USB_FS memory allocation
I follwed the solution provided in the below topic.
By re-flashing the AGX xavier with below command without changing any original jepack files
sudo ./flash.sh -k kernel -C “usbcore.usbfs_memory_mb=1000” -k kernel-dtb jetson-xavier mmcblk0p1
Reflashing done successsfully but when i turn on and check the usbfs_memory_mb,its still shows default 16MB.
Please re-flash the system( without -C usbcore.usbfs_memory_mb=1000 ) and only apply this:
change usbcore.usbfs_memory_mb [SOLVED] - #6 by sidneib
Ideally the setting in extlinux.conf shall be applied. Please add the line and reboot the system for a try.
I have tried the mentioned solution as well.But still it is showing default value.
Does it work if you modify the value directly?
# echo 256 > /sys/module/usbcore/parameters/usbfs_memory_mb
its working, but everytime i reboot or power cycle jetson , i need to set it manually, i m trying to flash permanently, please help in approach, thanks
A possible solution is to run a script at startup. Please refer to Jetson Nano FAQ
Q: How to autorun an app or commands at startup?
A bit strange that it doesn’t work by modifying extlinux.conf. This would need other users to share experience.
