?
So…
- Why doesn’t the Manager see the devkit?
- Is it beacuse it’s too old Jetpack?
- Because it’s flashed on NVMe?
- Can I download the correct AGX Orin Jetpack using sdkmanager? (I only see
~/nvidia/nvidia_sdk/JetPack_6.0_DP_Linux_DP_JETSON_ORIN_NANO_TARGETSthat I used on nano ) and flash it using ./flash.sh? - is
$ sudo ./flash.sh jetson-agx-orin-devkit /dev/nvme0n1enough?
( EDIT: I have latest SDK Manager with 22.04 host, and I already upgraded Orin Nano to JP 6.0 from JP5.x once )
